27 Pages«<1314151617>»
Offline uni
#281 Posted : 04 August 2018 08:46:31(UTC)
uni
Updated. Line style for shape added. Small changes in the shape vector format.
X-Y Plot. Draw shapes.sm (30kb) downloaded 57 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 04/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC)
Offline uni
#282 Posted : 04 August 2018 18:42:20(UTC)
uni
Updated. Arc and pie added, rounded rect fixed.
X-Y Plot. Draw shapes.sm (35kb) downloaded 70 time(s).
Edited by user 04 August 2018 19:09:23(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ndtma
#283 Posted : 04 August 2018 19:14:31(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
Thanks. How about a simple arrow?
Edited by user 04 August 2018 19:50:55(UTC)  | Reason: Not specified
Offline omorr
#284 Posted : 04 August 2018 23:37:50(UTC)
omorr
Serbia
I saw the picture above made by uni and just remembered that many times users mentioned filling option (fill the area below the curve and x-axis) and workarounds in standard SMath plot.
Offline uni
#285 Posted : 05 August 2018 04:43:12(UTC)
uni
I do not know how to do it better. The arrow should look good in different scales and in its own size.
Future plans:
- add a bar plot;
- add a contour plot;
- add a color map plot;
- add a vector field plot.
As for the log scale, for now I don't know how to add it without breaking the old documents.
Edited by user 06 August 2018 23:07:47(UTC)  | Reason: Not specified
Russia ☭ forever
on 05/08/2018(UTC),  on 05/08/2018(UTC),  on 05/08/2018(UTC)
#286 Posted : 06 August 2018 01:31:05(UTC)
I don't see what I posted few hours ago ?
2D Util Bar Arrow.sm (24kb) downloaded 49 time(s).
thanks 2 users thanked Jean Giraud for this useful post.
on 06/08/2018(UTC),  on 06/08/2018(UTC)
#287 Posted : 06 August 2018 04:23:12(UTC)
We have the Mathcad code for vector field arrow, pretty involved.
Very superb to appreciate some DE solution as it evolves.
Offline uni
#288 Posted : 06 August 2018 22:54:53(UTC)
uni
Updated. Serialization dependency for the settings form removed (changed to the experimental automatic algorithm). Legend height issue fixed. Save/load methods are significant refactored. Version changed to 0.2.x.x. Names (text representation) for the some parameters simplified (truncated).
Be careful Good
Russia ☭ forever
Offline uni
#289 Posted : 07 August 2018 11:14:02(UTC)
uni
The legend shows line patterns even if line visibility is set to false for the data series.
Workaround: Set the line color to transparent (see left plot).
Updated. Fixed.
Russia ☭ forever
on 07/08/2018(UTC),  on 07/08/2018(UTC),  on 07/08/2018(UTC)
#290 Posted : 07 August 2018 17:40:24(UTC)
#291 Posted : 07 August 2018 23:53:46(UTC)
#292 Posted : 08 August 2018 00:07:37(UTC)
MCD arrow style on low populated field is OK.
MCD arrow style on high populated field ... just horror.
Offline uni
#293 Posted : 08 August 2018 06:19:31(UTC)
uni
Jean, I already have code for this:
To all.
I can add more plot styles (or regions):
- stem, error, area, stock, stairstep, bar, countur (color mapped), vector field (these styles can be added to xyplot region);
- polar;
- pie.
All these graphs are described in the book from Jack Xu: Practical C# Charts and Graphics.
I need more time to port all of them to SMath Studio.
Now I found a way to save region settings automatically (without built in serialization). I hope that I will be able to use it in the general case. I have to change the format of saving the xyplot region settings to extend it.
You can open old versions of documents, but older versions of SMath Studio will not be able to display new documents correctly.
How do you look at such changes or what do you think about it?
Edited by user 08 August 2018 07:08:51(UTC)  | Reason: Not specified
Russia ☭ forever
on 08/08/2018(UTC),  on 08/08/2018(UTC)
Offline uni
#294 Posted : 08 August 2018 07:39:18(UTC)
uni
Updated. You can use simplified form to define implicit 2D plot (t or x used as first variable, for the second you can use any variable).
Russia ☭ forever
on 08/08/2018(UTC),  on 08/08/2018(UTC),  on 08/08/2018(UTC),  on 08/08/2018(UTC)
#295 Posted : 08 August 2018 17:46:58(UTC)
Thanks Uni for working all those stuff.
We still need a 3D matrix style for different usages
but mostly Catmul-Clark 3D splines and mesh.
Offline frapuano
#296 Posted : 08 August 2018 23:50:17(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Uni
my modest opinion is that I see as really positive the implementation of all these features/changes mentioned in your earlier e-mail ; they are really welcome even if new documents will not be displayed in old Smath version .
Franco
Offline manolo
#297 Posted : 12 August 2018 20:53:32(UTC)
manolo
Was thanked: 8 time(s) in 2 post(s)
Uni,
thank you very much for your work on X-Y Plot Region. Clap
I'm plotting measured data visible as symbols and regressions as lines like this:
It is possible to change the behavior of the legend? Entries without names should not be displayed in the legend.
Many thanks, Manolo
#298 Posted : 13 August 2018 02:30:56(UTC)
If you want too look smart for the reader and hide the source,
just identify "N/A: Confidential".
Offline uni
#299 Posted : 13 August 2018 05:52:20(UTC)
uni
Updated. Try now.
Russia ☭ forever
on 13/08/2018(UTC)
Offline manolo
#300 Posted : 13 August 2018 19:33:10(UTC)
manolo
Uni,
thank you for quick response. Plugin works as desired.
de_Energieumwandlungen_Federschwinger.sm (150kb) downloaded 53 time(s).
Manolo
thanks 2 users thanked manolo for this useful post.
on 14/08/2018(UTC),  on 14/08/2018(UTC)
Guest (4)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
