Was thanked: 4 time(s) in 2 post(s)
Dear Andrey, When I specify the number of decimal places in the result of any expression and the last digit is zero then it is also cut. Sample: - Set value n:=0,798
- List value by typing n=
- Set number digits after comma to 2
I would expect to have 0,80, instead I get 0,8. It is confusing as reader does not know that I use two digits precision in my calculations. Michał
Hello
m227
, have you tried the "trailing zeros" option in the context menu? |
Davide, you saved my day. So this post can be deleted. I don't know how could I omit this, blind am I... Probably this function should be set ON default? Michał
Originally Posted by: m227 Probably this function should be set ON default? MichaÅ Most of the times, I would vote for this option [show trailing 0's]. Other times would vote "NO". Option "show trailing 0's" enables to line up decimal points in data tabulated from calculations. Jean
Originally Posted by: m227 Probably this function should be set ON default? I think would be possible to setup this as a global option that acts on new regions (like decimal places; tools -> options -> calculation). BTS feature requesst: SS-2442Edited by user 20 April 2017 13:43:55(UTC)
