SMath Studio - SMath
Muy buena la aplicación. Ligera, potente y eficaz para lo que está diseñada. Es mi herramienta diaria para cálculos de Ingeniería Civil en Venezuela.
more...
by Kenny Silva
A very useful tool for engineers. Thanks a lot. Keep up the great work.
more...
by Bhargav
Excelente software para los cálculos de ingeniería, muy livano, pero bastante robusto a la hora de realizar cálculos; y su plataforma en la nube es buena.
more...
by fredynils
9 users thanked Andrey Ivashov for this useful post.
on 12/02/2018(UTC), on 12/02/2018(UTC), on 12/02/2018(UTC), on 12/02/2018(UTC), on 12/02/2018(UTC), on 12/02/2018(UTC), on 13/02/2018(UTC), on 13/02/2018(UTC), on 16/02/2018(UTC)
Originally Posted by: Andrey Ivashov Mode to insert special symbols into equation implemented using Ctrl K (Ctrl Shift K is also supported); Very good! Now we can write even the argument separator in subscripts like in eurocodes (not like the decimal separator that changes with settings, but close enough for daily work) Edited by user 12 February 2018 21:04:42(UTC)
Simple example of using new possibility to work with unicode symbols: dec2hex.sm (12kb) downloaded 72 time(s).Best regards.
on 13/02/2018(UTC), on 18/06/2018(UTC)
Hello, Davide! Originally Posted by: Davide Carpi Now we can write even the argument separator in subscripts like in eurocodes (not like the decimal separator that changes with settings, but close enough for daily work) One more benefit here is that we are not limited in units names now. It is pretty important f.e. in Russia:
Creating a variable right on the form SmathViewer Accidentally discovered - it 1. Error 2. Future plan 3. Or so intended - undocumented opportunities And this trick works only when there are variables before and after our variable "fdsf" Перевод: Создание переменной прямо на форме SmathViewer Случайно обнаружил - это 1. Ошибка 2. Планы на будущее 3. Или так задумано - недокументированные возможности Причем этот трюк работает только тогда, когда есть переменные до и после нашей переменной "fdsf" Gif-Animation
Hi. Which goes to be the correct answer? Best regards. Alvaro. vectorize.sm (6kb) downloaded 54 time(s).Edited by user 13 February 2018 13:29:38(UTC)
Technically i thnk 6617 is implementing vectorize correctly. If you want to achieve the results from 6484 you need to apply the vectorize function to the input of rgb2dec as shown in the attached example. vectorize (1).sm (9kb) downloaded 51 time(s).Edited by user 13 February 2018 19:12:43(UTC)
Hello, Alvaro. Originally Posted by: Razonar Hi. Which goes to be the correct answer? Thank you very much for this report! I have investigated issue and see new version shows incorrect results (I have introduced this bug during work on refactoring). I have found the reason and just fixed it. Now results are the same as in 6484. I will release new SMath Studio version soon. Best regards.
Hello. Originally Posted by: Kriss Creating a variable right on the form SmathViewer Accidentally discovered - it 1. Error 2. Future plan 3. Or so intended - undocumented opportunities Heh. This is not something I planned to implement. I would say this "feature" is introduced accidentally At least it is a first time I see it. And I even not sure what to do with it now... Best regards.
Originally Posted by: Andrey Ivashov I have investigated issue and see new version shows incorrect results (I have introduced this bug during work on refactoring).
I don't know why this vectorize function confuses me so much. Could someone explain to me how this function operates? I tend to think of it as a similar to the "dot" . command in Matlab. For example in 0.6484 shown below. I don't see how calling vectorize either inside the function or outside the function produces the same results, but calling it both inside the function and outside cancels its effects. I'm sure my misunderstanding comes from ignorance on how SMath works behind the scenes and order of operations. But to me the behavior in 6617 tends to make sense. |
Originally Posted by: alyles I don't know why this vectorize function confuses me so much. Could someone explain to me how this function operates? Since it was introduced [Smath 6179] and 100's time I used it, it works same as Mathcad 8 Pro <= 11. It is an element wise operator, seemingly universal similar to all matrix/vector algebra ... for instance 2d, 35 rotation. Does it work ? Yes and no as you put it. As simple as it looks, follows some rules depending upon the result style. Jean vectorize (1).sm (96kb) downloaded 48 time(s).
... some examples Observe the matrix/vector rules ... M*rotation ... NOT rotation*MCholesky solver is not commutative ... + examples vectorize => please feel free ! Alyles.sm (1,013kb) downloaded 49 time(s).
Hi. Yes, vectorize is similar to the dot operator in matlab, but also like map in maple and /@ in mathematica: ever language have a way to operate "element by element" in matlab speak, or over the "head" of structures, in the others. SMath "structure" are always arrays, and could be confusing the behavior when the vectorize operator operates over "arrays of arrays". Fortunately, SMath is more congruent than mathcad, which behavior was unpredictable between versions: Here is the maple's map and mathematica /@: Best regards. Alvaro.
Originally Posted by: Razonar I don't know why this vectorize function confuses me so much. Could someone explain to me how this function operates?
Originally Posted by: alyles I don't know why this vectorize function confuses me so much. Could someone explain to me how this function operates? camera & many more is a standard in image processing. A gorgeous application for the Smath vectorize operator.
2 users thanked Jean Giraud for this useful post.
on 15/02/2018(UTC), on 15/02/2018(UTC)
Originally Posted by: alyles I don't know why this vectorize function confuses me so much. Could someone explain to me how this function operates? ... the few examples above make you confident. You may hit the wall from "vectorize" ... Explain => Mathcad vectorize operator take interpolation functions, Smath does NOT, thus the vect operator fails. Unlike Mathcad, Smath linterp, ainterp, cinterp are NOT scalar functions ... demonstrated in the attached. This nuance will save you growing more gray hairs. Image Rainbow Colormap.sm (240kb) downloaded 53 time(s).
