Offline fred47
#1 Posted : 06 August 2016 02:19:36(UTC)
fred47
I have run into a problem with using units which are reciprocals - specifically Ohms and Siemens.
If I try to add a quantity with units Ohms to the reciprocal of a quantity with units Siemens, an error occurs: Units don't match.
Due to computer limitations where I am presently, I have only text entry.
Example:
Ra := 1 Ohm
Ga := 1 S
Rsum := Ra + 1/Ga = "units don't match"
But they do cancel:
Rprod := Ra * Ga = 1
Is there a work-around I'm missing somehow?
Thanks,
Fred
Edited by moderator 06 August 2016 16:26:53(UTC)  | Reason: Not specified
#2 Posted : 06 August 2016 16:20:10(UTC)
Hello Fred,
it is a bug; as workaround you can transit through a 3rd variable with symbolic optimization on his definition, then it is possible to evaluate numerically this variable in a separate region (see the cloud example)
Edited by user 06 August 2016 16:22:01(UTC)  | Reason: Not specified
Offline nierges
#3 Posted : 18 August 2016 11:45:41(UTC)
nierges
I was trying to implement a formula to calculate needed inductance on a flyback transformer and the program reports that units do not match. However splitting the formula in smaller pieces I was able to get the result out of it.
units dont match.sm (35kb) downloaded 36 time(s).
Thank you.
#4 Posted : 18 August 2016 11:53:04(UTC)
It is the same bug as the one shown in the first post, so I moved your post here.
The problem is related to the numeric evaluation, but there is a workaround:
- remove the RHS (the evaluation = and all after it)
- change optimization to symbolical
- show the result alone (Lp=#)
Bug reported as SS-2368
Edited by user 19 August 2016 18:08:50(UTC)  | Reason: marked as FIXED
on 19/08/2016(UTC)
Offline nierges
#5 Posted : 19 August 2016 11:11:59(UTC)
nierges
Thank you Davide, seems to work following your advice.
Emil
Offline Andrey Ivashov
#6 Posted : 19 August 2016 18:07:49(UTC)
Both issues fixed. See latest available nightly build: http://en.smath.info/for...073--19-August-2016.aspx
on 20/08/2016(UTC)
