SMath Studio Forum
Questions
Measured values in practical seminar
Hello people, I'm new to this kind of software. Normally i work with excel. I'm doing internships with students where they measuring for example for different flow the losses in a system. In Excel i did that calculation in a table, but it was hard to display the formulars. So now my problem is: When i put the values which were measured in a matrix, it is not possible to square it... Addition is workig really well. So should i put it in lists? But with lists its not possible to do addition... You may have a look to my data... i have the vector v1 and in the formula i need v1^2, but it doesnt calculate the right value... Praktikum Venturi Blende.sm (35kb) downloaded 28 time(s).Thanks for you reply
Originally Posted by: phili-marx Hello people, i have the vector v1 and in the formula i need v1^2, but it doesnt calculate the right value... Praktikum Venturi Blende.sm (35kb) downloaded 28 time(s).Thanks for you reply Hi. You can use v1[k for square it, or better, not using the k range, with the vectorize operator (the arrow in the matrix palette) when the expression is evaluated for some more complicated expression than sums or products by scalars. Please, see the attached. Praktikum Venturi Blende.sm (31kb) downloaded 35 time(s).SMath vectorization is something like dot operator in matlab. Best regards. Alvaro.
Originally Posted by: phili-marx I'm doing internships with students where they measuring for example for different flow the losses in a system. ... few more stuff for your Classroom Internships. The orifice Plate [ISO-5167] is the standard I have use since Windows. Previous to Windows, used Sharp pocket calculator iterative method. Previous to calculating machinery: used the Foxboro booklet and log tables. One way or another, Iso-5167 implements the 1970 Foxboro. Orifice plate is an Engineering document. Jean Inst_Colebrook MOODY.sm (20kb) downloaded 27 time(s). Inst_Orifice Plate.sm (388kb) downloaded 34 time(s). Inst_Flow Profile.sm (674kb) downloaded 33 time(s).
... a much better demonstrative Vena Contracta.
Dear people, thanks for all of your replys. I didnt think, that i would get a answer. Helped a lot and I understood the problem. Thanks also for all the feature documents relating to the orifice/venturi calculation. Thanks.
Originally Posted by: phili-marx Thanks also for all the feature documents relating to the orifice/venturi calculation. 1. [1975..77] I was involved with the Montreal sewage pumping station, at the time the world biggest project of the kind, presented to an International Symposium [Yougoslavia]. 17 pumps 100000 UGM each, of which two variable speed, 139 ft deep. At the top discharge, 17 Venturi flow measuring devices, each 8 ft diameter [Brooks ~ 1000000 $ each] Pump engine 4500 HP each. 2. The best beta ratio [Orifice Plate] is around 0.62. Installed in machined meter run and lab tested give the best accurate mass-flow rate. An industrial plant may have 100's measuring points. It won't be be practical to have each flow meter associated with its own calibration. Instead we calculate/bore each orifice plate with its own beta ratio, thus minimizing the burden of the Instrument Men ! No point to purchase expensive Orifice Plate software, Smath does it just perfect. Cheers ... Jean
SMath Studio Forum
Questions
