  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,592   Was thanked: 1929 time(s) in 654 post(s)
New Beta SMath Studio 0.99.6858 is available!Tiny, but powerful mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- Added support for Header/Footer (see Insert > Header/Footer menu items or use doubleclick on Header/Footer area to activate editing; press ESC or doubleclick on page content to return back);
- Implemented support for Fields (auto-fields) inside MathRegion (see Insert > Field... dialog);
- Added ability to Fill background image to the page bounds;
- Background image can now be shown in full page size;
- MathRegions consists with single variable name contains special symbols automatically switches cursor to Special Chars mode on focus.
Corrections- Fixed issue happens on drawing cursor after space symbol in MathRegion;
- Incorrect pages numbers used in Insert Background dialog fixed for Pages layout mode;
- Fixed observation happens on inserting operator inside of the variable name which contains special symbols;
- SS-3567: Saving of worksheets with protected collapsed Areas fixed.
Download
 9 users thanked Andrey Ivashov for this useful post.
on 11/10/2018(UTC), on 11/10/2018(UTC), on 11/10/2018(UTC), on 11/10/2018(UTC), on 11/10/2018(UTC), on 11/10/2018(UTC), on 12/10/2018(UTC), on 16/10/2018(UTC), on 18/10/2018(UTC)
Joined: 23/07/2013(UTC) Posts: 773  Was thanked: 275 time(s) in 195 post(s)
New header-footer option is awesome. This will help me to reduce file sizes a lot. By the way I noticed the linux and windows versions have layout difference. Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions. Regions under Linux are wider and pictures regions are bigger I guess. I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it. Regards. Edited by user 12 October 2018 19:50:25(UTC)
| Reason: Not specified
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
Joined: 15/04/2012(UTC) Posts: 1,728  Was thanked: 950 time(s) in 602 post(s)
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field). |
Joined: 03/03/2014(UTC) Posts: 408  Was thanked: 119 time(s) in 92 post(s)
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
Joined: 23/03/2016(UTC) Posts: 238  Was thanked: 76 time(s) in 47 post(s)
Thanks! In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. . |
 1 user thanked alyles for this useful post.
Joined: 04/07/2015(UTC) Posts: 6,103  Was thanked: 891 time(s) in 719 post(s)
Originally Posted by: alyles  May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded? Interesting request, but between the moment a work sheet is first created and the last saving [dozen and dozen times saved], the first time saved has no more meaning: is it ? Windows timestamp [hover on sheet name] is the last saved. Print preview page header is the actual time
Joined: 05/01/2018(UTC) Posts: 7  Location: Zzz Was thanked: 1 time(s) in 1 post(s)
Hi, I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets. But, i get this error with the latest version: "Object reference not set to an instance of an object."  Thanks!
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German: "Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Regards, Mustafa
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
Originally Posted by: Farja  Hi, I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets. But, i get this error with the latest version: "Object reference not set to an instance of an object."  Thanks! Thank you for the report. Issue is fixed now. Fix will be available into the next beta release. Best regards!
