Offline Jakhro
#1 Posted : 25 January 2019 04:51:33(UTC)
Jakhro
Australia
I am trying to solve 2 eq with 2 variable using Solve() function, the output is division of 2 large numbers which is unusable,
I have tried to find the answer on the forum but cant seem to find anything...
How can I avoid this,
Thanks,
Offline omorr
#2 Posted : 25 January 2019 09:56:16(UTC)
omorr
Serbia
The result is in so called symbolic representation. You can get the numercial answer as well. Just see this is from Interactive book by Martin Kraska (function Solve() in the Maxima plugin). You need Assign() function as well.
Edited by user 25 January 2019 09:58:38(UTC)  | Reason: Not specified
on 25/01/2019(UTC)
Offline Razonar
#3 Posted : 25 January 2019 21:05:23(UTC)
Razonar
Uruguay
Hi. The use of assign for access to the solutions, as Radovan shows, it's useful if you want the variable names with the solution values. But if not, you can use "at" function, and preserve the variables clean.
on 30/01/2019(UTC)
Offline Jakhro
#4 Posted : 30 January 2019 02:50:01(UTC)
Jakhro
Australia
I would like to thank you all for support..... Clap Clap Clap Clap
I got the answer from from Interactive book by Martin Kraska,
Again Thanks to all ...
Edited by moderator 30 January 2019 11:05:57(UTC)  | Reason: marked as Solved
#5 Posted : 30 January 2019 16:23:00(UTC)
You can solve the Engineer way, tracking the upstream dependent(s).
