Joined: 28/08/2014(UTC) Posts: 613  Was thanked: 337 time(s) in 216 post(s)
Originally Posted by: uni  If we find a free editor of electronic circuits, then we can use this simulator: Spice#. 1. Tutorial. Hi Uni. I prefer Qucks ( http://qucs.sourceforge.net/ ), another simulator. But instead of make a plugin for doing that maths, I guess that SMath is enough powerful for have it's own library for solve spice netlists. In the attached, a very rude mna solver (Modified Nodal Analysis. Can see, for example: http://qucs.sourceforge.net/tech/node14.html or https://www.swarthmore.e...heeve1/Ref/mna/MNA6.html ) and a very primitive Ladder function for chart circuits defined in a similar way like spice files. Also, some attempts for make bode, zp and other charts. I don't know if this could be an one man task, and figure that it could be better to have some place where develop shared libraries in native smath files in a collaborative way. MNA Solver.sm (333kb) downloaded 26 time(s).Best regards. Alvaro.
on 04/02/2019(UTC), on 04/02/2019(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,101   Was thanked: 972 time(s) in 557 post(s)
I'm more interested in circuits with transistors and opamps. You could see one simple circuit with a diode. It is interesting to me to study the behavior of amplifiers, analog solvers with operational amplifiers, generators on one transistor, multivibrators and other similar circuits. Also transient analysis. I think Spice# can do that. But the task should be the scheme, not net list. This is old school  Source codes in c# make this project cross-platform. I want something like Amplitude detector worksheet, but Spice# must solve the ODE. |
Joined: 23/03/2016(UTC) Posts: 214  Was thanked: 75 time(s) in 46 post(s)
Originally Posted by: uni  I'm more interested in circuits with transistors and opamps. You could see one simple circuit with a diode. It is interesting to me to study the behavior of amplifiers, analog solvers with operational amplifiers, generators on one transistor, multivibrators and other similar circuits. Also transient analysis. I think Spice# can do that. But the task should be the scheme, not net list. This is old school  Source codes in c# make this project cross-platform. I want something like Amplitude detector worksheet, but Spice# must solve the ODE. Hi uni. The attached shows that what you need to do that is get inside SMath the net list (and, yes, that's very old school). So, that's means that with some kind of modeler plugin you can get the net list and further process it with some SMath MNA solver, and procedures for bode and others charts.  (example from https://www.swarthmore.e...na/MNA6.html#Example%205 ) The MNA implemented can work with opamps, so, given the equivalent circuit for some transistors, you can implement them. What I can't do yet is implement diodes. Notice that this technique not solve an ode, but get the transfer function. Best regards. Alvaro.
LiveCharts - simple, flexible, interactive & powerful data visualization for .Net. LiveCharts is just data visualization but built and for everyone. |
SUNDIALS: SUite of Nonlinear and DIfferential/ ALgebraic equation Solvers Link: https://github.com/LLNL/sundialsThe SUNDIALS suite consists of the following packages: - ARKODE - for integration of stiff, nonstiff, and multirate ordinary differential equation systems (ODEs) of the form
M y' = f1(t,y) + f2(t,y), y(t0) = y0
- CVODE - for integration of stiff and nonstiff ordinary differential equation systems (ODEs) of the form
y' = f(t,y), y(t0) = y0
- CVODES - for integration and sensitivity analysis (forward and adjoint) of ordinary differential equation systems (ODEs) of the form
y' = f(t,y,p), y(t0) = y0(p)
- IDA - for integration of differential-algebraic equation systems (DAEs) of the form
F(t,y,y' ) = 0, y(t0) = y0, y'(t0) = y0'
- IDAS - for integration and sensitivity analysis (forward and adjoint) of differential-algebraic equation systems (DAEs) of the form
F(t,y,y',p) = 0, y(t0) = y0(p), y'(t0) = y0'(p)
- KINSOL - for solution of nonlinear algebraic systems of the form
F(u) = 0
GeneticSharpGeneticSharp is a fast, extensible, multi-platform and multithreading C# Genetic Algorithm library that simplifies the development of applications using Genetic Algorithms (GAs).  |
on 26/11/2020(UTC), on 26/11/2020(UTC)
Joined: 23/07/2013(UTC) Posts: 202  Was thanked: 59 time(s) in 42 post(s)
Adding svg based interactively editable shapes as in ms office would be useful.
 2 users thanked overlord for this useful post.
on 26/11/2020(UTC), on 27/11/2020(UTC)
Originally Posted by: overlord  Adding svg based interactively editable shapes as in ms office would be useful.
Great idea! Best regards. Alvaro.
Originally Posted by: Jean Giraud  My vote for SVG plugin is NO, absolute |NO|. Rather, a plugin advanced integrator rather than the native good/useless native Simpson.
The idea is a shape plugin, not an SVG plugin. Don't get upset but SVG is already supported. You had already said no by the way, why bother to say another one? And why you thought anyone would say NO to a good native integrator? Why you compare a "going to be useful plugin" with other "going to be useful feature", decide to pick only one and dictate your opinion to other people? Since it would be a plugin, you would have your option not to install it. Besides, why triggered this much, it would not work on your build probably. Since you say NO even to newer builds of SMath.
Joined: 15/04/2012(UTC) Posts: 1,647  Was thanked: 915 time(s) in 575 post(s)
I'd vote for this as well. In engineering, documentation of calculations frequently involves sketches. Making them, so far requires a special setup and a non-obvious workflow (there are two sections on this in the Getting Started Guide example). Currently, I recommend the image region with Paint as external editor for quick and dirty, yet editable sketches. Annotations can be done using math regions. SVG would be smart, because this is stored as human readable xml anyways and therefore quite consistent with the .sm file format. Usability would depend on a good tradeoff between functionality and simplicity, with the picture region where you can't even erase on the one extreme and applications like inkscape on the other extreme. One might even think of parametrizing objects using canvas or placeholder variables. Another trend I adopted recently is to include handwritten sketches in my documents (created with pen and tablet, using Onenote as application). I find myself spending much less time than with whatever graphics software on creating sketches for homework assignments, lecture notes or exams. The ability to create and edit these in SMath Studio would be great. |
Joined: 04/07/2015(UTC) Posts: 5,060  Was thanked: 809 time(s) in 642 post(s)
Originally Posted by: mkraska  Another trend I adopted recently is to include handwritten sketches in my documents (created with pen and tablet, using Onenote as application). I find myself spending much less time than with whatever graphics software on creating sketches for homework assignments, lecture notes or exams. For that matter, I help myself further, for projects. Mathcad 8 sold by > million, delivered with SmartSkech from Intergraph. The demo c/w applicable maths is impressive. It included ISO circuits symbols, has not been used except if not published in the Collaboratory. In 1980, we had graphic packages to draw industrial plant c/w library of symbols. It would draw from point to point something like Paint, color/thickness as desired. In the mean time of inventing a new wheel, interested users may advance a profitable pace. Cheers ... Jean  Inst_Filtrate Bin [Level].sm (34kb) downloaded 7 time(s).
Originally Posted by: overlord  Adding svg based interactively editable shapes as in ms office would be useful. From the 100's documents projects/tutorials I have posted in Samples, please show at least one where the sun is missing ... I will show one for decorative, maths/Physics are not decoration.  Spline De Casteljau SVG Companion Drum.sm (52kb) downloaded 6 time(s). Spline De Casteljau SVG Companion.sm (100kb) downloaded 4 time(s).
Hi. There are a lot of free resources for include sketch's, diagrams, technical draws and thinks like those in C sharp at sites like github and others. But what I think that is actually missing it's the ability for paste as an object and display it as an image, like the old OLE automation for editable objects like Autodesk draws, Visio schemas and usual windows and linux programs. Those objects are save inside the caller application file and can be easily modified just double clicking on it. Finally, it could be very important if SMath files can be inserted as objects into other windows applications, in other words, SMath as an OLE server.
Originally Posted by: Razonar  Hi. There are a lot of free resources for include sketch's, diagrams, technical draws and thinks like those in C sharp at sites like github and others. But what I think that is actually missing it's the ability for paste as an object and display it as an image, like the old OLE automation for editable objects like Autodesk draws, Visio schemas and usual windows and linux programs. Those objects are save inside the caller application file and can be easily modified just double clicking on it. Finally, it could be very important if SMath files can be inserted as objects into other windows applications, in other words, SMath as an OLE server.
Best regards. Alvaro. I would want and regularly use a shape plugin. If it could be implemented well, plugin drastically reduce simple engineering sketch drawing without using any additional software. I would deeply say YES to OLE implementation too, this is a should be feature actually. Heck, thinking of OLE capabilities, why it is not in SMath until now?
A simple plug-in for drawing graphic shapes can be obtained by converting this project. It will be possible to insert simple shapes on the sheet and change their properties. The project sources do not depend on anything and can be used for all versions of the program. I can do it, but I don't have time for it. Edited by user 28 November 2020 11:30:01(UTC)
Process Control & Instrumentation is as important than communications. A Classroom on that is more than years, rather associative life time. It deserves spending some times to image the math/physics under the hood. Glyphes gadgets decoration does not bother me.
You really don't understand what we are telling, do you? What if you really had to change the diagram or create a different diagram from scratch? In the picture below, I had created your example diagram in MS Word using only shapes. Also added an additional step for you to understand. It took me for 10 minutes to create it, and adding new step is only 5-10 seconds. It is scalable and vectorial, you can easily add new items or remove existing without print quality loss. You can also create it with Inkscape, Adobe Illustrator, etc. But please explain, why shouldn't we also do this inside SMath? We are just dreaming here (only dreaming at this moment) to create or manipulate this kind of things in SMath Studio. Because this program is called "Studio". This is not an MatLab or MathCad clone. You want only calculation, nothing else. If you want only calculation and math why don't you use MatLab at all? I don't understand your motivation for opposing every new feature or idea, even existing bug corrections. I remember very well, you had strongly resisted for header/footer also. In the last weeks we were saying picture importing is not working under Linux and while you are not using Linux at all, you had strongly depicted nothing is wrong with SMath. Blissfully Andrey corrected that bug. I have started to think you are deliberately doing this. Regards
BTW, such a plugin could be limited to shapes without annotations, as we always can place text or math regions wherever we want, keeping consistent style between annotated figures and the rest of the document.
The image above would also benefit from being annotated using math regions, as the sans serif font isn't really good for symbols. I suffer from that heavily in Moodle, where question input fields use sans serif. You can't tell lowercase L from capital I. It isn't just by chance that latex formulae use roman font. |
