29 Pages«<910111213>»
Offline uni
#201 Posted : 17 March 2018 07:10:33(UTC)
uni
Was thanked: 1306 time(s) in 765 post(s)
Quote:
I just downloaded 0.99 and it didn't work out.
Tell me more about what's wrong.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Gecko
#202 Posted : 19 March 2018 15:14:00(UTC)
Gecko
Hi Uni,
I downloaded your zip file, then copied the two dll files into the plugin folder of smath. When I then start smath I get an error message saying "The remote server returned an error: (407) Proxy Authentication Required".
Sorry I am a newbee. I am not familiar with the procedure for installing plugins. I had used mathcad in the past, and I started working a bit with smath about a year ago. I was looking for a WYSIWYG option, next to python. I do found smath rather convenient but was not so happy with the plotting options so I was curious to see how it would turn out with that plugin.
Thanks for your help.
Offline uni
#203 Posted : 19 March 2018 16:12:42(UTC)
uni
You need to use the Extension Manager (from SMath Studio main menu) to install plugins.
Russia ☭ forever
#204 Posted : 19 March 2018 16:23:44(UTC)
Was thanked: 1368 time(s) in 895 post(s)
Before using the Extensions Manager please remove any plugin you have manually installed. Good
This is under Tools > Plugins... > Online gallery
Edited by user 19 March 2018 16:35:54(UTC)  | Reason: Not specified
on 19/03/2018(UTC)
Offline ElSid
#205 Posted : 28 March 2018 17:50:28(UTC)
ElSid
Going to my heat transfer sheet ...
I was plotting the curves and started filling in the table information. The title stuck, but the X and Y labels did not.
I have tried several times, including creating a new graph, to fix these labels and the plugin freezes SMath. I need to enter task manager to end the program. Essentially, the "pop-up" associated with this plugin is not showing up.
XY-Plot Crash.sm (116kb) downloaded 54 time(s).
PS, I created a new sheet and inserted a zed graph, pop up came up. I created another new sheet and inserted a blank X-Y graph, it crashed.
Edited by user 28 March 2018 18:00:53(UTC)  | Reason: Added PS
#206 Posted : 28 March 2018 19:14:46(UTC)
Originally Posted by: ElSid Go to Quoted Post
... it crashed.
Quite OK here.
Are you doing something wrong or bug wrt your Smath version ? ?
Offline ElSid
#207 Posted : 28 March 2018 19:22:08(UTC)
ElSid
Are you doing something wrong or bug wrt your Smath version?
My sheet has the app version. I'm on 0.99.6654. Looks like that may be the problem
#208 Posted : 28 March 2018 19:53:16(UTC)
I'm on 0.99.6654.Looks like that may be the problem
Conclusively, Maxima X_Y is affected by the Smath version.
Offline uni
#209 Posted : 29 March 2018 07:04:16(UTC)
uni
I can't reproduce the issue. Can you make a screenshot or save crash dump?
Russia ☭ forever
Offline ElSid
#210 Posted : 29 March 2018 15:31:38(UTC)
ElSid
Issue was with SMath 0.99.6654. Andrey updated Smath to 0.99.6661 yesterday and the plugin works
Offline ElSid
#211 Posted : 13 April 2018 20:42:37(UTC)
ElSid
Found the issue(s). See revamped file. Still having issues in that X-Y plot Labels for the legend *zap* Quick Sound Loss.smz (143kb) downloaded 62 time(s).
Edit: Two bugs
  1. X-Y Plot. If functions crash, *Zap* to the legend titles. All other titles OK. Legend is empty due to laziness after last 5 crashes
  2. solve(4) did not like trying to cancel units in the denominator of the final function (#dist). As I was adding units to x:0-100 FT and dividing the units meters in the function, the function crashed in the solve block (Just the function, with all values plugged in except for x = vector, so it's a solve(4) issue).
This is one of those sheets where UNITS are huge! The equations are all based off of SI/metric references. Major issue
There is additional documentation and function definition updates. Sanity check the graph x scale (adjusted for feet since I'm in the US). Should be good now
Offline Alex M.
#212 Posted : 01 June 2018 21:02:40(UTC)
Alex M.
Hi Uni,
Is XY plot still being actively developed?
I was hoping you can address the image quality when printed to PDF.
I wonder if this is because in onpaint() you convert all the draw calls to bitmap which is further stored displayed and printed. In image region, for a windows native vector EMF file, i draw the EMF directly within onpaint() which makes sure that image looks sharp on both the screen (94 dpi) and printer (300 DPI)
AM
#213 Posted : 04 June 2018 02:55:35(UTC)
PDF quality depends only upon the PDF creator. For free, CutePDF is acceptable.
No idea how it renders hard print because I don't have printer.
TESLA.pdf (60kb) downloaded 62 time(s).
Offline Alex M.
#214 Posted : 05 June 2018 01:07:17(UTC)
Alex M.
You are not using "X-Y Plot Region" but "2D Plot" in attached PDF; my comment was regarding the "X-Y Plot Region"
#215 Posted : 05 June 2018 05:57:02(UTC)
No matter X_Y region or QuickPlot ... totally identical from CutePDF.
Doublet.pdf (29kb) downloaded 44 time(s).
#216 Posted : 05 June 2018 06:02:37(UTC)
Image of the CutePDF as rendered by Adobe Reader DC.
Offline alyles
#217 Posted : 05 June 2018 15:12:23(UTC)
alyles
Was thanked: 92 time(s) in 58 post(s)
Jean, looked at zoomed image below from your pdf.
the function text is nice and clear, the plot is pixelated. This is what the issue here.
Offline Alex M.
#218 Posted : 05 June 2018 18:19:48(UTC)
Alex M.
It does look that bitmap is being displayed / printed instead of draw calls
Code:
        public override void OnPaint( PaintEventArgs e ) {
            base.OnPaint( e );
            if ( this.InEvaluation ) return;
            Image image = new Bitmap( e.ClipRectangle.Width, e.ClipRectangle.Height );
            Rectangle Rect = new Rectangle( new Point( 0, 0 ), image.Size );
            Graphics g = Graphics.FromImage( image );
            g.FillRectangle( new SolidBrush( Color.White ), Rect );
            cs.ChartArea = Rect;
            cs.AddChartStyle( g, ca, xa, ya, y2a, gd, lb, tl );
            dc.AddCurves( g, cs, xa, ya, y2a );
            lg.AddLegend( g, dc, cs );
            e.Graphics.DrawImage( image, e.ClipRectangle );
            g.Dispose();
Uni, if you have time at some point, could you either supersample bitmap, or draw directly in onPaint() similar to what was done in PieChart:
https://smath.info:8443/!/#public/view/head/plugins/PieChartRegion/PieChartCanvas.cs
Thank you,
Alex M.
#219 Posted : 05 June 2018 20:41:39(UTC)
Originally Posted by: alyles Go to Quoted Post
Jean, look at zoomed image below from your pdf.
PDF creators recognize what is coded [text, glyphes like in equation editors ...].
The graphs are not codable and treated as image raster. When you zoom up the PDF
documents, the images are simply pixelated. If you zoom up 400%, each pixel is
quadruplated side by side thus the poor looking. If the graph could be interpreted
as an RGB image, then the PDF reader would have to process/zoom the image from
some type of image subprocessor. That simply does not exist with Adobe Reader.
I'm not aware of PDF creator/reader that process images.
In short: Smath is of no concern in there.
From recollection, my "Nuance PDF creator/reader" would zoom up like an image.
Page1 zoom Doublet.sm (110kb) downloaded 37 time(s).
#220 Posted : 06 June 2018 09:58:22(UTC)
Yes this is the cause. Try the following (drag&drop the zip in the canvas - just for testing purposes):
XYPlotRegion.zip (70kb) downloaded 35 time(s).
code committed
Edited by user 06 June 2018 20:22:45(UTC)  | Reason: Not specified
on 07/06/2018(UTC)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
