Offline Steve22
#1 Posted : 07 December 2018 02:05:32(UTC)
Steve22
New Zealand
Hi, the attached sheet defines a simple function Qout(Qin) based on if statements. The function works for single valves of Qin. However, I'd like to plot Qout(Qin) so I defined Qin as a range variable. The function doesn't work and gives me a type conversion error. I'm a newbie to smath, please can you advise what I'm doing wrong? I've been through the documentation and examples and can't find anything. pump station2.sm (10kb) downloaded 8 time(s).
Edited by user 07 December 2018 02:07:05(UTC)  | Reason: Not specified
#2 Posted : 07 December 2018 04:13:21(UTC)
Was thanked: 610 time(s) in 473 post(s)
Originally Posted by: Steve22 Go to Quoted Post
Hi, the attached sheet defines a simple function Qout(Qin) based on if statements.The function works for single valves of Qin.However, I'd like to plot Qout(Qin) so I defined Qin as a range variable.The function doesn't work and gives me a type conversion error.I'm a newbie to smath, please can you advise what I'm doing wrong?I've been through the documentation and examples and can't find anything.
That's as far I understand the problem. It needs more fabrication.
It should work in your latest Smath. If you have more interest,
I can probably find a model function to the pump curve.
As your are nwe in Smath Community: please, do not hesitate.
pump station2.sm (22kb) downloaded 15 time(s).
on 07/12/2018(UTC)
