2 Pages12>
Offline barmin
#1 Posted : 29 June 2018 14:53:06(UTC)
barmin
Poland
I have a question if it's possible to display the string part of a matrix in *.exe file created from a Smath file?
Screenshot of issue
Tried the var2string function, but after changing the string value via exe file, it reads function argument name (a) instead of it's value.
Is there some kind of workaround for this issue?
Offline alyles
#2 Posted : 29 June 2018 16:37:31(UTC)
alyles
It would help if you post the original .sm file.
I'm not exactly sure what you are trying to do. Are you trying to assign a value to a variable name defined in a?
If so you can do something like this: https://en.smath.info/fo...eqautions.aspx#post36117
As far as getting that dynamically created variable name to display on the left as an actual variable name, I'm not sure if that's possible.
Offline barmin
#3 Posted : 29 June 2018 16:42:57(UTC)
barmin
Poland
In smath it's defined as:
a:="sample string"
a="sample string"
And if I change the string, sheet recalculates and shows a value as the new string. I wanted to achieve this functionality in smath viewer in exe file for creating additional info page on my docs, like project name and so on.
Offline alyles
#4 Posted : 29 June 2018 17:27:39(UTC)
alyles
Make sure you hit enter/return key after entering value.
Edit: You may have found a bug. This kind of functionality works great with numeric values but not with strings. I've tried with different optimizations as well to no avail.
I'm not sure it's ever worked. I now SMath Viewer is still a work in progress so feel free to add bug entry.
Edited by user 29 June 2018 17:39:14(UTC)  | Reason: Not specified
Offline CBG
#5 Posted : 29 June 2018 20:33:35(UTC)
CBG
Screenshot of issue
Hello Barmin
The function you are looking for was previously available in previous versions of smath, such as version 5737.
I do not know why they disabled it. Here I put an example in that version.
Test_string_5737.zip (360kb) downloaded 33 time(s).
Carlos
Offline barmin
#6 Posted : 01 July 2018 19:56:27(UTC)
barmin
Poland
Seems it's a bug then. Thanks for info.
Offline mkraska
#7 Posted : 02 July 2018 17:07:17(UTC)
mkraska
Can't reproduce
hallo.sm (3kb) downloaded 34 time(s).
hallo.zip (483kb) downloaded 28 time(s).
Offline alyles
#8 Posted : 02 July 2018 17:11:51(UTC)
alyles
Martin,
Once the Viewer is running try to change the value of Hallo and notice if it doesn't update in the second box.
Offline CBG
#9 Posted : 03 July 2018 04:58:56(UTC)
CBG
Offline mkraska
#10 Posted : 03 July 2018 10:58:49(UTC)
mkraska
For me it works. Yet I have to press enter to forward the changes in the input box.
Offline omorr
#11 Posted : 03 July 2018 12:14:27(UTC)
omorr
Serbia
For me it will change the numerical variable but not the string one (with return pressing, of course).
before
after
Offline wb.c
#12 Posted : 05 March 2021 21:38:37(UTC)
wb.c
Was thanked: 22 time(s) in 19 post(s)
So what was the end result of this topic?
Why is the ability to modify text string entries disabled in the viewer?
Offline wb.c
#13 Posted : 12 March 2021 03:34:26(UTC)
wb.c
This issue has now been resolved in the latest update.
Offline CBG
#14 Posted : 12 March 2021 04:55:14(UTC)
CBG
You are right, the text change in the variables still does not work.
Carlos
Offline wb.c
#15 Posted : 12 March 2021 05:00:50(UTC)
wb.c
Please take a look at this topic. You will need the latest nightly build to have functionality.
Offline CBG
#16 Posted : 12 March 2021 20:17:50(UTC)
CBG
I did a test with the latest version of Smath Studio and the Viewer and it does not work
Carlos
Offline Razonar
#17 Posted : 12 March 2021 21:03:32(UTC)
Razonar
Uruguay
Carlos
Hi. Carlos it's right. I guess that there are an issue with the automatic update within the nightly build which seems to be now appVersion(4)="0.99.7739.40423"@# but previously I have appVersion(4)="0.99.7739.41xxx "@# or something like that.
Offline wb.c
#18 Posted : 13 March 2021 04:08:51(UTC)
wb.c
Seems to be working just fine for me.
99.7739.40423_Test_exe.zip (572kb) downloaded 9 time(s).
Good Luck!
Offline wb.c
#19 Posted : 13 March 2021 04:12:22(UTC)
wb.c
I'm using 64bit Win10 Enterprise by the way. Maybe it matters?
thanks 1 user thanked wb.c for this useful post.
on 13/03/2021(UTC)
Offline Razonar
#20 Posted : 13 March 2021 05:29:48(UTC)
Razonar
Uruguay
Me too, but 32 bits. I'm reinstall SMath and now works fine.
Thanks.
2 Pages12>
