SMath Studio Forum
Bugs & Problems
[SMath Viewer PRO] SV vs third-party plug-ins (Regions)
Hello Carlos, I haven't understood what the Viewer was designed for. That's personal only. Maybe for the facility to add comments ? In this typical image, I can add as much as desired to a accommodate each particular application. I understand your point: Commercial Viewer does NOT capture the plot. Jean
Hi Jean : Thank you for your comments. I explain how I see the use of Smath Viewer. A program was developed to calculate or design something , in order that almost anyone can use it with minimal knowledge. The person using it , simply by changing the input data , this can calculate or design element in smaller or larger size . The person does not see the formulas or source code . Then Smath Viewer is ideal to be used by almost anyone . In my case, I am trying to develop a program to calculate and design Wastewater treatment Activated Sludge fine bubbles Plants . The graphical X -Y plot , use it to graphically display the distribution of air diffusers . Some screenshots Small Plant (two diffusers). A slightly larger plant (60 and 48 diffusers)
4 users thanked CBG for this useful post.
on 29/07/2016(UTC), on 29/07/2016(UTC), on 30/07/2016(UTC), on 05/08/2016(UTC)
Thanks Carlos. A great tool the Viewer !
Originally Posted by: CBG Commercial Smath Viewer does not display the graphical X -Y Plot This is because SMath Viewer Pro doesn't support third-party plug-ins (because of technical challenges). I'm working on it...
Andrey
Thanks for your reply-
But I have curious to know , because the free version of Smath Viewer does support the Plugin X -Y Plot, and PRO version does not , if it is assumed that the PRO version has more features .
Carlos
You are right. But the reason of why SMath Viewer Pro costs nothing is that it is not actually ready yet. It will support third-party plug-ins when I will implement it.
Thank you very much.
Best Regards.
Carlos
SMath Studio Forum
Bugs & Problems
