SMath Studio Forum
Download SMath Studio
Archive
Stable: SMath Studio 0.98.6179 (01 December 2016)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,614   Was thanked: 1977 time(s) in 665 post(s)
New stable SMath Studio 0.98.6179 available Tiny, powerful, free mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into 38 different languages. Application also contains integrated mathematical reference book. SMath Studio Desktop on the Desktop (Windows) SMath Studio Desktop on the Desktop (Linux)  - [SS-2413]: Situations with displacing Regions on Worksheet open fixed;
- [SS-2407]: UnitsOf function improved to fix negative results and support sys(..) as an argument;
- [SS-2309]: Stack/Augment improved to accept numbers/strings in any position (systems are managed as scalar numbers);
- Application loading speed improved;
- Numeric power operation improved to handle extremely small numbers correctly;
- Behaviors to work with collapsed Areas significantly improved on Copy/Paste/Ctrl+drag;
- Delete/Cut operations fixed when working with Collapsed Areas;
- Fixed error happened in worksheet history in some cases (it was impossible to restore deleted region with ReDo);
- SMath Viewer improved to accept user input of exponential notation and imaginary numbers;
- Page Counter tooltip now shown over all other visible UI elements;
- All Regions based on RegionHolder improved to be correctly shown on focus when they are not fully visible on the screen;
- Back-compatibility of col/row functions calculation improved;
- Silent mode: exceptions happened on several configurations fixed;
- Cloud: Fixed issues appears on using Backspace/Delete/Enter to move Regions under cursor up or down on the Worksheet;
- Loading screen is now shown on top of other windows;
- Interface translations updated;
- Refactoring.
System requirements - Desktop (Windows):
Framework: .NET Framework 2.0
- Desktop (Linux):
Interface languages (37 languages) - [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
Free Download Tutorial SMath Studio tutorial by Bernard Liengme. SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons (  ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format. Edited by user 02 October 2017 20:08:52(UTC)
| Reason: Not specified
 12 users thanked Andrey Ivashov for this useful post.
on 01/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 02/12/2016(UTC), on 03/12/2016(UTC), on 05/12/2016(UTC), on 06/12/2016(UTC), on 19/12/2016(UTC)
Joined: 05/03/2009(UTC) Posts: 433   Location: USA Was thanked: 17 time(s) in 15 post(s)
As always, thank you and the team for the new stable release. As the work progresses to 0.99 releases, would it be possible to 1) Allow English (IP units) as the default for those of us in the US? 2) Consider making some of the plugins an integral part of the software? (e.g. hyperlink, run, writer region, etc. plugins) Everyone has an opinion as to "what" should be baked in, so this is programmers choice. My request is for some of the "visuals" to creating a report to be part of the base package. Thank you
Joined: 04/07/2015(UTC) Posts: 6,720  Was thanked: 959 time(s) in 787 post(s)
Writer region & hyperlink are all explained in their respective release. What do you mean "run" ? F9 calculates the all work sheet.
Jean, Originally Posted by: ElSid  2) Consider making some of the plugins an integral part of the software? (e.g. hyperlink, run, writer region, etc. plugins) My request is for some of the "visuals" to creating a report to be part of the base package/install. Commands such as PDF Files Plugin, Matlab Math Library, Maple Wrapper, SQL, etc. can continue to be brought in on user's wants'/needs. As an example, I would love to see the "Writer Region" plugin functionality be part of the base install. This program is Awesome!!! Thanks to all of the time and effort that all of the programmers put in to make such wonderfully functional software as well as all of the bloggers from around the world ... Happy Holidays!
1. Matlab: functions are in fx menu "mwXXX" 2. Maple: are user command "maple(_"_) 3.PDF: two ways => 3.a/ Download free PDF from the web, install, print as PDF [give name]. 3.b/ Purchase a more advanceed PDF [typical DocuDesk was $50] 4. SQL [Data Base Management]: Smath is essentially an Engineering Document Creator. 5. Viewer: Not part of the standard 6179 package. What should it do ? ......
Thanks for the viewer demo. As it looks it captures a live web page and more. From the page where you have installed Smath 6179: 1. Click on plugin(68) 2. Browse for "Viewer" or else plugin 3. Click to download the plugin of interest [zip] 4. Unzip at the Smath destination 5. Now, "Viewer" is in the "Insert menu'
Joined: 15/04/2012(UTC) Posts: 1,894  Was thanked: 1056 time(s) in 676 post(s)
I uploaded an interactive (german) tutorial "Erste Schritte mit SMath Studio" to my support page. It is a single .sm file with 22 area regions (topics). https://extmoodle.th-bra...de/course/view.php?id=34This perhaps could be distributed easily via the online gallery but I am not sure as what type of extension I should register the file. - handbooks would require pdf or cbm format - interactive books would be opened in the limited viewer window (the user of the tutorial is expected to perform exercises) - example would work but is not really the right word for the stuff. My recommendation would be to extend the handbooks type to accept self-contained (with no dependencies) .sm files. PS: I failed to add the tutorial to the wiki list. There was an error when producing the preview. |
 2 users thanked mkraska for this useful post.
on 09/01/2017(UTC), on 13/01/2017(UTC)
The interactive tutorial has been extended with an english version. You can download it in the extension manager.  |
 7 users thanked mkraska for this useful post.
on 23/01/2017(UTC), on 23/01/2017(UTC), on 23/01/2017(UTC), on 23/01/2017(UTC), on 23/01/2017(UTC), on 27/01/2017(UTC), on 06/03/2017(UTC)
thank you a lot for this  |
Divide et impera ))) |
German handbook (316 pages, PDF) updated. It is based on the pre-configured portable distribution with Maxima, which you can download at TH Brandenburg (Registation required). The file is too large for the extension portal, therefore I distribute it via the external Moodle system of our university. The distribution comes with a pre-installed interactive handbook (german/english), access it using the help button [?] in the toolbar. There is also an interactive introduction (tutorial) |
on 08/07/2017(UTC), on 09/07/2017(UTC)
SMath Studio Forum
Archive
