SMath Studio Forum
Download SMath Studio
Archive
RC2: SMath Studio 0.98.6089 (02 September 2016)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,640   Was thanked: 2012 time(s) in 680 post(s)
Release Candidate: SMath Studio 0.98.6089 available - Fixed handling of directories in plug-ins archives when plug-in installed from Extensions Manager;
- [SS-2345]: Fixed toolbox invisible items;
- Fixed white background while buttons contains drawings;
- [SS-219]: Required parenthesis automatically added in some cases for el(...) function;
- [SV-2373], [SV-2377]: Wrong handling of encrypted areas by Viewer and related crashes are fixed;
- [SV-2376]: Case-sensitive function listing restored in Insert Function dialog;
- Back-compatibility issue fixed: it was impossible to work with data loaded by rfile(...);
- It is possible now to paste one-line text into MathRegion.
Download
 9 users thanked Andrey Ivashov for this useful post.
on 02/09/2016(UTC), on 02/09/2016(UTC), on 02/09/2016(UTC), on 02/09/2016(UTC), on 02/09/2016(UTC), on 02/09/2016(UTC), on 02/09/2016(UTC), on 03/09/2016(UTC), on 03/09/2016(UTC)
Joined: 15/04/2012(UTC) Posts: 2,048  Was thanked: 1177 time(s) in 752 post(s)
Section Math ODE intro.sm (27kb) downloaded 71 time(s).If I try to open the attached document, the plugin dependency dialog complains about the missing ODE Solver. The requested version in the dialog is older than the one actually installed. It seems that the message can be ignored safely. Not sure if that is a feature...  |
Hello. Originally Posted by: mkraska  The requested version in the dialog is older than the one actually installed. It seems that the message can be ignored safely. Not sure why, but on 17 August 2015
amyuniyal
changed version of ODESolvers plug-in from 1.0.* to 0.1.*. This is not a good practice because in software development it is always supposed that newer build means increased version. Because of that challenge SMath Studio cannot understand what happened with this plug-in and displays an error dialog to show that something unusual happens. This also means that those who installed ODESolvers plug-in before 17 August 2015 will never see any updates of this plug-in and will always use outdated version. That is why I think SMath Studio message you mentioned is a good thing. I suggest to delete installed version of ODESolvers plug-in (using Extensions Manager - select plug-in and press uninstall button at the bottom of the dialog) and then install it again. Best regards, Andrey Ivashov. Edited by user 05 September 2016 17:23:09(UTC)
| Reason: Not specified
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,641   Was thanked: 1400 time(s) in 817 post(s)
My mistake, sorry for this. I forgot why I did it. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
SMath Studio Forum
Archive
