2 Pages12>
Offline Andrey Ivashov
#1 Posted : 06 April 2018 00:40:39(UTC)
SMath Studio - SMath
Created by SMath LLC in the scope of SMath project. Published by smath.
SMath Studio box
It's perfect alternative to Mathcad. The solution to make another namespace for measure units - is genious! more...
by Sergey Grunenko
If you are thinking about getting MathCAD for your business or personal use you may want to try SMath Studio first. SMath Studio is a free math program with easy to use intuitive "paper-like" interface. If SMath Studio meets your needs then look no further and consider donating to promote further development of this great program. On the SMath Studio forum, the developer and forum community are very receptive to help questions, bug reports, and feature requests. more...
by j_kris
Probably the best free math program out there. As an electrical engineer, you can do so many calculations, e.g for designig drive systems and calculate protection settings, can be almost entirely automated using SMath Studio. With the huge amount of plugins you can push SMath in an high level. Thanks a lot! more...
by Karsten
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
Edited by user 07 April 2018 21:47:25(UTC)  | Reason: Not specified
thanks 9 users thanked Andrey Ivashov for this useful post.
on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 06/04/2018(UTC),  on 07/04/2018(UTC),  on 10/04/2018(UTC)
Offline ElSid
#2 Posted : 06 April 2018 01:18:35(UTC)
ElSid
Thank you Andrey.
I have a few questions
  1. Can a snippet be nested? I have a function "snippet" that relies on another snippet. This file is an example and I want to reference only this snippet function which will embed the other snippet function
  2. Do Snippets need to be saved as SM? I had an issue with my SMZ files which I default to saving everything out of habit. I have not tried this version
  3. Equation wrap does not work on exponents. I know this feature is a work in progress. I even posted a work around
Split not work exponent.sm (15kb) downloaded 44 time(s).
#3 Posted : 06 April 2018 03:58:14(UTC)
Sorry for answering a personalized question.
Doctored AFAIU.
Offline ElSid
#4 Posted : 06 April 2018 07:24:17(UTC)
ElSid
Andrey,
User error on the Snippet. Because snippets are static, you can embed one Snippet that calls on another Snippet. I thought it was more of a reference like rfile. I like to go back and update documentation/clarifications as time goes by.
Jean,
The sheet I posted is the second half "liquid" equation, per ASHRAE, to calculate the water vapor pressure. It's parabolic and the numbers are within calculation error due to the coefficients being converted from SI to IP. Disclaimer is in the 2017 ASHRAE Handbook. The sample values that I ran, I was within 0.002 psi of most values published in the handbook ... well within engineering tolerances
#5 Posted : 06 April 2018 07:58:13(UTC)
What's that second half liquid equation ?, I must have missed something in so many years.
My point [previous reply] was to use Sigma instead of Gyzma.
Inst_Water bar Saturation [tdegC].sm (52kb) downloaded 46 time(s).
Offline ElSid
#6 Posted : 06 April 2018 17:48:35(UTC)
ElSid
Andrey,
Has this been figured out or do I need to add it to the wish list?
Postfix operator (dB scale in my case)
I was trying to transcribe some old MathCAD sound calculations
#7 Posted : 06 April 2018 18:00:54(UTC)
Andrey,
I've missed this thread. Please add it to https://smath.info/bts/ - it is easier for me to manage requests there.
Thanks in advance!
Offline ElSid
#8 Posted : 06 April 2018 22:16:28(UTC)
ElSid
Posted SS-3532.
FYI, There appears to be a bug in the forum software as I could not post a hyperlink to the forum page. The URL pop-up came up and it would then lock up my web browser (IE and Firefox). Clicking OK or Cancel did nothing
Offline tomracing
#9 Posted : 07 April 2018 00:08:10(UTC)
tomracing
Rank: Member
Netherlands
Was thanked: 7 time(s) in 4 post(s)
Unfortunatly 0_99_6670 has an issue to start for me on linux, something about the printer seems to be required.
Hopefully you can make some of this terminal message i get and fix it eventually.
Quote:
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
(mono:960): Gtk-WARNING **: 22:55:52.067: Unable to locate theme engine in module_path: "adwaita",
(mono:960): Gtk-WARNING **: 22:55:52.086: Unable to locate theme engine in module_path: "adwaita",
Unhandled Exception:
System.Drawing.Printing.InvalidPrinterException: No printers are installed.
at System.Drawing.Printing.PageSettings.get_PaperSize () [0x00018] in <020b17b0944a400f98b947de862cf1c4>:0
at SMath.Manager.AppSettings.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) [0x00013] in <357f5ddcf7854e8d98f4122101e9db1b>:0
at .. (System.String[] ) [0x00059] in <2824d45d6dcf4ff891701e290e7054bb>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Drawing.Printing.InvalidPrinterException: No printers are installed.
thanks 1 user thanked tomracing for this useful post.
on 07/04/2018(UTC)
#10 Posted : 07 April 2018 00:31:11(UTC)
Do you have any printer installed? Can you try to install a virtual one (if it is possible on Linux)?
Offline 3rav
#11 Posted : 07 April 2018 11:01:06(UTC)
3rav
I have problem with new version (6670).
Assigning a variable value with the appropriate unit before the "for" loop causes an error, where the older version (6622) worked correctly.
example.sm (6kb) downloaded 55 time(s). - example
My exaple in old wersion
My example in new version
Rafal
#12 Posted : 07 April 2018 12:45:31(UTC)
Hello, Rafal.
This is by design. In the example you are trying to set element of scalar by index. This is an error. In previous versions of SMath Studio program just lost value of the scalar, which was wrong.
You have three options here:
1) Remove σ:=100*MPa line at all (actually it gave nothing to you in previous versions of SMath Studio as well);
1) Add Clear(σ)=... before the for loop;
2) Use another name for σ variable.
Edited by user 07 April 2018 12:50:48(UTC)  | Reason: Not specified
on 07/04/2018(UTC)
Offline mkraska
#13 Posted : 07 April 2018 13:05:16(UTC)
mkraska
Was thanked: 1120 time(s) in 718 post(s)
The change was introduced because issuing an error message was preferred over the danger of silently doing unintended things (SS 3525)
The real problem is in the useless error message "cannot calculate". It is misleading, as not the calculation does fail but the assignment by index to an existing scalar.
A message like "element assignment is only possible for empty or matrix objects" would help. I am not aware of other situations where such an assignment might fail, thus this message could be used by default in failing element assignments.
on 07/04/2018(UTC),  on 07/04/2018(UTC)
#14 Posted : 07 April 2018 21:50:12(UTC)
Topic updated with corrected build 6671. Fixed critical issue for environment without default printer installed and/or OS version less then Windows 7. SMath Studio in the Cloud updated and restored.
Sorry for inconvenience!
Best regards, Andrey Ivashov.
on 07/04/2018(UTC),  on 07/04/2018(UTC),  on 07/04/2018(UTC),  on 08/04/2018(UTC)
Offline tomracing
#15 Posted : 08 April 2018 21:10:01(UTC)
tomracing
Rank: Member
Netherlands
In regards to the previous error, i've tried installing cups with a pdf but haven't completed it yet.
anyway 6671 gives an even larger exception notification
System.TypeInitializationException: The type initializer for 'System.Console' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.ConsoleDriver' threw an exception. ---> System.Exception: Magic number is wrong: 542
at System.TermInfoReader.ReadHeader (System.Byte[] buffer, System.Int32& position) [0x00028] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.TermInfoReader..ctor (System.String term, System.String filename) [0x0005f] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.TermInfoDriver..ctor (System.String term) [0x00055] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.ConsoleDriver.CreateTermInfoDriver (System.String term) [0x00000] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.ConsoleDriver..cctor () [0x0004d] in <2dfe84a36ef4410ca18642993b51b799>:0
--- End of inner exception stack trace ---
at System.Console.SetupStreams (System.Text.Encoding inputEncoding, System.Text.Encoding outputEncoding) [0x00007] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Console..cctor () [0x0008e] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Windows.Forms.XplatUIX11.HandleError (System.IntPtr display, System.Windows.Forms.XErrorEvent& error_event) [0x0009a] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at (wrapper managed-to-native) System.Windows.Forms.XplatUIX11.XPending(intptr)
at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue, System.Boolean allowIdle) [0x00166] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue) [0x00000] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.XplatUIX11.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr handle, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x0001c] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.XplatUI.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.Application.RunLoop (System.Boolean Modal, System.Windows.Forms.ApplicationContext context) [0x00331] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext context) [0x00011] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at System.Windows.Forms.Application.Run (System.Windows.Forms.Form mainForm) [0x00006] in <620961265dcd4ef2bef9e70169cb6e5a>:0
at .. () [0x0000a] in <2b5e52884bc94eee85ddd10306fe74aa>:0
at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) [0x00014] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00071] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00000] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) [0x0002b] in <2dfe84a36ef4410ca18642993b51b799>:0
at System.Threading.ThreadHelper.ThreadStart () [0x00008] in <2dfe84a36ef4410ca18642993b51b799>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Console' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.ConsoleDriver' threw an exception. ---> System.Exception: Magic number is wrong: 542
#16 Posted : 08 April 2018 22:47:24(UTC)
It looks like this is a Mono issue fixed several days ago. Please see here for a workaround: https://github.com/mono/mono/issues/6752
on 09/04/2018(UTC)
#17 Posted : 09 April 2018 01:48:24(UTC)
"element assignment is only possible for empty or matrix objects" ... I like it
"can not calculate" is much more real because there is nothing to calculate.
If some wish list would ask for Mathematica style zillions error messages,
that will not replace reading the Smath Handbook.
"for loop can not index a constant"
"not a scalar assignment" [typical Mathcad style]
As it looks, the matter was to replicate a value.
Offline tomracing
#18 Posted : 09 April 2018 21:50:28(UTC)
tomracing
Rank: Member
Netherlands
thanks! indeed xterm solved it and also the application link in menu opens smath without issues.
Offline ElSid
#19 Posted : 11 April 2018 04:44:44(UTC)
ElSid
Andrey,
Last plugin issue was fixed with this AppVersion 0.99.6671. I am now wondering if this caused an issue with the X-Y plugin. I posted a bug report there, but wanted to bring this to your attention
UPDATE: Plugin opens fine on 0.99.6661 portable version
Edited by user 11 April 2018 05:20:03(UTC)  | Reason: Not specified
#20 Posted : 11 April 2018 21:15:01(UTC)
Can't reproduce this issue. Dialog opens correctly for me.
UPDATE: I see you found a reason and described it here: https://en.smath.info/fo...e-program.aspx#post47855
Not an issue of SMath Studio. Thanks.
2 Pages12>
