Offline CBG
#1 Posted : 28 July 2016 19:48:55(UTC)
CBG
Commercial Smath Viewer does not display the graphical X -Y Plot
Carlos
Human eye.sm (7kb) downloaded 42 time(s).
Human eye_Comm_and_Free.zip (1,106kb) downloaded 38 time(s).
Edited by moderator 10 September 2016 20:36:02(UTC)  | Reason: title updated
#2 Posted : 29 July 2016 15:17:27(UTC)
Hello Carlos,
I haven't understood what the Viewer was designed for. That's personal only.
Maybe for the facility to add comments ? In this typical image, I can add as
much as desired to a accommodate each particular application.
I understand your point: Commercial Viewer does NOT capture the plot.
Offline CBG
#3 Posted : 29 July 2016 19:05:27(UTC)
CBG
Hi Jean :
Thank you for your comments.
I explain how I see the use of Smath Viewer.
A program was developed to calculate or design something , in order that almost anyone can use it with minimal knowledge.
The person using it , simply by changing the input data , this can calculate or design element in smaller or larger size .
The person does not see the formulas or source code . Then Smath Viewer is ideal to be used by almost anyone .
In my case, I am trying to develop a program to calculate and design Wastewater treatment Activated Sludge fine bubbles Plants .
The graphical X -Y plot , use it to graphically display the distribution of air diffusers .
Some screenshots
Small Plant (two diffusers).
A slightly larger plant (60 and 48 diffusers)
thanks 4 users thanked CBG for this useful post.
on 29/07/2016(UTC),  on 29/07/2016(UTC),  on 30/07/2016(UTC),  on 05/08/2016(UTC)
#4 Posted : 30 July 2016 02:26:04(UTC)
Thanks Carlos. A great tool the Viewer !
Offline Andrey Ivashov
#5 Posted : 05 August 2016 17:29:42(UTC)
This is because SMath Viewer Pro doesn't support third-party plug-ins (because of technical challenges). I'm working on it...
Offline CBG
#6 Posted : 05 August 2016 21:34:52(UTC)
CBG
Andrey
Thanks for your reply-
But I have curious to know , because the free version of Smath Viewer does support the Plugin X -Y Plot, and PRO version does not , if it is assumed that the PRO version has more features .
Carlos
#7 Posted : 06 August 2016 00:11:22(UTC)
You are right. But the reason of why SMath Viewer Pro costs nothing is that it is not actually ready yet.
It will support third-party plug-ins when I will implement it.
Offline CBG
#8 Posted : 06 August 2016 02:32:53(UTC)
CBG
Thank you very much.
Best Regards.
Carlos
