Offline Andrey Ivashov
#1 Posted : 11 October 2018 01:54:46(UTC)
Was thanked: 2012 time(s) in 680 post(s)
SMath Studio - SMath
Created by SMath LLC in the scope of SMath project. Published by smath.
  • SMath Studio box
  • Calculation of Gravitation Acceleration example
  • Example of animation on the Worksheet
  • Extensions Manager tool
  • Opened math Reference Book
  • SMath Viewer output to Autocad example
  • SMath Studio on iOS
  • SMath Studio on iPad
They trust us *
* Customers' names and logos are used with the written permission of the copyright holders.
They talk about us (all reviews...)
  • The secret power of the original MathCad was its self-documenting feature. SMath brings this back and it is free. Amazing. Write your math essentially the same way you would write it by hand, but it is live. The math is calculated left-to-right then top-to-bottom. Self-documenting and live. Wonderful.
    by John Cantlin
  • Спасибо вам за вашу работу, это приложение просто прекрасно!
    by Илья
  • Found out that this software is as powerful as commercial softwares. Many thanks Andrey.
    by Harold Lopez
  • This program helped me in solving a lot of my mechanical problems related to gears, design standards & structural problems. Now we can run it on our mobiles also. Thanks for this useful program.
    by Sudhir Gill
  • May God reward the developers, for filling the vacuum left after MathCad. Thank you very very much.
    by Zsolt Roman
  • I'm a student of civil engineering and SMath has become an invaluable tool for "by hand" calculations of my assignments. I can't believe other students are still using MS Word and a regular calculator.
    by Filda
  • Buenísima aplicación.
    by Nicolás Troncoso
  • This mathematical tool is very useful. I was a Mathcad user, now I use SMath in all courses I teach and ask my students to use it.
    by Waluyo Adi Siswanto
  • This is a great tool. Just like Mathcad. I'd encourage science/engineering students to use it. And you get a copy of your work.
    by RJ
  • The most important daily-use software for engineers. Far more powerful than actual Mathcad Prime. I actually use more SMath Studio than MS Excel at work. Thank you, Andrey, for this GEM.
    by Alvaro Gavilán Rojas
SMath Studio in publications (all publications...)
SMath Studio plug-ins (all plug-ins...)
The functionality of the program can be expanded through the installation of plug-ins created by third-party developers and companies, as well as those prepared by the SMath LLC team. Most plug-ins are open source and can be modified if necessary.
  • Extends SMath Studio with a 3D Plot Region.
    Jack Xu, Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with more save/import/export features.
    Davide Carpi (davide.carpi@gmail.com)
  • Access to a set of programs for calculating properties of water, steam, gases and gases mixtures. Requires separate installation of the Water Steam Pro libraries and appropriate license for it (see http://www.wsp.ru/).
    ООО "ЭсМат"
  • Provides access to the free and open source computer algebra system Maxima.
    Kay Graubmann & Martin Kraska (THB www.th-brandenburg.de)
  • Extends SMath Studio with a X-Y Plot Region.
  • A SMath Studio native wrapper of the CoolProp library (www.coolprop.org) - thermophysical property database and wrappers for a selection of programming environments.
    Mike Kaganski
  • Contains nonlinear solvers for equations and systems of equations: Bisected Direct Quadratic Regula Falsi (BDQRF), Bisection, Brent's, Broyden's, Homotopy, Newton-Raphson, Ridder's, Secant, etc.
  • Digital Signal Processing Library: spectral analysis, IIR and FIR filters, resampling algorithms, etc.
    Sergey Bakhurin (http://dsplib.org), Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with statistical tools: Sample Estimators, Probability Density, Cumulative Density, Quantile functions, Random Numbers, etc.
  • Provides an interface to the SQLite relational database engine.
    Chris Bietz, Viacheslav N. Mezentsev
thanks 9 users thanked Andrey Ivashov for this useful post.
on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 11/10/2018(UTC),  on 12/10/2018(UTC),  on 16/10/2018(UTC),  on 18/10/2018(UTC)
Offline overlord
#2 Posted : 12 October 2018 19:38:12(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
New header-footer option is awesome. This will help me to reduce file sizes a lot.
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
Edited by user 12 October 2018 19:50:25(UTC)  | Reason: Not specified
Offline ianlh
#3 Posted : 14 October 2018 12:28:42(UTC)
ianlh
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
Offline mkraska
#4 Posted : 15 October 2018 22:01:30(UTC)
mkraska
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field).
Offline Alex M.
#5 Posted : 17 October 2018 20:42:38(UTC)
Alex M.
Was thanked: 127 time(s) in 96 post(s)
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
Offline alyles
#6 Posted : 18 October 2018 00:14:08(UTC)
alyles
Was thanked: 93 time(s) in 58 post(s)
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
thanks 1 user thanked alyles for this useful post.
on 18/10/2018(UTC)
#7 Posted : 19 October 2018 00:00:08(UTC)
Originally Posted by: alyles Go to Quoted Post
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
Offline Farja
#8 Posted : 19 October 2018 18:46:24(UTC)
Farja
Chile
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
Offline Mustafa_K
#9 Posted : 21 October 2018 15:06:25(UTC)
Mustafa_K
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German:
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
Offline Mustafa_K
#10 Posted : 21 October 2018 15:15:00(UTC)
Mustafa_K
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
#11 Posted : 26 October 2018 20:55:58(UTC)
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
