SMath Studio Forum
Questions
How to display string element of the matrix in Smath Viewer?
Hello, I have a question if it's possible to display the string part of a matrix in *.exe file created from a Smath file? Screenshot of issueTried the var2string function, but after changing the string value via exe file, it reads function argument name (a) instead of it's value. Is there some kind of workaround for this issue?
Joined: 23/03/2016(UTC) Posts: 275 Was thanked: 91 time(s) in 57 post(s)
It would help if you post the original .sm file. I'm not exactly sure what you are trying to do. Are you trying to assign a value to a variable name defined in a? If so you can do something like this: https://en.smath.info/fo...eqautions.aspx#post36117As far as getting that dynamically created variable name to display on the left as an actual variable name, I'm not sure if that's possible. |
In smath it's defined as:
a:="sample string"
a="sample string"
And if I change the string, sheet recalculates and shows a value as the new string. I wanted to achieve this functionality in smath viewer in exe file for creating additional info page on my docs, like project name and so on.
Make sure you hit enter/return key after entering value. Edit: You may have found a bug. This kind of functionality works great with numeric values but not with strings. I've tried with different optimizations as well to no avail. I'm not sure it's ever worked. I now SMath Viewer is still a work in progress so feel free to add bug entry. Edited by user 29 June 2018 17:39:14(UTC)
Originally Posted by: barmin Hello, I have a question if it's possible to display the string part of a matrix in *.exe file created from a Smath file? Screenshot of issueTried the var2string function, but after changing the string value via exe file, it reads function argument name (a) instead of it's value. Is there some kind of workaround for this issue? Hello Barmin The function you are looking for was previously available in previous versions of smath, such as version 5737. I do not know why they disabled it. Here I put an example in that version. Test_string_5737.zip (360kb) downloaded 33 time(s).Best Regards Carlos
Seems it's a bug then. Thanks for info.
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Martin,
Once the Viewer is running try to change the value of Hallo and notice if it doesn't update in the second box.
For me it works. Yet I have to press enter to forward the changes in the input box. |
For me it will change the numerical variable but not the string one (with return pressing, of course). before after Regards, Radovan |
Joined: 02/04/2018(UTC) Posts: 132 Was thanked: 22 time(s) in 19 post(s)
So what was the end result of this topic?
Why is the ability to modify text string entries disabled in the viewer?
This issue has now been resolved in the latest update.
Quote:This issue has now been resolved in the latest update. You are right, the text change in the variables still does not work. Best Regards Carlos
Please take a look at this topic. You will need the latest nightly build to have functionality.
I did a test with the latest version of Smath Studio and the Viewer and it does not work Best Regards Carlos
Originally Posted by: CBG I did a test with the latest version of Smath Studio and the Viewer and it does not work Best Regards Carlos Hi. Carlos it's right. I guess that there are an issue with the automatic update within the nightly build which seems to be now appVersion(4)="0.99.7739.40423"@# but previously I have appVersion(4)="0.99.7739.41xxx "@# or something like that. Best regards. Alvaro.
I'm using 64bit Win10 Enterprise by the way. Maybe it matters?
1 user thanked wb.c for this useful post.
Originally Posted by: wb.c I'm using 64bit Win10 Enterprise by the way. Maybe it matters? Me too, but 32 bits. I'm reinstall SMath and now works fine. Thanks. Best regards. Alvaro.
SMath Studio Forum
Questions
