2 Pages12>
Offline Ryu945
#1 Posted : 11 May 2018 02:23:24(UTC)
Ryu945
How do I integrate symbolically?
Edited by user 11 May 2018 02:27:47(UTC)  | Reason: Not specified
#2 Posted : 11 May 2018 03:54:23(UTC)
Originally Posted by: Ryu945 Go to Quoted Post
How do I integrate symbolically ?
Generally, like this.
on 12/05/2018(UTC)
#3 Posted : 11 May 2018 04:35:04(UTC)
... more procedures.
Integrate_000000 [ Source Code Maple].sm (10kb) downloaded 242 time(s).
Offline Ryu945
#4 Posted : 11 May 2018 06:03:19(UTC)
Ryu945
For reference, I just installed SMath. I installed maple. Where is the integrate sign located in the program?
Edited by user 11 May 2018 08:16:10(UTC)  | Reason: Not specified
#5 Posted : 11 May 2018 06:15:35(UTC)
Wolfram Alpha integrator:
http://integrals.wolfram.com/index.jsp?expr=1%2F%28x%5E2%2B1%29&random=false
Offline Ryu945
#6 Posted : 11 May 2018 08:24:05(UTC)
Ryu945
What are you trying to say?
#7 Posted : 11 May 2018 14:17:25(UTC)
1. Visit Wolfram Alpha for ultimate accuracy definite integral
2. Reproduce my first reply for indefinite integral .
3. Open the two attachments
4. Click on Smath menu to get the palette of stuff.
#8 Posted : 11 May 2018 14:22:03(UTC)
http://www.wolframalpha.com/input/?i=integrate+x%5E(0.5-1)*exp(-x)+from+0+to+0.1
#9 Posted : 11 May 2018 14:37:42(UTC)
#10 Posted : 11 May 2018 14:41:26(UTC)
From the last reply:
1. click on the image, copy
2. paste in Smath
3. DIY [Do It Yourself]
Offline alyles
#11 Posted : 11 May 2018 15:32:38(UTC)
alyles
Hi Ryu
Welcome to the forums. Jean's first post outlined a how to create the indefinite integral, although it might not have been clear.
For example, to create the integral for x^2, you can type "int(x^2,x)" without quotes.
I do not believe there is a toolbar button for the indefinite integral.
-alyles
#12 Posted : 11 May 2018 16:44:39(UTC)
There was no palette indefinite integral in Smath 5346,
but from recollection, there was from f(x) menu.
Not reinstalled in 6179 ...
Offline Ryu945
#13 Posted : 11 May 2018 17:04:21(UTC)
Ryu945
Thankyou. int( x^2,x) was what I was looking for (and I see now what that first picture was suppose to be /headdesk). I tried the example mentioned above with maple installed but I don't see the answer like I saw above. I see this instead.
Edited by user 11 May 2018 17:14:41(UTC)  | Reason: Not specified
Offline alyles
#14 Posted : 11 May 2018 17:49:59(UTC)
alyles
Try right click and change optimization to symbolic.
Also you can use symbolic evaluation by hitting Ctrl + . (That is Ctrl and period) instead of =
#15 Posted : 11 May 2018 18:13:30(UTC)
Copy the image, paste in blank work sheet ... try to do it yourself.
Try hard !!! rescue yourself by downloading the work sheet.
It should work in your latest Smath version.
Integrate Wisely [Arc Maple].sm (9kb) downloaded 87 time(s).
#16 Posted : 11 May 2018 18:43:56(UTC)
... be productive to integrate, try it.
#17 Posted : 11 May 2018 19:44:31(UTC)
... this attached example is of prime importance.
It shows by how much the Simpson integrator can be OFF track !
Not even the first decimal is true !
Integrate Wisely [Arc Lagrange].sm (45kb) downloaded 88 time(s).
Offline Ryu945
#18 Posted : 11 May 2018 20:26:13(UTC)
Ryu945
Thankyou for all of your assistance.
Offline ElSid
#19 Posted : 11 May 2018 20:40:36(UTC)
ElSid
Jean,
Your overloading Ryu945. This appears to be his first experience with this type of software. Slow down and teach/explain. Notice the way alyles responded.
Welcome to the forum Ryu945. Play with the software, look at the Wiki, search the forums. When in doubt, ask. Don't be surprised if someone responds to a link from several years back ... thus, search the forum first.
as you progress and have specific questions, please post/attach your sheet like Jean did. This will allow others to help without having to redo or guess your work. Also, there is one function that I recommend you add to all of your sheets, appversion(). In particular, appversion(3) and appversion(-3). This tells us what version you are currently working in and what version the sheet was last saved in. Not common, but over the years, some updates have broken older sheets.
thanks 1 user thanked ElSid for this useful post.
on 12/05/2018(UTC)
Offline mkraska
#20 Posted : 13 May 2018 17:35:29(UTC)
mkraska
You can use the free computer algebra system (CAS) Maxima from within SMath Studio.
See the Maxima forum topic. There is also a pre-configured portable SMath-Distribution, see link in my signature.
The german Handbuch has a lot of material on using the Maxima interface. Besides doing symbolic math it also gives many examples on how to use Maxima based graphics functions.
on 13/05/2018(UTC),  on 16/05/2018(UTC)
Guest (2)
2 Pages12>
