Offline kilele
#1 Posted : 03 June 2011 02:36:55(UTC)
kilele
I can't change units of this matrix ? Is this a bug ?
Thanks
Open in SMath Cloud
Offline omorr
#2 Posted : 03 June 2011 09:32:56(UTC)
omorr
Serbia
I think it was already mentioned this on the Forum.
SMath matrix elements can be of different type (text, numbers, units etc.). If you display matrix with elements which consist units - there will be default units diaplayd ('m instead 'mm here) and you can not change the units inside matrix. I think that this feature is not implemented yet. As a workaround, you can just display the particular matrix element and then change the units into the desired one.
