Offline jas0nuk
#1 Posted : 15 March 2009 03:03:14(UTC)
jas0nuk
Rank: Member
Hi
Thank you for an excellent piece of software. Definitely the best Windows Mobile calculator I have found.
However I think I have found a slight issue with imaginary numbers
(-1)^(1/2) should give the answer as i
However it seems to add a small real number to the answer, giving
Code:
(-1)^(1/2) = 6.123*10^{-17} + i
Additionally, squaring i gives
Code:
 i^2 = -1 + 1.2246*10^{-16}*i
which should be -1
Code:
2*i^2=-4+4.8984*10^{-16}*i
should be -4, etc.
Offline Andrey Ivashov
#2 Posted : 16 March 2009 04:23:52(UTC)
Was thanked: 1971 time(s) in 661 post(s)
This is not an issue. This is normal calculation errors of numeric methods. Please, take a look to the picture below:
This hapens because Mathcad, by default, shows all numbers, that less than 10^(-15) as 0. But SMath Studio doesn't do so - that's why you can see proper results in the similar examples... and that's why your finding is not an issue...
Offline jas0nuk
#3 Posted : 16 March 2009 05:03:46(UTC)
jas0nuk
Rank: Member
So, it's a by-product of calculating imaginary numbers numerically.
Thanks for the explanation.
Similar Topics
the issue with imaginary numbers in equations answers (Questions)
by Вуаутвук 26/02/2020 17:15:45(UTC)
