SMath Studio Forum
Samples
Method A.B. Draghilev and animation spatial mechanisms
Joined: 15/07/2010(UTC) Posts: 437   Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Jean Giraud ,here it is your animation without the display on the 2D graf  3d.sm (447kb) downloaded 41 time(s).
Was thanked: 73 time(s) in 54 post(s)
Hello Jean , It would be better to put the animation in a 3/4 view . Would that be possible?
Best Regard
Carlos
Joined: 04/07/2015(UTC) Posts: 6,406  Was thanked: 928 time(s) in 756 post(s)
Originally Posted by: CBG  Hello Jean , It would be better to put the animation in a 3/4 view . Would that be possible?
Best Regard
Carlos Hello Carlos, "3/4 view" : like setting TV screen 3/4 or other style. You could scale the vertical vector, it would end being hugly. The x, y ranges in the CreateMesh have these limits under the hood. These limits are what make the Breather so pleasant like the Eiffel shape. Attached the 4 fixed orientations. Jean  Rotate Breather [4 Orientations].sm (18kb) downloaded 40 time(s).
Hello Jean. Excellent !!! But the file does not work for me, it indicates that M is not defined. Besides, I can not update the Maple plugin . On the other hand , Is it possible to see a 3/4 view from the Z axis?, I think it will better. Thank you. Carlos
Puma manipulator The working body of the manipulator moves along a given trajectory. To solve the problem, 5 equations with six unknowns were used. -Two link length equations -Equations of the condition that the links are in the same plane -Two space curve equations  Puma.sm (35kb) downloaded 22 time(s).Edited by user 13 March 2022 08:20:14(UTC)
| Reason: Not specified
 4 users thanked Ber7 for this useful post.
on 24/01/2022(UTC), on 24/01/2022(UTC), on 24/01/2022(UTC), on 24/01/2022(UTC)
 1 user thanked Ber7 for this useful post.
Originally Posted by: Ber7  Puma manipulator The working body of the manipulator moves along a given trajectory. To solve the problem, 5 equations with six unknowns were used. -Two link length equations -Equations of the condition that the links are in the same plane -Two space curve equations
In my option this system have
- Rigid link between 2 points
- 2 equations about belonging 2 points to the same sphere
- x2*y1-y2*x1
- some sin curve
Don't quite understand about x2*y1-y2*x1. Some spherical meaning? The difference between azimuth angles is not perfect equal. Replace with atan(y1/x1)-atan(y2/x2) to make perfect equal.
Originally Posted by: grelkin2  In my option this system have
Hi grelkin2. Please provide your equations so that the solutions can be compared. Best regards
Hmm, atan is expensive function, may be switching to spherical coordinate reduces number of steps initial vector 1.5355 0.8065 0.9959 1.9127 0.5761 0.0989 precision 1e-3 sphere(1,0,0,0) sphere(2,0,0,0) line(1,2) atan(x[1]/x[0])-atan(x[4]/x[3]) .5*sin(8*x[3]+9*x[4])-x[5]
Originally Posted by: Ber7  The Schatz mechanism The Schatz mechanism provides a perfect dynamic balance оf both centripetal and centrifugal forces as patented in 1971 as the only widely-used overconstrained linkages in industry, mainly used as spatial mixing-machines.
It has equation four points are coplanar Maxima gives me this equation is exactly is zero with any coordinate
The Schatz mechanism. Modernized animation.
 Schatz Linkage.sm (144kb) downloaded 20 time(s).
 2 users thanked Ber7 for this useful post.
on 18/03/2022(UTC), on 18/03/2022(UTC)
Joined: 30/09/2012(UTC) Posts: 33  Was thanked: 10 time(s) in 5 post(s)
In the Schatz mechanism, the length of the middle link does not change, and the axes of the middle link are constantly perpendicular to each other. In this case, one vertical rack (input link) rotates uniformly. This is for those who are interested. And Draghilev's method does not directly work in this case.
The error of changing the length of the middle link is ε = 10^{-7} You can also check the perpendicularity of the hinges  Proverka.sm (48kb) downloaded 15 time(s).Edited by user 24 March 2022 23:17:23(UTC)
To @Ber7, @алексей_алексей Not really understand Schatz system Please correct me if I'm wrong  AO=const, BO'=const, AB=const С extra point, AC=CB Still two equation, one as I understand Z1*Z2=const? and the last one is Normals to planes ABO and ABO' must be perpendicular? Magenta lines are normal vectors to ABO and ABO'  Pause and check perpendicularity  Rotate the view to get best observation Make animation in mov format for the best quality, If not working, message me Animation schatz.mov (286kb) downloaded 6 time(s).
Please, read the article at the link post # 27.The length of each link is equal to one, and the distance between the vertical axes is equal to the root of 3.Equation x3*x6 = 1/2 derived from Equation (6) of this paper. "Normals to planes ABO and ABO' must be perpendicular?" Yes. Regards
 sinθ_2*sinθ_5=const θ_2, θ_5 rotating angles around the ZA2, ZB2 rotating axis, difficult equation You cann't use any intial values for coordinates because ABO and ABO' must be perpendicular, if you fixed all coordinates but one, you've got Quadratic equation. If you have no real roots change others coordinates and try again. Also you can change equation to be cos(α)=const, α≠90, α is angle between normals
SMath Studio Forum
Samples
