#1 Posted : 15 December 2018 18:20:41(UTC)
Fourier Quantum [Momentum 2 slits].sm (19kb) downloaded 41 time(s).
Fourier Quantum Airy.sm (10kb) downloaded 28 time(s).
Fourier Quantum CoC Pin Hole.sm (13kb) downloaded 29 time(s).
Fourier Quantum 2C Mask.sm (21kb) downloaded 28 time(s).
Fourier Quantum [mask square hole].sm (68kb) downloaded 31 time(s).
Fourier Quantum 2C.sm (66kb) downloaded 28 time(s).
Fourier Quantum CoC Model.sm (104kb) downloaded 30 time(s).
Fourier Quantum DNA.sm (358kb) downloaded 42 time(s).
on 15/12/2018(UTC)
#2 Posted : 15 December 2018 18:28:12(UTC)
... suite [some didn't upload]
Fourier Quantum Slit.sm (28kb) downloaded 27 time(s).
Fourier Quantum Satellites.sm (23kb) downloaded 31 time(s).
Fourier Quantum Double Slit Probability.sm (37kb) downloaded 26 time(s).
on 15/12/2018(UTC)
#3 Posted : 16 December 2018 19:40:11(UTC)
... CoC diffraction has been refactored
to speed up ~ 20 times faster !
Fourier Quantum CoC Model.sm (123kb) downloaded 32 time(s).
on 16/12/2018(UTC)
Offline CBG
#4 Posted : 18 December 2018 07:57:39(UTC)
CBG
Hello Jean
I get the error "The requested matrix element doesn't exist"
I think that Smath Studio does not accept the sub-index zero,
since at the beginning of the "for" loop in the operations
M (m-1 and n-1) this value is obtained.
Carlos
#5 Posted : 18 December 2018 18:54:55(UTC)
Originally Posted by: CBG Go to Quoted Post
Hello Jean
Not this way Carlos ... maybe ?
1. As you open the document, do you get [1..N]
2. original is 1..N , i.e: NOT nested
3. if you can't re-create unested 1..N
4. sub-index [1..N]1
Jean ... Does it work ?
It may have freaked all other Collabs that downloaded.
Surprising: none commented !
Fourier Quantum DNAsanity.sm (491kb) downloaded 20 time(s).
Offline CBG
#6 Posted : 18 December 2018 21:49:24(UTC)
CBG
Hello Jean,
I made the changes shown in the printout shown
so that the worksheet does not indicate an error.
Fourier Quantum DNA Copy.sm (53kb) downloaded 19 time(s).
Carlos
#7 Posted : 19 December 2018 06:19:09(UTC)
Hello Jean,
Thanks Carlos for your precious collaboration.
The size of the matrix does not matter.
What matters is a symmetric matrix.
Fourier Quantum DNA Copy [NOT Symmetric].sm (182kb) downloaded 21 time(s).
#8 Posted : 19 December 2018 17:21:02(UTC)
This project is one of some that don't reconciliate the 0/1 indexing base.
For this particular application, it is immaterial wrt the end use.
Just interesting to be aware. Seemingly, 0 indexing is more universal.
Fourier Quantum DNA Copy [Symmetric Reconciliation].sm (183kb) downloaded 25 time(s).
Fourier Quantum DNAsanity.sm (489kb) downloaded 23 time(s).
Offline CBG
#9 Posted : 21 December 2018 07:37:22(UTC)
CBG
Hello Jean.
Following the steps indicated in the document;
dna.pdf (182kb) downloaded 13 time(s).
which I have downloaded from the reference you indicate,
and with the data shown there, the following
pattern of refraction is opted;
Fourier Quantum_Jean_Original_Values.sm (222kb) downloaded 21 time(s).
And I wonder if it will be possible:
get the negative of the image in a native way in Smath Studio?
Carlos
#10 Posted : 21 December 2018 13:32:39(UTC)
It's greyscale, I guess 255-DNA should be enough....
Fourier Quantum_Jean_Original_Values - opt_01.sm (168kb) downloaded 22 time(s).
#11 Posted : 21 December 2018 20:54:22(UTC)
Hello: Carlos, Davide ... thanks for your interest.
Ah! this time, SS 6179 does not open 6884.
The Mathcad 11 0 base index original document produces
the required square symmetric matrix. Smath can do it
only as demonstrated. That the SS/MCD matrices are NOT
exactly same is immaterial. The SS symmetric best imitates MCD.
Why SS 6179 does not open 6884 ? Error message is not inductive.
Presumably, 6884 does not save the image compatible to 6179.
Quantum slit runs in less time for exploring symmetric/asymmetric.
Fourier Quantum Slit.sm (38kb) downloaded 23 time(s).
Similar Topics
Fourier Quantum CoC (Samples)
by Jean Giraud 25/05/2019 15:13:00(UTC)
Fourier Quantum [Slit, DNA] (Samples)
by Jean Giraud 09/05/2017 15:22:31(UTC)
Fourier Quantum 2 Circles (Samples)
by Jean Giraud 04/05/2017 18:53:50(UTC)
Fourier Quantum Demo (Samples)
by Jean Giraud 03/05/2017 16:41:18(UTC)
Fourier Quantum [CoC] (Samples)
by Jean Giraud 30/04/2017 18:20:09(UTC)
Fourier Quantum Slit Momemtum Distribution (Samples)
by Jean Giraud 09/05/2016 19:20:46(UTC)
