4 Pages<1234>
Offline Razonar
#41 Posted : 08 November 2018 23:37:16(UTC)
Razonar
Uruguay
Was thanked: 277 time(s) in 172 post(s)
Originally Posted by: Ber7 Go to Quoted Post
The parameterization by Draghilev method.The starting point is taken near the bifurcation point (0,0).
Just a very little modifications: using norme(J) and the SMath ability for handling undefined parameters.
ContourTifoleum.sm (17kb) downloaded 21 time(s).
on 09/11/2018(UTC),  on 09/11/2018(UTC)
Offline Ber7
#42 Posted : 09 November 2018 11:29:40(UTC)
Ber7
Israel
Was thanked: 447 time(s) in 240 post(s)
Thank you, Alvaro. The norme function simplifies the code and reduces the calculation time.
Example of using norme when solving ODE
LorenzPointsAreEquidistantc.sm (7kb) downloaded 24 time(s).
thanks 2 users thanked Ber7 for this useful post.
Offline Razonar
#43 Posted : 09 November 2018 19:08:46(UTC)
Razonar
Uruguay
Hi Ber. I don't remember to read nothing in the literature about equally spaced points in the numerical solution of the ode, except for the opposite: adaptive steps, but referring for the time variable, not the X,Y,Z solution points. About how you apparently get the same distance between solution points, i.e. sqrt(X^2+Y^2+Z^2), I guess that the background theory must to be in the Draghilev method and how the solution (X,Y,Z) is obtained from the differential equation. You have a very interesting point for investigate and publish about it.
I try to investigate the relationship between the symbolic ode solution and the paramatrization, but the symbolic solutions are quite complicated, and I don't have simple examples.
Apparently the distance between the points is 1 (guess can be easily proved because you divide by the norme the system), and this seems to provide more stable numerical solutions for the system (can be applied here Lyapunov's theorems?)
Unfortunately in this example I introduce the factor 1/1000 for avoid numerical over max limit error for the case without norme.
Online Jean Giraud
#44 Posted : 11 November 2018 05:39:23(UTC)
Was thanked: 789 time(s) in 625 post(s)
Thanks Ber7, gorgeous
For this particular Trifolium, once created it is easy to collect
as many as desired to any scale corresponding to Draghilev 'a'
The great tool here, is the bidirectional fmesh(f(x),x0,x1,mesh)
2D Parametric Plot [Create Trifolium].sm (32kb) downloaded 21 time(s).
Offline Ber7
#45 Posted : 11 November 2018 08:48:41(UTC)
Ber7
Israel
Thank you Jean, I suggest a small change in the animation.
TrifoliumAnim.sm (25kb) downloaded 19 time(s).
Edited by user 11 November 2018 12:44:29(UTC)  | Reason: Not specified
Online Jean Giraud
#46 Posted : 11 November 2018 17:48:44(UTC)
Thanks Ber7 ... even more compacted.
Trifolium:=stack(b1,b2,b3,b4) from inversing f4(x) <= f3(x).
0Anim Trifolium [Windmill Ber7].sm (26kb) downloaded 19 time(s).
Offline Ber7
#47 Posted : 24 November 2018 22:03:02(UTC)
Ber7
Israel
Graph of implicit function with bifurcation point (Problem on
the calculation of the arch)
https://en.smath.info/forum/yaf_...thod-in-Engineering.aspx
The graph consists of three curves that occur at the bifurcation point.
1. Find the coordinates of the bifurcation point
2.The starting point for each of the three graphs is taken near the bifurcation point
3. Build graphics by Draghilev method
Point Bifurcation.sm (39kb) downloaded 21 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 24/11/2018(UTC)
Online Jean Giraud
#48 Posted : 26 November 2018 04:29:54(UTC)
Thanks Ber7.
This version works fine compared to the previous "arca" that never stopped pedaling .
By same token, I'm puzzled by the Lagrange points. Where those contours come from ?
Offline frapuano
#49 Posted : 26 November 2018 10:56:38(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Joan
from Wikipedia it is stated that they are involved in Astronomy and that for 2 large bodies there are 5 of these points so I guess that your pictures/worksheet refers on how to calculate them all(their positions).
https://en.wikipedia.org/wiki/Lagrangian_point
Franco
Online Jean Giraud
#50 Posted : 28 November 2018 16:30:11(UTC)
dn_GearsBDF is nearly ½ time. I think its Lorentz
Offline алексей_алексей
#51 Posted : 05 January 2019 16:22:29(UTC)
алексей_алексей
Rank: Member
Was thanked: 10 time(s) in 5 post(s)
Maple, Draghilev's method. The inverse problem of kinematics. For those who want to try hard and to do better in SMath.
Online Jean Giraud
#52 Posted : 05 January 2019 18:10:14(UTC)
Thanks for the suggestion. My head is not oblate like Extraterrestrials !
Offline Ber7
#53 Posted : 06 January 2019 11:18:45(UTC)
Ber7
Israel
An article about the effectiveness of the solution of the system diff. equations for parameterization integral curve through arc length
Russiy.pdf (608kb) downloaded 34 time(s).
on 06/01/2019(UTC),  on 07/01/2019(UTC)
Offline Razonar
#54 Posted : 09 January 2019 00:02:47(UTC)
Razonar
Uruguay
. I don't remember ...
Thanks for the paper. Now you found the keywords for this point, which seems to be "Arc Length Method". This give only 79 results at google search:
Results are related with mechanical engineering for finite elements analysis. From the first result, having this attached file: https://scholar.harvard....sios/files/ArcLength.pdf
But actually I don't find any appointment nor observation that solution points are equally spaced. Notice that It could be some "obvious" point for, given f(t,x,x' ) = 0, plot for x(t) it's equally spaced if one transform it to f(s,x,x' ) with s as the arc length. But it's immediate for me that the plot for the state space (x,x' ) seems to be equally spaced too, as in some smath examples here in this topic.
Also, for the observation that can apply Lyapunov theorems about stability of solutions, there are some references in the 79 google's search results. The application here of Lyapunov is related about the stability of the found solutions, because authors using the parametrization along the arc length for ill conditioned systems.
. Apparently the distance between the points is 1 (guess can be easily proved because you divide by the norme the system), and this seems to provide more stable numerical solutions for the system (can be applied here Lyapunov's theorems?)
Edited by user 09 January 2019 00:15:12(UTC)  | Reason: Not specified
on 09/01/2019(UTC),  on 09/01/2019(UTC)
Offline Ber7
#55 Posted : 26 February 2019 20:32:50(UTC)
Ber7
Israel
Finding Minimum Distanceof a Point from Curve
(with Draghilev method)
MinDistDragilev.sm (24kb) downloaded 23 time(s).
Edited by user 27 February 2019 11:55:44(UTC)  | Reason: Not specified
thanks 4 users thanked Ber7 for this useful post.
on 26/02/2019(UTC),  on 26/02/2019(UTC),  on 26/02/2019(UTC),  on 25/03/2019(UTC)
Online Jean Giraud
#56 Posted : 26 February 2019 21:07:47(UTC)
Finding Minimum Distance of a Point from Curve
Thanks Ber7 ... works fine.
Offline Ber7
#57 Posted : 13 March 2019 20:47:37(UTC)
Ber7
Israel
Distance from point to implicit curve(with al_nleqsolve)
A thick red line is the normal to the curve at point a.
FindDist.pdf (244kb) downloaded 22 time(s).
FindDist.sm (73kb) downloaded 25 time(s).
on 13/03/2019(UTC),  on 13/03/2019(UTC),  on 13/03/2019(UTC),  on 25/03/2019(UTC)
Offline Ber7
#58 Posted : 24 March 2019 19:53:07(UTC)
Ber7
Israel
Refined the algorithm and added examples
DistMod.sm (52kb) downloaded 23 time(s).
thanks 3 users thanked Ber7 for this useful post.
on 24/03/2019(UTC),  on 24/03/2019(UTC),  on 25/03/2019(UTC)
Online Jean Giraud
#59 Posted : 25 March 2019 00:18:49(UTC)
Thanks Ber7,
looks interesting but couldn't doctor SS 6179.
Offline Ber7
#60 Posted : 25 March 2019 14:19:26(UTC)
Ber7
Israel
How the algorithm works.
Each time you press F9, we set the new position of point A
Animat.sm (22kb) downloaded 16 time(s).
Edited by user 25 March 2019 14:22:16(UTC)  | Reason: Not specified
on 25/03/2019(UTC),  on 25/03/2019(UTC)
Similar Topics
Draghilev method revisited [Isocurves] (Samples)
by Jean Giraud 27/03/2019 18:17:33(UTC)
4 Pages<1234>
