  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,603   Was thanked: 1972 time(s) in 661 post(s)
New Beta SMath Studio 0.98.6356 is available!Tiny, but powerful mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- SS-2443: Function vectorize(...) now acts even on 1-element matrices;
- Application enabled to use .Net Framework 4.0 or higher if no .Net Framework 2.0/3.0/3.5 installed on client Windows PC;
- Multiple improvements done into Core to support personal user settings.
Corrections- SS-2436: Boolean equality calculations: fixed strings vs different types;
- Incorrect program window location on start fixed;
- Critical issue fixed appeared in some cases when changing math equation display options using context menu;
- Settings Saving/Loading stability improved;
- Loading of language files corrected when not all of them are available.
Miscellaneous- DEV: SessionProfile allows to store settings from plug-ins now;
- Interface translations updated;
- Refactoring.
DownloadEdited by user 27 May 2017 23:21:24(UTC)
| Reason: Not specified
 11 users thanked Andrey Ivashov for this useful post.
on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 26/05/2017(UTC), on 27/05/2017(UTC), on 27/05/2017(UTC), on 27/05/2017(UTC)
Updated version released.
The only visible change to the build released yesterday is: - Usage of Descriptions for MathRegion (and other regions which contains MathRegion) are fixed - previously any input was duplicated between region equation and description.
Best regards, Andrey Ivashov.
 4 users thanked Andrey Ivashov for this useful post.
on 28/05/2017(UTC), on 28/05/2017(UTC), on 29/05/2017(UTC), on 29/05/2017(UTC)
Joined: 03/03/2014(UTC) Posts: 414  Was thanked: 123 time(s) in 94 post(s)
Good day, Andrey.
In my megabyte heavy smath worksheets I was faced with very long recalculation times for the new build. I have "time stamped" the worksheet an realised that major chunk of reclaulation time is spent before any calcs are done in the worksheet.
This behavior is repeatable over many worksheets.
I will gladly share the worksheet privately via email.
Thanks!
Originally Posted by: Alex M.  I will gladly share the worksheet privately via email. Please send a worksheet to me, so I could test and fix this issue. Thanks in advance! Best regards.
