4 Pages<1234>
#41 Posted : 08 August 2014 22:23:44(UTC)
Was thanked: 1270 time(s) in 835 post(s)
PLUGIN UPDATED
- Paste as SMath string enabled & fixed.
I apologize for the multiple updates.
Edited by user 08 August 2014 22:26:34(UTC)  | Reason: Not specified
Offline mkraska
#42 Posted : 01 January 2017 01:31:26(UTC)
mkraska
Was thanked: 988 time(s) in 631 post(s)
Davide, I experience strange problems with hyperlinks with SMath 0.98.6179 and a fresh hyperlink region plugin.
The links in your docs (from post #1) work fine.
If I copy them to my handbook page, I get "System can't find the file" messages for the links marked with red background, both documents in the same instance of SMath. No matter if portable or installed distribution...
There must be something wrong with my document...
HyperlinkRegion.sm (91kb) downloaded 51 time(s). Plugin Hyperlink Region.sm (66kb) downloaded 45 time(s).
on 02/01/2017(UTC),  on 02/01/2017(UTC)
#43 Posted : 02 January 2017 18:35:03(UTC)
Try now, it should be fixed.
Also:
- SMath Viever now should be able to open relative links (if the file exists);
- SMath files they can be opened even from SMath portable (a new instance of the current SS will be used to open the files, as in Writer Region);
on 02/01/2017(UTC)
Offline mkraska
#44 Posted : 02 January 2017 19:10:41(UTC)
mkraska
Confired, thank you.
BTW, due to the current plugin loading policy (long startup time), I'd prefer links to smath files being opened in the currently running instance.
For the interactive handbook, the writer region can't be used by this reason (also, because you need to activate the region before you can click links, i.e. thus doubling the required clicks).
Offline Kross
#45 Posted : 15 February 2017 13:57:07(UTC)
Kross
I am using it with version 0.98.6179 but generation
of executable version (viewer)
SMath Viewer Options
1. When check "Full version" in set - doesn't work for me.
HyperLink is not active
2. When uncheck "Full version" in set - all right.
HyperLink is active
explanation in the picture
http://pixs.ru/showimage/Question1p_4537918_25177731.png
P.S.
I can't login Kriss
#46 Posted : 15 February 2017 14:30:17(UTC)
Third-party plugins are not yet supported in SMath Viewer Full (see here)
Offline Kross
#47 Posted : 15 February 2017 14:40:15(UTC)
Kross
Ok
thank you
for the explanation
Offline Kross
#48 Posted : 03 March 2017 14:06:51(UTC)
Kross
Suggestion to improve appearance Hyperlink Region
I propose to add the property isEnable = 1 or 0
with the ability to switch in the environment Smath Studio
and add this functionality in ComboBoxList Region
Best regards!
Edited by user 03 March 2017 14:09:08(UTC)  | Reason: Not specified
#49 Posted : 03 March 2017 14:51:28(UTC)
Hello Kross,
You can disable the region like any other region evaluable (right click > disable evaluation). Or I miss something? Good
Offline Kriss
#50 Posted : 05 March 2017 12:29:43(UTC)
Kriss
Rank: Member
Probably, I not clearly explained
I need to control programmatically from within
assume conditions
Code:
if a > 10
isEnable = 1
my English is not very good
Offline gregi
#51 Posted : 02 June 2017 12:15:02(UTC)
gregi
Poland
Your extension is great - it should be built-in in SMath, but I have encountered a problem when I wanted to add hyperlink to a file inside a directory within SMath file, for example:
SMath file is in:
E:\longDirName\SmathSample\Hyperlinks.sm
The hyperlinked file is in:
I don't want to paste always the whole path - sometimes there could be a situation of copy-paste SMath file - hyperlinks would be then broken.
I want to use reference paths, in this example just:
But in your code it is denied by the first logical check in code (class HyperlinkRegion, method GoToDestination():
Code:
if ((!String.IsNullOrEmpty(this.FileName) || this.IsViewerApplication)
                    && destination.IndexOfAny(Path.GetInvalidFileNameChars()) == -1
                    && destination.IndexOf('@') == -1
                    && !Path.IsPathRooted(destination))
There are two conditions: destination.IndexOfAny(Path.GetInvalidFileNameChars()) == -1 which are denying hyperlinks with backslashes (backslash could not be in FileName).
If you change your comparisions to: Path.GetInvalidPathChars() you will open that possiblity.
thanks 1 user thanked gregi for this useful post.
on 02/06/2017(UTC)
#52 Posted : 02 June 2017 14:21:52(UTC)
Hello gregi Offline ,
it is a bug introduced by me in a recent update, thank you Good
Plugin fixed and updated (latest SS beta only)
on 02/06/2017(UTC)
Offline krissn
#53 Posted : 19 February 2018 23:56:23(UTC)
krissn
Rank: Member
United Kingdom
Paste doesn't work when there is already some input data.
E.g.
1. ctrl+h
2. ctrl+v and this paste e.g. "C:\some_path\"
3. ctrl+v at the end of already pasted string -- doesn't work.
Kriss
#54 Posted : 20 February 2018 02:36:03(UTC)
E.g.
1. ctrl+h
Kriss
Please update the plugin and test if the fix works for you Good
PLUGIN UPDATED
Offline krissn
#55 Posted : 20 February 2018 14:53:05(UTC)
krissn
Rank: Member
United Kingdom
Hi, Thanks for fix.
It seems to be working, unless you trying to paste something outside of double-quotes (beginning or end of line). Then it says "Paste to region failed" on status bar. I'm not complaining, just want to bring that into your attention in case you want to do anything with this.
Thanks again for quick response.
Kriss
Offline mkraska
#56 Posted : 26 September 2018 20:48:08(UTC)
mkraska
The link text seems to be cut off in 6824 and newer (perhaps also older).
on 27/09/2018(UTC)
#57 Posted : 27 September 2018 01:07:46(UTC)
Thank you Martin, confirmed and fixed.
seems there are issues with the Release Manager today, I'll deploy the updated extension as soon as it will be possible Good
Edited by user 27 September 2018 01:16:31(UTC)  | Reason: Not specified
Offline fedeghi
#58 Posted : 04 June 2019 12:50:30(UTC)
fedeghi
Was thanked: 23 time(s) in 15 post(s)
Hi Davide,
is there a way to save a pdf of an .sm file, and keeping the Hyperlink Region as a real embedded hyperlink in the pdf file?
Currently I'm saving pdfs with Andrey's tool "PDF Files Plugin", meaning that I simply select " SAVE AS ---> .pdf " from the "file" tab.
Doing this, the hyperlink Region will become an image in the pdf file.
I'm not even sure if the above requirement is related more to the "Hyperlink plugin" or to the "PDF Files Plugin" behaviour.
#59 Posted : 04 June 2019 14:39:57(UTC)
Was thanked: 928 time(s) in 756 post(s)
Not my business, but don't understand why re-convert:
an *.sm saved as *.PDF back to the original *.sm ?
Offline fedeghi
#60 Posted : 04 June 2019 14:47:52(UTC)
fedeghi
Hi Jean, my goal is not to reconvert.
Probably I didn't write it properly: I would like to open an sm file that contains Hyperlinks, and save it as pdf where Hyperlink Regions are still clickable links.
4 Pages<1234>
