SMath Studio Forum
Download SMath Studio
Archive
UPDATED: RC5: SMath Studio 0.98.6123 (06 October 2016)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,614   Was thanked: 1977 time(s) in 665 post(s)
Release Candidate: SMath Studio 0.98.6122 available - [SS-2409]: Return value for indeterminate argument by UnitsOf() function fixed;
- [SS-2318]: Preprocessing of symbolic data / functions' arguments finally fixed;
- [SS-111], [SS-2327]: Fixed issues with functions arguments names interference;
- [SV-2377]: Viewer: Issue when protected Area Regions was shown as tabs fixed;
- [SS-2411]: Symbolic simplification of functions arguments fixed;
- Detection of 0^0 error disabled for operations performed by numerical methods (like Integration or Gamma function);
- Function range(3) improved to fix issues with lost last value of result vector;
- Glitches happened sometimes on insert new Regions after collapsed Area Regions fixed;
- About dialog extended to show if application is started in 32/64-bit mode;
- Silent mode extended with -b argument (summary mode of output);
- Consistency fix for el(...) function - when matrix used as indices (elements by row then by column);
- Support for matrix as index feature added for sys(..) + several input errors handled;
- Refactoring.
UPDATE: Changes against SMath Studio 0.98.6122 - Support for units in range(2) implemented (base unit of the range start value used for increment);
- Automatic scrolling to the Region just added to the Worksheet improved;
- Incorrect location of Separator Region inserted by Ctrl+Enter press fixed (now it is added exactly on the place where cursor is located);
- Visual glitches fixed when using Ctrl+Click functionality to select Regions on the Worksheet;
- Special Region placeholder is now shown instead of incorrectly loaded Regions on file open;
- Refactoring and code simplifications;
- [Against to 0.98.6122 only]: Support for units in range(3) restored;
- [Against to 0.98.6122 only]: Hotkeys for Math Regions restored.
Download Edited by user 06 October 2016 17:07:17(UTC)
| Reason: Not specified
 8 users thanked Andrey Ivashov for this useful post.
on 05/10/2016(UTC), on 05/10/2016(UTC), on 06/10/2016(UTC), on 06/10/2016(UTC), on 06/10/2016(UTC), on 06/10/2016(UTC), on 06/10/2016(UTC), on 06/10/2016(UTC)
Joined: 17/01/2013(UTC) Posts: 296   Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
I seem to be unable to use "[" shortcut to el() function.  Edit: The same for root ("\" ) Edited by user 06 October 2016 01:45:29(UTC)
Best regards, Mike Kaganski |
 1 user thanked mikekaganski for this useful post.
Units are lost in range(2):  |
  Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740   Was thanked: 318 time(s) in 268 post(s)
Originally Posted by: mikekaganski  I seem to be unable to use "[" shortcut to el() function.  Edit: The same for root ("\" ) Confirmed |
Problems with "[", "]", "\" and units in range are fixed in appVersion(4)="0.98.6123.7493" |
Thank you Mike!
Yes, issues you have found are fixed (not only thoose ones) and new build created. Please see updated first comment for list of changes.
Best regards, Andrey Ivashov.
on 06/10/2016(UTC), on 07/10/2016(UTC)
Joined: 07/10/2016(UTC) Posts: 1  Location: Россия, Красноярск
Hello. In Windows version I insert image on the document page and save it. After I open this document on the Linux and don't see image. But on Windows image be show.
(Sorry for bad English)
Joined: 03/03/2014(UTC) Posts: 417  Was thanked: 125 time(s) in 96 post(s)
Originally Posted by: GreatGehar  Hello. In Windows version I insert image on the document page and save it. After I open this document on the Linux and don't see image. But on Windows image be show.
(Sorry for bad English) If it is related to the "Image Region" please post in the corresponding thread of the plugin - I will attempt to help you.
SMath Studio Forum
Archive
