Offline Razonar
#1 Posted : 30 November 2018 01:09:04(UTC)
Razonar
Uruguay
Hi. I can't reproduce this in SMath.
Integrate with ode solver.sm (7kb) downloaded 35 time(s). Integrate with ode solver.zip (9kb) downloaded 25 time(s).
on 30/11/2018(UTC),  on 30/11/2018(UTC)
#2 Posted : 30 November 2018 05:48:00(UTC)
1/1 in Smath 6179, proof: the snippet.
Cheers Alvaro
Integrate with ode solver.sm (30kb) downloaded 35 time(s).
#3 Posted : 30 November 2018 05:59:54(UTC)
You may not be able to implement the Mathcad bloc Given/ODEsolve.
ODEsolve is based on linterp. That is the first point.
The other point is that in Mathcad "linterp(x)" is a scalar function.
In Smath: ainterp, cinterp, linterp are simply interpolation fncts
They are not scalar functions. How does it reflects in ODEsolve ?
In Smath, ln(x), exp(x), ... are scalar from source code.
I tried to make cinterp scalar like in Mathcad, not to avail.
Please, persist on such a beautiful idea.
#4 Posted : 30 November 2018 07:16:48(UTC)
This document was essentially designed to plot scalar the derivative on canvas,
as well as get a discrete export. Also included: the scalar quadratic.
Spline Deriv Infinitesimal.sm (71kb) downloaded 32 time(s).
Offline Razonar
#5 Posted : 30 November 2018 08:31:22(UTC)
Razonar
Uruguay
Hi Jean. Actually not, just the solver, without the given.
I found how to call the odesolver, with D(x,y)=[f(x)].
This method is much more faster than the direct integration.
But remains the ln(0) error, which seems to be a bug in the odesolvers, because zero isn't in the domain range.
Integrate with ode solver.sm (11kb) downloaded 36 time(s).
Edited by user 30 November 2018 08:33:22(UTC)  | Reason: Not specified
on 30/11/2018(UTC)
Offline uni
#6 Posted : 30 November 2018 09:35:52(UTC)
uni
The zero point is used to determine the dimension of the vector D(t,x) at runtime (D(0, x0)). The size of the system must be determined for the further operation of the numerical algorithm. It seems that it would be correct to substitute the beginning of the interval. I will try to change this. Also, if possible, I will support the one-dimensional case.
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 30/11/2018(UTC),  on 30/11/2018(UTC),  on 30/11/2018(UTC),  on 30/11/2018(UTC)
Offline Razonar
#7 Posted : 30 November 2018 11:01:06(UTC)
Razonar
Uruguay
Thanks Viacheslav. It's amazing the effort that you and the others plugins developers put in enhance SMath, with very spectacular results.
on 03/12/2018(UTC)
#8 Posted : 30 November 2018 18:29:42(UTC)
Buenos dias Alvaro !
ln(0) was introduced in Mathcad 11 soon after release via update [from recollection]
There is more in the attached, specially wrt parametric D(,,,).
ODE 0_Model General.sm (30kb) downloaded 24 time(s).
#9 Posted : 30 November 2018 18:34:54(UTC)
#10 Posted : 30 November 2018 21:36:38(UTC)
... refreshed version wrt explore all solvers.
ODE 0_Model General.sm (39kb) downloaded 43 time(s).
thanks 3 users thanked Jean Giraud for this useful post.
on 30/11/2018(UTC),  on 30/11/2018(UTC),  on 04/12/2018(UTC)
