Offline omorr
#1 Posted : 27 October 2010 12:38:34(UTC)
omorr
Serbia
Yes, it is possible. Make two vectors, like:
A←mat(3,5,10,15,20,25,30,7,1) C←mat(10.1,12.2,13.7,14.4,14.8,15.0,15.2,7,1)
Then make a matrix with two columns from these vectors.
AC←augment(A,C) AC=mat(3,10.1,5,12.2,10,13.7,15,14.4,20,14.8,25,15,30,15.2,7,2)
Open the Insert=>Plot=>2D and put the matrix AC in the placeholder. The first column will be on the x-axis and the second on the y-axis.
For additional details visit the Wiki and read the Tutorials, please.
SMath Tutorials
on 27/10/2010(UTC)
Offline omorr
#2 Posted : 30 October 2010 22:30:06(UTC)
omorr
Serbia
Did you try to click into the graph and to use mouse wheel or CTRL+mouse wheel or SHIFT+mouse wheel? This way you can rescale the axis, both or separate x and y.
Offline omorr
#3 Posted : 31 October 2010 11:34:16(UTC)
omorr
Serbia
If you click in the graph and use mouse scroll wheel, both axis will rescale simultaneosly.
If you click in the graph, keep pressed CTRL and use mouse scroll wheel, ONLY the y axis will rescale.
If you press and keep SHIFT and by using the mouse scroll wheel then ONLY the x axis will be rescaled.
With the left mouse button you can move the graph in the graph region.
Just make the plot the way you want and click outside the graph region. For making points instead of lines see the mentioned links.
Here you are:
AC1 - two column matrix
AC2 - five column matrix (symbol, size, color vectors added)
Edited by user 31 October 2010 13:42:07(UTC)  | Reason: Not specified
Similar Topics
Help with Graph Function (Questions)
by Igor_Mag 05/10/2023 19:27:35(UTC)
High Quality Graphs (Questions)
by Oichi 16/08/2023 22:35:26(UTC)
Plotting a x,y graph with complex numbers (Questions)
by Lee Snook 06/07/2023 22:42:28(UTC)
XY GRAPHS VERSUS ZEDGRAPH (Questions)
by JReg 25/06/2023 02:01:55(UTC)
Design Response Spectra - Graphing (Questions)
by GFDIntano 09/05/2023 11:31:47(UTC)
Basic Graphics (Bugs & Problems)
by Javier Ochoa 29/03/2023 20:41:21(UTC)
Getting started with graphical windows/sketches of a structure? (Questions)
by OlliL 01/03/2023 10:52:38(UTC)
Graphs for the control tasks (Questions)
by TopUser2000 26/02/2023 19:23:18(UTC)
Create a graph with x y plot (Questions)
by Israel Pelaez 13/02/2023 19:37:51(UTC)
Create a graph with x-y plot (Questions)
by Beyaz 11/02/2023 12:35:47(UTC)
Graphic Package PID Experimental (Samples)
by Jean Giraud 25/01/2023 15:41:31(UTC)
x,y time depended graphs (Questions)
by mareksss 17/10/2022 19:58:40(UTC)
Functions not Plotting in Graph (Questions)
by Albedo 09/10/2022 06:06:17(UTC)
Problem with Graphs (Questions)
by mareksss 09/09/2022 17:20:30(UTC)
Graphic Utilities rev.1 (Samples)
by Jean Giraud 28/01/2022 21:39:22(UTC)
