6 Pages<12345>»
#41 Posted : 02 December 2015 02:24:45(UTC)
Hello Alex Good
That's an interesting idea; I've something in my mind but is not yet fully defined. Now I'm working to complete a new plugin, then I'll start to update the core of the table region, I know there are several bugs to fix and things to add. This will require time.
Of course you can play with the code, there aren't restrictions
Edited by user 02 December 2015 02:34:03(UTC)  | Reason: Not specified
on 09/12/2015(UTC)
Offline Alex M.
#42 Posted : 09 December 2015 19:57:35(UTC)
Alex M.
Hi Davide,
I looked at the code - it seems to be somewhat out of my league (at least for now). I might just wait till you decide it is time to use table region for matrix creation.
Thank you for your hard work here!
thanks 1 user thanked Alex M. for this useful post.
on 10/12/2015(UTC)
#43 Posted : 17 December 2015 07:51:23(UTC)
a convincing example of where display contents editing is useful.
_____________________________
I agree with Martin:
1. If your matrix is wrong: recreate the same way you did "wrong" but this time "right"
2. If you create a matrix from a *.PDF, address the element you want to correct.
3. You can extract "row', "col"
4. You can insert row(s) by submatrix and stacking.
5. You can insert col(s) by transposing by [4. above] and re-transpose.
If you are given a horse, don't ask for the saddle.
à cheval donné: ne demande pas la bride
"Edit" is a very large word, especially if not exemplified.
No work sheet = No problem !
#44 Posted : 18 December 2015 04:51:28(UTC)
This work sheet may be useful. Many important modules are missing:
1. Replace part of a matrix by another one.
2. Insert row(s)/col(s) at specific position.
...etc.
Utilities Matrix.sm (162kb) downloaded 145 time(s).
on 18/12/2015(UTC)
Offline PompelmoTell
#45 Posted : 05 July 2017 14:30:02(UTC)
PompelmoTell
As shown in the attached image, I encounter a problem using SMath-formatted labels for table headers.
This problem did not exist in previous versions as highlighted in the image.
In particular, the problem seems to be limited to the use of "." for the subscript.
I note that the opening "TableRegion.sm" of the sample file causes the program to crash Smath (only in version 098.6356).
on 05/07/2017(UTC)
#46 Posted : 05 July 2017 19:28:14(UTC)
Thank you Sergio,
please try with the updated plugin Good
on 05/07/2017(UTC)
Offline uncblue
#47 Posted : 05 July 2017 20:30:23(UTC)
uncblue
Rank: Member
Wow I had no idea this plugin even existed.
Thanks so much to the SMath contributors and especially Davide for this plugin. Clap
#48 Posted : 05 July 2017 20:57:31(UTC)
PompelmoTell
Ok works as well as before OK
thank you Davide
Offline uncblue
#49 Posted : 06 July 2017 00:17:14(UTC)
uncblue
Rank: Member
Davide,
I looked through the example files but I didn't see anything that addressed my situation.
I'm not sure if this is even possible or if I overlooked the option.
Is there a way to word wrap the header to fit a set width for the numeric table values?
The second table in the screenshot is similar to what I'm trying to achieve.
I also made a quick example in excel to help illustrate.
I was also going to use the footnote option as an alternative but I'm came across a similar problem where I couldn't widen the note section since it appears dependent on the table width.
#50 Posted : 06 July 2017 03:26:15(UTC)
Hello uncblue Offline ,
I guess this feature is not available (I have to double check the code but I'm almost sure I haven't ooded it).
This plugin has a lot of room for improvements (and several fixes), I'll try to come back on it in the future!
on 06/07/2017(UTC)
Offline uncblue
#51 Posted : 06 July 2017 03:59:20(UTC)
uncblue
Rank: Member
Ok, that sounds great.
I'm so glad I came across this plugin because I was creating "ugly" tables manually before I found this.
Offline MarB
#52 Posted : 04 October 2017 14:27:55(UTC)
MarB
found an issue in Version 0.1.6395.15149, using SMath 0.98.64.84.
It is related to using commas (,) for decimal separator.
The plugin seems to replace every point with a comma, also where used as subsript.
e. g. "BS,k" (the string "BS,k" cannot be found in the sm-File).
Tables work well if point as decimal separator is used.
Bevor calculation:
After calculation:
Offline MarB
#53 Posted : 04 October 2017 15:20:48(UTC)
MarB
Nested arrays as input for a table don't work anymore, too.
#54 Posted : 04 October 2017 18:11:38(UTC)
Thank you MarB Offline , I'll look into it ASAP
on 04/10/2017(UTC),  on 06/10/2017(UTC)
#55 Posted : 08 October 2017 20:31:02(UTC)
PLUGIN UPDATED SMath Studio 0.98.6484 and later
  • provided access to settings via context menu;
  • fixed some issues related to Session' Profile compatibility;
  • SS-120: fixed issues with nested matrices;
  • SS-2394: fixed decimal places/significant figures settings not stored;
  • significant figures algorithm refactored;
thanks 5 users thanked Davide Carpi for this useful post.
on 08/10/2017(UTC),  on 09/10/2017(UTC),  on 09/10/2017(UTC),  on 09/10/2017(UTC),  on 09/10/2017(UTC)
Offline MarB
#56 Posted : 09 October 2017 08:58:20(UTC)
MarB
Thanks for your improvement, Davide.
In following screenshot you can see the following behaviour:
With number format set to default...
- numbers are always written with exponent (left/right stub also)
- strings are printed with surrounding "" and Expressions are not formatted
By changing the number format to number, everything looks as usual.
Is that intended?
thanks 1 user thanked MarB for this useful post.
on 09/10/2017(UTC)
#57 Posted : 09 October 2017 10:27:01(UTC)
Thank you,
it's a bug indeed, I'll fix it later today. Good
on 10/10/2017(UTC)
#58 Posted : 10 October 2017 17:48:30(UTC)
please try again now
PLUGIN UPDATED
on 10/10/2017(UTC)
Offline MarB
#59 Posted : 10 October 2017 20:42:43(UTC)
MarB
Looks good.
Units are printed black, upright (not blue, italic). But why not?
#60 Posted : 11 October 2017 03:27:23(UTC)
Originally Posted by: MarB Go to Quoted Post
Looks good.
Fixed, it was not intentional, thank you again Good
Edited by user 11 October 2017 03:29:24(UTC)  | Reason: Not specified
Guest (2)
Similar Topics
Table Region Problem (Questions)
by ndtma 27/08/2023 11:58:19(UTC)
[Table Region] Caption Font Size Problem with Windpws Display Scale (Bugs & Problems)
by ndtma 09/01/2022 20:02:03(UTC)
Text formatting single cell in table region (Questions)
by wb.c 15/09/2021 22:14:25(UTC)
Table Region PlugIn (Questions)
by MBernacca 29/01/2020 13:42:47(UTC)
"Table Region" Plug-in installation failed (Questions)
by aviateCar 02/07/2019 23:30:54(UTC)
Table Region Font Bug at Font Scale %125 (Bugs & Problems)
by overlord 16/03/2019 23:00:46(UTC)
Show the Orignal Units in Table Region (Questions)
by CBG 21/03/2018 22:01:53(UTC)
by CBG 07/03/2018 20:21:01(UTC)
Table Region Units (Extensions)
by CBG 16/12/2017 04:41:33(UTC)
Table Region Model (Samples)
by Jean Giraud 07/06/2017 18:19:06(UTC)
6 Pages<12345>»
