Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
Originally Posted by: uni Updated. Axis general format changed. Hi uni, did you have the chance to test the new update also on Smath Viewer? In case yes, if you could let us know so that users that are currently interested in Viewer compatibility (like me) can update safely. Thanks
This is happening for me when I just increase the power of x in X-Y plot (Win7 64bit). At some higher power, say after 10,11 (it depends on the plot size - larger the plot smaller the power) it just become white and the regions disappear when you click on them. It seems it got stuck. But you can click on the power and reduce it. When you reduce it, regions got back and everything seems to be Ok. Regards, Radovan |
2 users thanked omorr for this useful post.
on 02/08/2018(UTC), on 04/08/2018(UTC)
Originally Posted by: fedeghi Hi uni, did you have the chance to test the new update also on Smath Viewer? In case yes, if you could let us know so that users that are currently interested in Viewer compatibility (like me) can update safely. Thanks Nope, the issue is still here and it is related to Xml serialization used in the plugin. I'm looking for possible fixes. |
Originally Posted by: omorr At some higher power, say after 10,11 (it depends on the plot size - larger the plot smaller the power) it just become white and the regions disappear when you click on them. It seems it got stuck. But you can click on the power and reduce it. When you reduce it, regions got back and everything seems to be Ok. Radovan, this is normal. This is due to errors in drawing. Similar behavior is found in another plugin, but there is a workaround. Quote:This method just handles the case where one or more of the coordinates are outrageous, or GDI+ threw an exception. This method attempts to correct the outrageous coordinates by interpolating them to a point (along the original line) that lies at the edge of the ChartRect so that GDI+ will handle it properly. GDI+ will throw an exception, or just plot the data incorrectly if the coordinates are too large (empirically, this appears to be when the coordinate value is greater than 5,000,000 or less than -5,000,000). Although you typically would not see coordinates like this, if you repeatedly zoom in on a ZedGraphControl, eventually all your points will be way outside the bounds of the plot.
I'll try to workaround the problem in the same way. |
This is a known problem: X_Y fails to accept too large/too small coordinates ranges. And the trick is to set the X, Y ranges before putting the plot argument(s). Too large/too small numbers aren't visible anyway, better manage otherwise.
Originally Posted by: omorr At some higher power, say after 10,11 (it depends on the plot size - larger the plot smaller the power) it just become white and the regions disappear when you click on them. It seems it got stuck. But you can click on the power and reduce it. When you reduce it, regions got back and everything seems to be Ok. Updated. Try now. |
Originally Posted by: uni Originally Posted by: omorr At some higher power, say after 10,11 (it depends on the plot size - larger the plot smaller the power) it just become white and the regions disappear when you click on them. It seems it got stuck. But you can click on the power and reduce it. When you reduce it, regions got back and everything seems to be Ok. Updated. Try now. Thank you uni. It does not stuck anymore. I just thought it might be inconvenient the way it worked before. White area instead of the plot and disappearing regions is not pleasant to see. Regards, Radovan |
Originally Posted by: Davide Carpi Nope, the issue is still here and it is related to Xml serialization used in the plugin. I'm looking for possible fixes. Fix committed to the SVN server. Error messages about missing LINQ and XmlSerializer assemblies shouldn't be a problem anymore. P.S. Before changes applies plugin must be recompiled and published again by
amyuniyal
Edited by user 04 August 2018 10:34:27(UTC)
Updated again. Smath Viewer supported. |
on 03/08/2018(UTC), on 04/08/2018(UTC), on 04/08/2018(UTC)
Originally Posted by: ndtma Is it possible to plot text at a specified coordinate in X-Y Plot Region or ZedGraph Plot? Updated. Text labels added. Edited by user 03 August 2018 06:35:35(UTC)
5 users thanked uni for this useful post.
on 03/08/2018(UTC), on 03/08/2018(UTC), on 03/08/2018(UTC), on 04/08/2018(UTC), on 04/08/2018(UTC)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Thank you uni. Its amazing and very useful. |
Following 2 issues noted with new update today. 1. Only integer values for x & y coordinates effective. Text Lables disappear when decimal values are used. 2. Changes in formatting of lines to spline not saved when worksheet is re-loaded. |
Updated. Try now. Trace settings can also be used with text labels (in mixed mode). The text label settings are used if specified, otherwise the trace settings are used. Edited by user 03 August 2018 17:17:29(UTC)
Originally Posted by: uni Updated. Try now.
While you are in the plot design, is there any chance to improve Quick plot ? Damned hard to leave with so many useless decimals. Obviously, it concerns x_axis as well
This request is not for me. I'm not a SMath Studio developer. Additional features to the program should be specified in Feature Requests Forum. |
Trace settings can also be used with text labels (in mixed mode). The text label settings are used if specified, otherwise the trace settings are used. Thanks. It works fine now. |
4 users thanked uni for this useful post.
on 04/08/2018(UTC), on 04/08/2018(UTC), on 04/08/2018(UTC), on 04/08/2018(UTC)
Thanks uni for adding shapes also. It is useful. |
This is experimental. Maybe I'll add a line type, arc shape and something else. |
