Joined: 11/03/2011(UTC) Posts: 1 Location: Melbourne, Australia
This is an extremely useful and excellent program.
One improvement I have determined is if the units could be filtered to show only the relevant units for input and output values in the Viewer. That way the end user may not enter the wrong type of unit. Some end users may not be engineers or mathematicians so may make errors this way.
For example if the inputs/outputs are in pressure units, only the same unit type could be accessed, such as bar, kPa, ksf, ksi, Pa, psi, psf, MPa or if Force is the unit then only N, kN, kgf, kip, tonnef etc.
If the unit type could somehow be locked in when the Studio sheet is published to the Viewer.
