SMath Studio Forum
Questions
How do I integrate Symbolically?
How do I integrate symbolically? Edited by user 11 May 2018 02:27:47(UTC)
| Reason: Not specified
Originally Posted by: Ryu945 How do I integrate symbolically ? Generally, like this.
For reference, I just installed SMath. I installed maple. Where is the integrate sign located in the program? Edited by user 11 May 2018 08:16:10(UTC)
What are you trying to say?
Originally Posted by: Ryu945 What are you trying to say? 1. Visit Wolfram Alpha for ultimate accuracy definite integral 2. Reproduce my first reply for indefinite integral . 3. Open the two attachments 4. Click on Smath menu to get the palette of stuff.
Originally Posted by: Ryu945 What are you trying to say? From the last reply: 1. click on the image, copy 2. paste in Smath 3. DIY [Do It Yourself]
Joined: 23/03/2016(UTC) Posts: 275 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: Ryu945 Where is the integrate sign located in the program? Hi Ryu Welcome to the forums. Jean's first post outlined a how to create the indefinite integral, although it might not have been clear. For example, to create the integral for x^2, you can type "int(x^2,x)" without quotes. I do not believe there is a toolbar button for the indefinite integral. -alyles |
Originally Posted by: alyles I do not believe there is a toolbar button for the indefinite integral There was no palette indefinite integral in Smath 5346, but from recollection, there was from f(x) menu. Not reinstalled in 6179 ...
Thankyou. int( x^2,x) was what I was looking for (and I see now what that first picture was suppose to be /headdesk). I tried the example mentioned above with maple installed but I don't see the answer like I saw above. I see this instead. Edited by user 11 May 2018 17:14:41(UTC)
Try right click and change optimization to symbolic.
Also you can use symbolic evaluation by hitting Ctrl + . (That is Ctrl and period) instead of = |
Originally Posted by: Ryu945 Thankyou. int( x^2,x) was what I was looking for Copy the image, paste in blank work sheet ... try to do it yourself. Try hard !!! rescue yourself by downloading the work sheet. It should work in your latest Smath version. Integrate Wisely [Arc Maple].sm (9kb) downloaded 86 time(s).
... be productive to integrate, try it.
... this attached example is of prime importance. It shows by how much the Simpson integrator can be OFF track ! Not even the first decimal is true ! Integrate Wisely [Arc Lagrange].sm (45kb) downloaded 88 time(s).
Thankyou for all of your assistance.
Jean, Your overloading Ryu945. This appears to be his first experience with this type of software. Slow down and teach/explain. Notice the way alyles responded.
Welcome to the forum Ryu945. Play with the software, look at the Wiki, search the forums. When in doubt, ask. Don't be surprised if someone responds to a link from several years back ... thus, search the forum first. as you progress and have specific questions, please post/attach your sheet like Jean did. This will allow others to help without having to redo or guess your work. Also, there is one function that I recommend you add to all of your sheets, appversion(). In particular, appversion(3) and appversion(-3). This tells us what version you are currently working in and what version the sheet was last saved in. Not common, but over the years, some updates have broken older sheets.
1 user thanked ElSid for this useful post.
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Originally Posted by: Ryu945 How do I integrate symbolically? You can use the free computer algebra system (CAS) Maxima from within SMath Studio. See the Maxima forum topic. There is also a pre-configured portable SMath-Distribution, see link in my signature. The german Handbuch has a lot of material on using the Maxima interface. Besides doing symbolic math it also gives many examples on how to use Maxima based graphics functions. |
2 users thanked mkraska for this useful post.
on 13/05/2018(UTC), on 16/05/2018(UTC)
SMath Studio Forum
Questions
