on 26/06/2018(UTC), on 26/06/2018(UTC)
Updated. Y2 axis now looks right. Small improvements. Edited by user 27 June 2018 00:49:29(UTC)
on 27/06/2018(UTC), on 27/06/2018(UTC), on 27/06/2018(UTC)
Updated. Fixed bug when zooming. |
Quote:Pl see the attached. Can't enable outer border (using Tool Pallet). I think it is after the latest update of XYPlot Region plugin. Same with ZedGraph. Yes you are right. I changed the look of the plugins: X-Y PLot, ZedGraph and NPlot. The border and area around the plot now hidden (transparent). This is a new design. Do you really want to return the option of enabling the border? |
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 124 time(s) in 82 post(s)
Thanks uni. Now I know it is by design. IMHO it is alright without borders. |
Originally Posted by: uni Yes you are right. I changed the look of the plugins: X-Y PLot, ZedGraph and NPlot. The border and area around the plot now hidden (transparent). This is a new design. Do you really want to return the option of enabling the border? Good think is does affect 6179. Otherwise, it will make me pest off. The borders allows clean/professional capture for publishing.
It can't be done for this version, Jean. Life goes on, do not get off the train. There are still many stops ahead. |
on 12/07/2018(UTC), on 13/07/2018(UTC)
Updated. Region evaluated with using the last store state when any properties changed. EDIT: Don't use, some bugs present. Edited by user 20 July 2018 13:36:00(UTC)
on 20/07/2018(UTC), on 20/07/2018(UTC)
Updated. Changes: - region evaluated with using the last store state when properties changed ( removed, not stable); - added ability to direct access to axis when double clicking on it; - refactored. |
4 users thanked uni for this useful post.
on 20/07/2018(UTC), on 20/07/2018(UTC), on 20/07/2018(UTC), on 20/07/2018(UTC)
Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
Looks like yesterday update has broken something when using Smath Viewer. Works fine with .sm files, doesn't work with .exe See error message here
Maybe this is because LinqBridge dll now used (since June). I'm not sure, you need to ask Andrey about this problem. He is now busy with a new beta and you will have to wait a while. Edited by user 20 July 2018 20:32:59(UTC)
Ok, understood. Is there a way to rollback to yesterdays version? I'm asking this because this morning I have been working on a file and saving the .exe and running it was working smoothly. This evening I updated the plugin and now it doesn't. So I would be happy to roll back to yesterday, at the moment :P Edited by user 20 July 2018 20:39:40(UTC)
Yes, it is possible. You just need to remove the last copy of plugin from the plugin folder:
C:\Users\User\Application Data\SMath\extensions\plugins\c12231ec-4873-43c1-a7d0-a167ebd17066
You need to remove downloaded folder (0.1.67xx.xxxx) and change the record in .ini file. |
Houston we have a problem. I messed around, don't know exactly how and have corrupted something. I need to reinstall everything from scratch, but when I try to, SMath finds the previously installed plugin again. Any clue on how to remove EVERYTHING and start from scratch? Sorry to bother, so angry with myself. Here below some infos Can't disable version 36185Error message when attempting to create a new XYPLOTConfiguration modifications...Most critical, today work will not open... Edited by user 20 July 2018 22:14:54(UTC)
Try this. 1. Close SMath Studio 2. Remove folder 0.1.6775.30553. Edit ini file: Code:0.1.6732.38438
0
XYPlotRegion.dll
3. Run SMath Studio. |
Originally Posted by: uni Try this. 1. Close SMath Studio 2. Remove folder 0.1.6775.30553. Edit ini file: Code:0.1.6732.38438
0
XYPlotRegion.dll
3. Run SMath Studio. Done, same error messages. Cant' understand why 36185 is still listed in the plugin manager... Where the hell is that version coming from, since we removed its folder? Originally Posted by: fedeghi Can't disable version 36185
Try to save entire c12231ec-4873-43c1-a7d0-a167ebd17066 folder in another place and remove it from \extensions\plugins at all. Restart SMath Studio. Plugin still exists? |
Originally Posted by: uni Try to save entire c12231ec-4873-43c1-a7d0-a167ebd17066 folder in another place and remove it from \extensions\plugins at all. Restart SMath Studio. Plugin still exists? I solved differently, just rolling back something very stupid (an overwrite) I did in C:\Program Files (x86)\SMath Studio\plugins. 1) I un-installed again smath. 2) I noticed that everything was gone except for a XYPlotRegion.dll file which was left there... So I understood how stupidly I moved it when trying to roll back to a previous version "on my own" (so stupid). 3) Deleted that .dll in the wrong folder, installed Smath back again, and I assume that while installing smath loaded back all the plugins as per D:\Users\FGhioni\AppData\Roaming\SMath\extensions\plugins dataset, including the beloved old version of XYPlot Uni I really need to THANK YOU for the support! Awesome software, awesome user community Edited by user 20 July 2018 22:42:25(UTC)
Updated. Axis general format changed. Edited by user 02 August 2018 05:33:51(UTC)
on 02/08/2018(UTC), on 02/08/2018(UTC)
