SMath Studio - SMath
Congratulations!! This software is amazing!! An almost complete substitution for Mathcad!!
more...
by Hervandil Sant'Anna
Niezwykle przejrzyste narzędzie. Świetne do sprawdzenia czegoś na szybko, naturalne jak pisanie w zeszycie. Silna alternatywa dla MathCADa, zdecydowanie godny polecenia!
more...
by mati
I've used this software for several years and can not use anything else for work. I'm a mechanical Engineer and use this for any calculations I do.
1) To show and check my work
2) to set values and write descriptions so I can reuse my formulas for other projects.
This is better than any calculator.
Thank you Smath for such a great software.
more...
by Shawn Paul
on 30/10/2018(UTC), on 30/10/2018(UTC), on 30/10/2018(UTC), on 31/10/2018(UTC), on 01/11/2018(UTC)
Sometimes I test new versions of Smath with my very old worksheet which keeps failing since 0.98.5973. This time it puzzled me again. Please see how it performs now. The SS prints the result of maple(expand(...)) normally, but after assigning the resulting expression to the variable nnn, it failed even to display nnn. What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s).Edited by user 01 November 2018 03:29:59(UTC)
| Reason: Not specified
Originally Posted by: tomtit Sometimes I test new versions of Smath with my very old worksheet Maybe just like this Tom ... like 5346, 6179
Originally Posted by: tomtit ... What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s). Hi. It means that can't recalculate because the use of sums and products. For force the recalculation as it is needed, can enclose the num definition by a line: Best regards. Alvaro.
