Offline Andrey Ivashov
#1 Posted : 11 October 2018 01:54:46(UTC)
Was thanked: 1972 time(s) in 661 post(s)
New Beta SMath Studio 0.99.6858 is available!
SMath Studio boxCalculation of Gravitation Acceleration exampleExample of animation on the WorksheetExtensions Manager toolOpened math Reference BookSMath Viewer output to Autocad exampleSMath Studio on iOSSMath Studio on iPad
Changes introduced in current build
Improvements
  • Added support for Header/Footer (see Insert > Header/Footer menu items or use doubleclick on Header/Footer area to activate editing; press ESC or doubleclick on page content to return back);
  • Implemented support for Fields (auto-fields) inside MathRegion (see Insert > Field... dialog);
  • Added ability to Fill background image to the page bounds;
  • Background image can now be shown in full page size;
  • MathRegions consists with single variable name contains special symbols automatically switches cursor to Special Chars mode on focus.
Corrections
  • Fixed issue happens on drawing cursor after space symbol in MathRegion;
  • Incorrect pages numbers used in Insert Background dialog fixed for Pages layout mode;
  • Fixed observation happens on inserting operator inside of the variable name which contains special symbols;
  • SS-3567: Saving of worksheets with protected collapsed Areas fixed.
Miscellaneous
  • Refactoring.
Download
Software icon SMathStudioDesktop.0_99_6858.Setup.msi (Date: 2018.10.11; File size: 2.22 MB) - 984 downloads
Software icon SMathStudioDesktop.0_99_6858.Mono.tar.gz (Date: 2018.10.11; File size: 1.35 MB) - 181 downloads
thanks 9 users thanked Andrey Ivashov for this useful post.
on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 12/10/2018(UTC),  on 16/10/2018(UTC),  on 18/10/2018(UTC)
Offline overlord
#2 Posted : 12 October 2018 19:38:12(UTC)
Turkey
Was thanked: 409 time(s) in 275 post(s)
New header-footer option is awesome. This will help me to reduce file sizes a lot.
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
Edited by user 12 October 2018 19:50:25(UTC)  | Reason: Not specified
Offline ianlh
#3 Posted : 14 October 2018 12:28:42(UTC)
ianlh
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
Offline mkraska
#4 Posted : 15 October 2018 22:01:30(UTC)
mkraska
Was thanked: 1001 time(s) in 641 post(s)
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field).
Offline Alex M.
#5 Posted : 17 October 2018 20:42:38(UTC)
Alex M.
Was thanked: 123 time(s) in 94 post(s)
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
Offline alyles
#6 Posted : 18 October 2018 00:14:08(UTC)
alyles
Was thanked: 86 time(s) in 54 post(s)
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
thanks 1 user thanked alyles for this useful post.
on 18/10/2018(UTC)
#7 Posted : 19 October 2018 00:00:08(UTC)
Was thanked: 944 time(s) in 772 post(s)
Originally Posted by: alyles Go to Quoted Post
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
Offline Farja
#8 Posted : 19 October 2018 18:46:24(UTC)
Farja
Chile
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
Offline Mustafa_K
#9 Posted : 21 October 2018 15:06:25(UTC)
Mustafa_K
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German:
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
Offline Mustafa_K
#10 Posted : 21 October 2018 15:15:00(UTC)
Mustafa_K
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
#11 Posted : 26 October 2018 20:55:58(UTC)
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
