I think you made few mistakes in using RK equation of state and roots function in finding the molar volume. Here is how this could work properly: V.id=0.0248 P(V.id,T.f)-P.x=-709.8795 res:roots(P(_V,T.f)-P.x,_V,V.id) res=0.0246 P(res,T.f)-P.x=3.3237*10^{-10} Do not use variable ( second argument of "roots" ) which is already defined (I used here _V). The guess value here could be the molar volume of ideal gas Vid. BTW, do not use units in the integration - it is not advisable at the moment.
Regards, Radovan |
Hello skylo, skylo wrote:omorr wrote:Hello,
Regards, Radovan Hi, I want to ask what is "res". Thank you very much. Do not understand why "res" confuses you. It is a simple variable, and it receives the result of the expression on the right hand side of the assignment operator ( := ) - the result of the function "roots" calling in this case. In this case, "res" is actually the value of the volume you are looking for. You could have used here the variable name which suits you the most - it is irrelevant. Regards, Radovan Edited by user 02 January 2011 11:08:54(UTC)
Joined: 11/01/2011(UTC) Posts: 5 Location: Brescia Italy
Is it available the Mathcad "Reference" in SMath? If not, how to refer to formulas and data included in a different SMath file?
Thanks
Hello Paolo, PaoloM wrote:Is it available the Mathcad "Reference" in SMath? If not, how to refer to formulas and data included in a different SMath file? There is no "Reference" in the sense to "include" the file contents at the appropriate place into another file. However, you have the "Snippets" mechanism ( 0.89.8 Beta features). That means that you can make a "Snippet" file from an ordinary SMath file. Just save it into the dedicated "snippets" folder. It is located in the SMath subfolder "..\SMath\snippets\". After that the Snippet manager Tools=>Snippet Manager can be used to insert the file into another SMath file. It can be inserted as "Area" region. Regards, Radovan |
