Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome. Best regards. Alvaro. iplotq.sm (41kb) downloaded 62 time(s).
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Try the method of Draghilev DragilevMet.sm (25kb) downloaded 41 time(s).Edited by user 21 October 2018 20:28:06(UTC)
| Reason: Not specified
1 user thanked Ber7 for this useful post.
Perfect! Thanks.
Not graphic It does not show any error Best Regards Carlos
Hi Carlos For see the error message type B1=
Hello Alvaro: Thank you very much. The error in the graph is that x is not defined. What causes this error? In the graphs published by you it is seen that graphs correctly. Best Regards Carlos
Hola Carlos. Try the following, a short version, just for n=2. Best regards. Alvaro. DragilevMet2.sm (13kb) downloaded 34 time(s).
Try also the old version of the Draghilev method DragilevMet3.sm (24kb) downloaded 27 time(s). Razonar,thanks for the short code for n = 2 Edited by user 21 October 2018 20:29:28(UTC)
Carlos, Alvaro, From previous use of Dragilev method, I observed great difficulties to appropriately start/stop rkfixed. Your example above works fine as is. For more points with less tentatives in specific cases, the easiest way is to pass it to the closed shape Hermite suite. I should revisit some of those examples. The Esplina AI2000 interpolates as well for closed shapes. Spline Esplina [AI2000].sm (22kb) downloaded 21 time(s). Spline Esplina [Hermite].sm (36kb) downloaded 23 time(s).
By--> Razonar Quote: Hola Carlos. Try the following, a short version, just for n=2 By--> Ber7 Quote:Try also the old version of the Dragilev method DragilevMet3.sm (24k downloaded 10 time(s) Hola Alvaro, Hello Ber7, Thanks for your reply, but the DragilevMet2 and 3 files do not work. The file of Ber 7 does not show any error, but by requiring the value of B1 and B2, it says that "x" is not defined. Attached drawing of the errors. Hello Jean, your files worked perfectly. Best Regards Carlos
Hola Carlos. It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RKBest regards. Alvaro. Edited by user 25 February 2018 00:49:18(UTC)
Hola Alvaro: Gracias por tu respuesta. Thanks for your answer, but I found the fault. The interference is caused by the Maxima Plugin, by disabling it, the file works correctly. Best regards Carlos
Hola Alvaro Here too, the problem is caused by the decimal separator "Point", Changing in options, the decimal separator from "Point" to "Comma", (from "." To "," resolves the problem of graphing Best regards Carlos
1 user thanked CBG for this useful post.
