Offline studoc
#1 Posted : 05 July 2011 05:16:53(UTC)
studoc
Rank: Member
This is what I would like to do, but when I follow this procedure, when typing the variable again I am prompted with the already stored result...
How can I fix this...?
cheers,
Stu.
Offline omorr
#2 Posted : 05 July 2011 08:08:08(UTC)
omorr
Serbia
Sorry Stu,
I do not understand your question. Could you be more specific please.
Offline studoc
#3 Posted : 05 July 2011 12:16:32(UTC)
studoc
Rank: Member
Sure, thanks Radovan,
what I want to do is input changing values to a variable used in an equation I have defined in one of my calc sheets. Actually, the way I use this program, I would often do this...
I have written an equation, then defined the variables, subsequently, in order to arrive at an acceptable solution to the equation, I will need to change the value of one of the variables.
The above example suggested to me that as long as you write the equation first and then define the variables you could subsequently change a variable and therefore get amended results for the equation.
When I did this in my sheet, retyping "a=", the program immediately jammed in the already defined value of "a", so I don't get to amend the variable and therefore amend the result to the equation....
Stu.
Offline omorr
#4 Posted : 05 July 2011 12:53:08(UTC)
omorr
Serbia
Hell Stu,
I hope I understood your problem.
There is the difference between "definition - operator := " and "numerical evaluation - operator =".
When yuo type "A=" you will see (in the case A was not already defined above or to the left):
A←#
SMath will ask you to "define" the variable named A because it was not previously defined. Now, when you define the variable:
A←10.5
And type "A=" afterwards you will have "numerical evaluation" and get the value of variable A:
A=10.5
If you want to redefine A, you must type "A:" (not "A=" ) and to get again
A←#
in order to redefine the value of A
I think that your problem was in using "=" operator instead of ":=" for redefining variables
An example:
Type
f(x)=x+a
SMath
f(x)←x+a
ATTENTION: you typed "=" but on the screen you will see ":=" because f(x) was not already defined
Type
a=5 or a:5
SMath
a←5
Type
f(1)=
SMath
f(1)=6
Now, if you want to change a - you MUST
Type
a:11
Smath
a←11
Type
f(1)=
SMath
f(1)=12
Edited by user 05 July 2011 13:05:55(UTC)  | Reason: Not specified
Offline studoc
#5 Posted : 10 July 2011 03:45:39(UTC)
studoc
Rank: Member
Sorry, don't think I replied to you... this is exactly what I was looking for, thanks Radovan...!
Stu.
Offline omorr
#6 Posted : 10 July 2011 11:50:44(UTC)
omorr
Serbia
You are welcome Good
