6 Pages«<23456>
Offline CBG
#61 Posted : 16 December 2017 04:41:33(UTC)
CBG
Why units are duplicate in Table Region?
units (1).sm (22kb) downloaded 62 time(s).
Carlos
#62 Posted : 17 December 2017 14:39:26(UTC)
Was thanked: 1323 time(s) in 873 post(s)
It's a bug Good
thank you for reporting, I'll fix it ASAP.
Offline CBG
#63 Posted : 19 December 2017 07:39:06(UTC)
CBG
Thank you very much for your reply.
Carlos
Offline MarB
#64 Posted : 31 January 2018 17:42:58(UTC)
MarB
Hi Davide,
the values "Resizing/Limits on data size changes" are not stored between sessions (close/reopen SMath).
with SMath: "0.98.6484"
#65 Posted : 01 February 2018 18:49:54(UTC)
Originally Posted by: MarB Go to Quoted Post
Hi Davide,
I cannot reproduce. Do you have checked the "set as default" checkbox and then clicked on the "ok" button?
Offline PompelmoTell
#66 Posted : 22 March 2018 20:51:56(UTC)
PompelmoTell
Davide,
I have identified an abnormal behavior using the comma as a decimal point
#67 Posted : 22 March 2018 21:00:35(UTC)
Originally Posted by: PompelmoTell Go to Quoted Post
Davide,
Yes, this comes from a conflict in behaviors...var2str() was thinked to be used in plots as main target, hence preserving the localisation options... table region symbolic strings needs a standard input (period as decimal separator)
Edited by user 22 March 2018 21:02:34(UTC)  | Reason: Not specified
on 22/03/2018(UTC),  on 22/03/2018(UTC)
Offline wb.c
#68 Posted : 02 April 2018 18:48:15(UTC)
wb.c
Was thanked: 22 time(s) in 19 post(s)
Thanks for the work with this plugin, it has proven to be a very useful and much needed feature.
I am however having one small issue. My table displays fine within SMath, but when I print, depending on how many characters there are, the table cuts off.
This is only when I print.
Is there something in the settings I am missing?
All settings are default in the attached example.
Thank you!
#69 Posted : 03 April 2018 12:11:41(UTC)
Thank you!
Confirmed. Unfortunately string scaling is driven internally by the .NET framework (here the ssue is how letters are spaced), so there aren't easy fixes. I'll think if I can do something however, thank you for reporting.
#70 Posted : 03 April 2018 13:39:04(UTC)
PompelmoTell
I have seen that by adding some final spaces the string becomes completely visible. It is not a solution but can be used in some cases.
Even the formatted label has a similar behavior but in that case the string wraps.
thanks 2 users thanked PompelmoTell for this useful post.
on 04/04/2018(UTC),  on 06/04/2018(UTC)
Offline wb.c
#71 Posted : 05 April 2018 18:27:51(UTC)
wb.c
PompelmoTell - Yes, I did figure this "fix" out as well. Depending on the length of the original string, more spaces need to be added to the end. Not the best of solutions given that I am working with large amounts of data of varying length.
What is confusing to me, is that if the string is longer, it will print more of it, but also remove more characters at the end. if the string is shorter, it removes less characters but the end result is a shorter string than the previously mentioned. There doesn't seem to be be a fixed length when printing and it depends on the original length.
Lets hope the champion Davide Carpi has a solution to this!
Offline wb.c
#72 Posted : 09 June 2018 03:14:24(UTC)
wb.c
Davide,
Any news on a permanent fix for the string length cut off on the table region mentioned above?
Thanks!
Offline ndtma
#73 Posted : 25 June 2018 17:57:08(UTC)
ndtma
Sri Lanka
Was thanked: 124 time(s) in 82 post(s)
I observe a peculiar behavior when "Temp" is changed from 20 Celsius to, say, 40 Celsius.
See how the table value responds when input "Temp" is changed to 40 Celsius.
Where have I gone wrong? Apparently, this happens only with Temp units (needs further checks).
Units_Table_r2 (1).sm (18kb) downloaded 47 time(s).
Edited by user 25 June 2018 18:20:49(UTC)  | Reason: Further checks
Offline alyles
#74 Posted : 25 June 2018 18:54:50(UTC)
alyles
This seems to be related to offset between Celsius and Kelvin.
I can produce the correct output (with incorrect input) by changing units of Temp to Δ°C OR by changing value in Table1 to Temp-273.15K.
Note that by setting the units in the un column to 1 from °C, the temperature is shown in Kelvin as the first table in the .sm.
Somehow the conversion from K to °C is not being performed properly within table region.
Edited by user 25 June 2018 18:58:28(UTC)  | Reason: Not specified
#75 Posted : 26 June 2018 01:01:35(UTC)
Originally Posted by: ndtma Go to Quoted Post
Where have I gone wrong ?
Not easy to get Table that makes sense ... kind of pest !
Table Region [Project].sm (8kb) downloaded 39 time(s).
#76 Posted : 26 June 2018 01:19:12(UTC)
Offline wb.c
#77 Posted : 26 June 2018 01:42:28(UTC)
wb.c
alyles,
The way the unit summary matrix works is that it actually does a unit conversion as seen in the image below.
the "in" unit shown in the un matrix is converted to the default unit in the same way the "a" and "b" variables are. Then the un matrix divides the T matrix to cancel out the units and display the values in the units chosen in the un matrix.
In the image shown below, the 6in are converted to 0.5ft when placed into the table, then the cm unit in the un matrix is converted to 0.0328ft and divides the 0.5ft value, making it 15.24 as shown.
Note that the unit summary matrix is not being displayed. They will not display as entered into the unit summary matrix because they are converted to the default unit as explained prior.
If you want the units to display, you will need to add a right stub with the units as "S:'unit" as shown before.
It would appear that there is something wrong with the conversion being made for temperature.
Offline wb.c
#78 Posted : 26 June 2018 02:33:04(UTC)
wb.c
ndtma,
To answer your question as to where you went wrong. Well, you didn't go wrong. The issue, I believe (I may be wrong), is that the way the "unit summary" matrix is designed to work, it assumes that the conversion can be made with a multiplying factor, but since the temperature scales do not share the same zero, there is no factor to multiply for the conversion in some cases.
I think what it comes down to is a matter of how the conversions actually happen. This goes for any portion of Smath Studio. See below. From Celsius to Fahrenheit, Smath won't make the conversion unless there is an actual number in front of it. Similarly, from Celsius to Kelvin, without the number in front of the unit the conversion is broken.
From Kelvin to Fahrenheit oddly enough, the conversion seems to work. I'm not sure how these are set up within Smath.. but there you have it. Food for thought I guess.
#79 Posted : 26 June 2018 04:47:30(UTC)
What's wrong missing post 76 "Project"
Another style table few day ago.
Offline Santa401
#80 Posted : 09 September 2018 16:08:58(UTC)
Santa401
Rank: Member
United Kingdom
Was thanked: 3 time(s) in 2 post(s)
I tried to install the plugin but got an error message. Now the plugin cannot be disabled or removed?
Is there a problem or have I done / not done something?
Kriss
Similar Topics
Table Region Problem (Questions)
by ndtma 27/08/2023 11:58:19(UTC)
[Table Region] Caption Font Size Problem with Windpws Display Scale (Bugs & Problems)
by ndtma 09/01/2022 20:02:03(UTC)
Text formatting single cell in table region (Questions)
by wb.c 15/09/2021 22:14:25(UTC)
Table Region PlugIn (Questions)
by MBernacca 29/01/2020 13:42:47(UTC)
"Table Region" Plug-in installation failed (Questions)
by aviateCar 02/07/2019 23:30:54(UTC)
Table Region Font Bug at Font Scale %125 (Bugs & Problems)
by overlord 16/03/2019 23:00:46(UTC)
Show the Orignal Units in Table Region (Questions)
by CBG 21/03/2018 22:01:53(UTC)
by CBG 07/03/2018 20:21:01(UTC)
Table Region Units (Extensions)
by CBG 16/12/2017 04:41:33(UTC)
Table Region Model (Samples)
by Jean Giraud 07/06/2017 18:19:06(UTC)
6 Pages«<23456>
