2 Pages12>
Offline uni
#1 Posted : 21 July 2018 20:52:47(UTC)
uni
Was thanked: 1259 time(s) in 734 post(s)
SADEL
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Functions list: manzhuk(5|6|7)
DAE (ODE) solvers:
manzhuk(init, x1, x2, intvls, D)
Arguments:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
manzhuk(init, x1, x2, intvls, G, J1)
manzhuk(init, x1, x2, intvls, G, J1, J2)
manzhuk. Kinetic curves.sm (14kb) downloaded 65 time(s).
manzhuk. Van der Pol oscillator 1.sm (11kb) downloaded 57 time(s).
manzhuk. Van der Pol oscillator 2.sm (14kb) downloaded 49 time(s).
manzhuk. Lorenz-Attractor.sm (17kb) downloaded 50 time(s).
manzhuk. Kinetic curves.pdf (39kb) downloaded 48 time(s).
manzhuk. Van der Pol oscillator 1.pdf (47kb) downloaded 39 time(s).
manzhuk. Van der Pol oscillator 2.pdf (63kb) downloaded 41 time(s).
manzhuk. Lorenz-Attractor.pdf (66kb) downloaded 42 time(s).
Manual (rus): DAE-solver-manzhuk.pdf (3,499kb) downloaded 72 time(s).
Links:
1. SADEL.
Edited by user 15 August 2019 13:57:03(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 5 users thanked uni for this useful post.
on 21/07/2018(UTC),  on 21/07/2018(UTC),  on 21/07/2018(UTC),  on 23/07/2018(UTC),  on 07/12/2018(UTC)
Offline uni
#2 Posted : 22 July 2018 02:00:49(UTC)
uni
Updated. Short form added.
manzhuk. Kinetic curves (short).sm (12kb) downloaded 48 time(s).
manzhuk. Lorenz-Attractor (short).sm (16kb) downloaded 41 time(s).
manzhuk. Van der Pol oscillator 1 (short).sm (10kb) downloaded 39 time(s).
manzhuk. Van der Pol oscillator 2 (short).sm (13kb) downloaded 38 time(s).
manzhuk. Arenstorf Orbit (short).sm (17kb) downloaded 47 time(s).
manzhuk. Kinetic curves (short).pdf (38kb) downloaded 34 time(s).
manzhuk. Lorenz-Attractor (short).pdf (64kb) downloaded 33 time(s).
manzhuk. Van der Pol oscillator 1 (short).pdf (46kb) downloaded 33 time(s).
manzhuk. Van der Pol oscillator 2 (short).pdf (62kb) downloaded 33 time(s).
manzhuk. Arenstorf Orbit (short).pdf (56kb) downloaded 35 time(s).
Edited by user 22 July 2018 02:49:39(UTC)  | Reason: Not specified
Russia ☭ forever
on 22/07/2018(UTC),  on 22/07/2018(UTC)
Offline uni
#3 Posted : 22 July 2018 19:21:16(UTC)
uni
Updated. manzhuk() now more stable. Don't use hmx parameter. By default, its value is dt / 2.
Russia ☭ forever
on 22/07/2018(UTC)
#4 Posted : 23 July 2018 02:41:12(UTC)
Was thanked: 975 time(s) in 803 post(s)
Thanks Uni.
The complete Smath code might be educative.
mwode45 solves as well.
ODE manzhuk Arenstorf Orbit.sm (22kb) downloaded 53 time(s).
#5 Posted : 23 July 2018 04:16:45(UTC)
Circular/elliptic orbits.
ODE rkfixed Orbit.sm (42kb) downloaded 50 time(s).
Offline omorr
#6 Posted : 23 July 2018 09:23:04(UTC)
omorr
Serbia
Hello uni,
It seems this is a quite interesting ODE-DAE solver. I did not understand what the matrices J1 and J2 are. The manual is quite complicated for me. I just supposed that J1,J2 have something to do with DAE (differential algebraic equations). It seems to me that J1 is the Jacobian matrix regarding the vector of parameters (third argument in the function G()). I suppose J2 is again some kind of Jacobian matrix.
If one of your motivation was to have a DAE solver in SMath, I appreciate that very much.
Looking forward for some more examples from you about using this solver - especially DAE systems.
Offline uni
#7 Posted : 23 July 2018 11:55:52(UTC)
uni
I'll add the examples later.
Edited by user 23 July 2018 16:43:25(UTC)  | Reason: Not specified
Russia ☭ forever
on 23/07/2018(UTC),  on 23/07/2018(UTC),  on 23/07/2018(UTC)
#8 Posted : 23 July 2018 16:58:21(UTC)
DAE are each specific, I don't think a generalized solver can be designed,
only for odd examples ... I may be wrong , and wish the best.
Offline uni
#9 Posted : 23 July 2018 17:54:48(UTC)
uni
I have more than 12 examples of how to use it, but, unfortunately, symbolic interpreter slows down the computation of the algorithm. So I decided to show an alternative version of its use, using the Script component. I hope that I will succeed.
Russia ☭ forever
Offline uni
#10 Posted : 01 August 2018 18:10:59(UTC)
uni
Simple test 1.
manzhuk.test1.sm (12kb) downloaded 51 time(s).
manzhuk.test1.pdf (49kb) downloaded 50 time(s).
Edited by user 01 August 2018 19:14:42(UTC)  | Reason: Not specified
Russia ☭ forever
on 01/08/2018(UTC)
Offline uni
#11 Posted : 06 December 2018 22:12:13(UTC)
uni
Updated.
Changes:
- zero point issue partially fixed;
- added support for the simple D(t,x) definition.
Edited by user 06 December 2018 22:24:09(UTC)  | Reason: Not specified
Russia ☭ forever
Offline figa
#12 Posted : 12 March 2020 18:44:42(UTC)
figa
Good afternoon!
I use sadel to calculate the parameters of the transient in the RLC-circuit.
Why doesn't time go by in calculations? file attached model2_sadel_p.sm (26kb) downloaded 33 time(s).
Offline uni
#13 Posted : 12 March 2020 19:43:04(UTC)
uni
Можно посмотреть на описание задачи в изначальной форме?
Russia ☭ forever
Offline figa
#14 Posted : 12 March 2020 19:55:48(UTC)
figa
Схема замещения https://i.imgur.com/9p8FrH3.png
Система дифуров, описывающая процессы, происходящие при разряде https://i.imgur.com/Qf2fE8w.png
Взаимная индуктивность https://i.imgur.com/lRdX1Hp.png
Входные параметры электрической цепи рассчитаны, но сомнений не вызывают
Offline uni
#15 Posted : 13 March 2020 14:00:34(UTC)
uni
Для начала нужно в выражении G(t,x,xp) исправить xp на px. Смущает выражение для второй производной. Кажется, что первая и вторая производные dx/dt должны быть как-то связаны. Я не составлял подобных систем и с ходу не могу сказать что не так. Хорошо бы ещё посмотреть на результат моделирования схемы в специализированной программе, чтобы убедиться, что начальные условия и параметры схемы действительно приводят к какому-то не нулевому результату.
Ещё, мне кажется, что не обязательно использовать библиотеку SADEL для решения этой системы, а можно попробовать использовать любые другие решатели, чтобы избавиться от px-параметра.
Edited by user 13 March 2020 14:04:44(UTC)  | Reason: Not specified
Russia ☭ forever
Offline figa
#16 Posted : 13 March 2020 14:09:48(UTC)
figa
действительно! не заметила. Но конечно это исправление не помогло, программа видимо умнее меня, сама догадалась что имелось ввиду
dx/dt=v, dv/dt=a. Когда составлялась система дифуров вместо второй производной использовалась первая
это хорошая идея, попробую. Просто я опираюсь на источники, где описаны именно такая схема, именно такая система дифуров и именно такие входные параметры. Я пытаюсь пока что просто повторить. Это дает определенную уверенность, что должно работать. Хотя не исключено, что где-то упущена ошибка.
То, что в результатах расчета время не движется - это такая реакция программы на то, что она не может посчитать? Не могу понять о чем это говорит
Offline uni
#17 Posted : 13 March 2020 14:24:49(UTC)
uni
Нужно, чтобы ier был равен нулю, тогда можно делать интерпретации результата. Этого можно достичь, если исправить указанную ошибку и отключить задание минимального шага интегрирования (hmn) или сделать его меньше. Дальше нужно проверить опечатки в системе. Я посмотрю под отладчиком почему время не меняется.
Edited by user 13 March 2020 14:31:53(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#18 Posted : 13 March 2020 14:55:08(UTC)
uni
Можно писать вот так, чтобы было нагляднее, но промежуточные вычисления в этом случае замедлят работу функции.
Russia ☭ forever
Offline figa
#19 Posted : 13 March 2020 16:45:36(UTC)
figa
вы имеете ввиду нагляднее для того, кто пишет/читает функцию? т.е. другая форма записи?
это здорово - я попробовала так написать, так тоже запускается расчет, правда результат тот же плачевный :'(
Offline uni
#20 Posted : 13 March 2020 17:24:51(UTC)
uni
По сути это та же форма записи, так как результат работы функции определяется последним выражением блока программы. Определение переменных из вектора k можно вынести из программного блока на лист, т.к. это константы. Ещё нужно всем выражениям указать численный тип оптимизации в свойствах контекстного меню.
Что касается численного моделирования, то можно попробовать посчитать в Proteus данную схемку. Там только нужно подумать как имитировать ключ.
А что за книжка-то?
Edited by user 13 March 2020 17:27:09(UTC)  | Reason: Not specified
Russia ☭ forever
2 Pages12>
