Offline CBG
#1 Posted : 21 March 2018 22:01:53(UTC)
CBG
Was thanked: 73 time(s) in 54 post(s)
Will it be possible?
Units_Table.sm (8kb) downloaded 37 time(s).
Carlos
Offline PompelmoTell
#2 Posted : 21 March 2018 22:51:14(UTC)
PompelmoTell
Was thanked: 106 time(s) in 90 post(s)
sets the header and units matrices
on 22/03/2018(UTC)
Offline CBG
#3 Posted : 22 March 2018 02:22:36(UTC)
CBG
Thanks Sergio:
You made me remember the solution that Martin Kraska gave me, but I can not put a header on it.
Do you have any suggestion?
Units_Table_r2.sm (16kb) downloaded 52 time(s).
Carlos
#4 Posted : 22 March 2018 12:35:19(UTC)
PompelmoTell
I thought about this (string manipulation)
but num2strtransforms into fractions
Edited by user 22 March 2018 20:45:08(UTC)  | Reason: conversion error between K and °C
on 22/03/2018(UTC)
#5 Posted : 22 March 2018 19:36:09(UTC)
Was thanked: 915 time(s) in 743 post(s)
I prefer the way we did in 1987, collecting piles of fluids information.
Units_Table Preference.sm (13kb) downloaded 55 time(s).
Offline mkraska
#6 Posted : 22 March 2018 19:44:41(UTC)
mkraska
Was thanked: 968 time(s) in 616 post(s)
Use var2str() from CustomFunctions instead
on 22/03/2018(UTC),  on 22/03/2018(UTC)
Offline CBG
#7 Posted : 23 March 2018 02:21:28(UTC)
CBG
Thank you very much to everyone for your help,
I already managed to make the table as I required it.
Units_Table_r3.sm (10kb) downloaded 52 time(s).
Carlos
thanks 2 users thanked CBG for this useful post.
on 23/03/2018(UTC),  on 23/03/2018(UTC)
#8 Posted : 23 March 2018 05:20:16(UTC)
Thanks Carlos: gorgeous
Offline wb.c
#9 Posted : 27 June 2018 00:32:55(UTC)
wb.c
Was thanked: 16 time(s) in 15 post(s)
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
#10 Posted : 27 June 2018 03:28:04(UTC)
Just define those units.
Offline wb.c
#11 Posted : 27 June 2018 03:49:54(UTC)
wb.c
Jean Giraud,
Maybe try something other than 20 deg?...
Version: 0.99(build: 6671)
#12 Posted : 27 June 2018 05:59:58(UTC)
You are quite right and there are two things here
1. As it looks, the °C can't be made user.
The unit system is grounded on 'K', bloody pest to me.
2. The other thing is the Shadow in context, a real bug.
It worked fine from Carlos original [by what coincidence ?]
Not changing the context, context reproduces. Changing context
and the all thing °C gets freaked. I observed that many times
in Smath. In fact, very problematic.
Thanks for this wise observation.
Table Region Carlos.sm (11kb) downloaded 36 time(s).
