  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,592   Was thanked: 1929 time(s) in 654 post(s)
SMath Studio 0.98.6060 available - SS-2364: Version is added to Title bar when SMath Studio started as a Portable version;
- Always on top feature implemented and available in View menu;
- Rendering logic of the region with Description activated improved (one can set cursor on the worksheet by clicking in the area between region content and description);
- Plug-ns compatibility issue fixed;
- Back-compatibility improved for the existing worksheets (related to eval()/sum() functions);
- Critical issue happened sometimes on equation editing fixed;
- SS-2362: Debugging: Issue when it was not possible toggle breakpoint after content of placeholder is changed;
- Debugging: Watch Panel updated to show current break point expression in the watch list (often useful because some equation lines may be optimized and their real view may differ from initially created by user);
- Debugging: Debugging enabled in Plots;
- Silent mode: Abort on exceeded time fixed;
- Silent mode: Worksheets testing improved to show progress and correctly display differences;
- Silent mode: Added "-w" argument allows to limit max evaluation time per worksheet.
Download Edited by user 04 August 2016 21:39:13(UTC)
| Reason: Not specified
 9 users thanked Andrey Ivashov for this useful post.
on 04/08/2016(UTC), on 04/08/2016(UTC), on 05/08/2016(UTC), on 05/08/2016(UTC), on 05/08/2016(UTC), on 05/08/2016(UTC), on 05/08/2016(UTC), on 08/08/2016(UTC), on 10/08/2016(UTC)
Joined: 05/03/2009(UTC) Posts: 429   Location: USA Was thanked: 17 time(s) in 15 post(s)
Originally Posted by: Andrey Ivashov  - SS-2364: Version is added to Title bar when SMath Studio started as a Portable version;
I am assuming this is the unofficial portable version by mkraska ... any headway at making SMath officially portable again? Edited by user 10 August 2016 19:29:34(UTC)
Joined: 23/12/2011(UTC) Posts: 296   Location: italy Was thanked: 103 time(s) in 87 post(s)
ELsid, if you are looking in the forum "Portable Version" of "David Carpi", you will find the procedure for installing the latest version available as portable. It uses the Linux version. It could refer to this, but I have not tried it with this version.
 1 user thanked PompelmoTell for this useful post.
  Rank: Administration Groups: Registered, Administrators, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740   Was thanked: 318 time(s) in 268 post(s)
It seems that from today (15-avg-16) a new nightly build is available 0.98(build 6071). There is not yet the announcement on the Forum. It did not happen to me before (update available but no "Latest changes" available on the Forum), therefore I suppose Andrey did not have time to put the news about it on the Download section. Regards, Radovan Edited by user 15 August 2016 19:04:26(UTC)
