3 Pages123>
Offline uni
#1 Posted : 20 June 2014 13:30:40(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Script Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
C# and VB.Net:
Do not use directive "using". You just need to fill function body.
List of specified namespaces (c#, vn.net):
System
System.IO
System.Diagnostics
System.Xml
System.Linq
System.Text
System.Reflection
System.Collections.Generic
System.Globalization
System.Drawing
System.Drawing.Drawing2D
System.Drawing.Imaging
SMath.Manager
SMath.Controls
SMath.Math
SMath.Math.Numeric
List of specified namespaces (python (import * used)):
System
SMath.Manager
SMath.Controls
SMath.Math
SMath.Math.Numeric
Predefined variables available in script (c#, vn.net, python): Store store.
Links:
1. Fast Colored TextBox for Syntax Highlighting (Pavel Torgashov).
2. Runtime-генерирование .Net-кода для тех, кому некогда (Андрей Мартынов).
3. Scripting .NET Applications with IronPython (Jerome Terry).
4. SMath Studio Core documentation (CHM)
Examples:
Script. CurrentDirectory.sm (6kb) downloaded 220 time(s).
Script. CurrentDirectory.pdf (52kb) downloaded 270 time(s).
Script. Show time.sm (5kb) downloaded 157 time(s).
Script. Show time.pdf (43kb) downloaded 195 time(s).
Script. InOut.sm (9kb) downloaded 267 time(s).
Script. InOut.pdf (31kb) downloaded 324 time(s).
Edited by user 14 November 2019 13:16:56(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 21/06/2014(UTC),  on 30/12/2021(UTC)
Offline uni
#2 Posted : 20 June 2014 18:50:01(UTC)
uni
Updated.
uni attached the following image(s):
Offline uni
#3 Posted : 21 June 2014 08:53:48(UTC)
uni
Updated. Python also works but w/o syntax highlighting.
File Attachment(s):
Python. Example 1.sm (4kb) downloaded 275 time(s).
Offline uni
#4 Posted : 28 October 2014 23:10:34(UTC)
uni
Updated. Small improvements.
EDIT:
Test (c#).
Script:
Edited by user 09 March 2017 10:11:23(UTC)  | Reason: Not specified
Offline uni
#5 Posted : 01 February 2016 20:08:32(UTC)
uni
The source code has been restored, updated and uploaded to svn. Something does not work yet (last example). The plugin is not available, because Release Manager can't build it (too complex I think).
Edited by user 01 February 2016 20:10:13(UTC)  | Reason: Not specified
on 01/02/2016(UTC)
Offline uni
#6 Posted : 02 February 2016 10:44:50(UTC)
uni
Updated (svn). Now last example works and we are waiting when Andrey fix the Release Manager.
on 03/02/2016(UTC)
Offline uni
#7 Posted : 09 February 2016 07:11:56(UTC)
uni
Updated. Now available.
on 09/02/2016(UTC)
Offline Razonar
#8 Posted : 24 May 2016 00:12:44(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Hi Uni. Admirable work, thanks a lot for this plugin. Just few questions:
- From where plugin's take c#, vb.net and python ¿(i.e. came when plugin is downloaded)?
- ¿Can call nympi or Sci python?
- ¿Can you show how to modify some SMtah's vector or matrix variable? In other words, ¿there are an output, avoiding handling files, to smath worksheet or only can view results in the trace window?
- Not related with your plugin, but ... easy asking you: SMath don't have maple's traperror or mathcad onerror functions?
Have a nice day.
Edited by user 24 May 2016 00:14:18(UTC)  | Reason: Not specified
Offline uni
#9 Posted : 25 May 2016 10:41:58(UTC)
uni
c#, vn.net from the .Net Framework which is already installed on your PC.
As for the python I used IronPython which is a part of the plugin.
Not shure about numpi and Sci. I think it is impossible use them now.
You can modify and add definitions to the worksheet dynamically (inside the script). It not so simple to show how you can use this, I need a time to make an example.
Offline Tinu
#10 Posted : 27 May 2016 14:11:50(UTC)
Tinu
Rank: Member
Switzerland
Was thanked: 14 time(s) in 12 post(s)
Examples (specially regarding Python) would be greatly appreciated!Clap
Tinu
thanks 1 user thanked Tinu for this useful post.
on 27/05/2016(UTC)
Offline ahmetanildindar
#11 Posted : 06 August 2016 16:22:58(UTC)
ahmetanildindar
Turkey
Dear all,
I donwloaded @uni's #3 smath file. Tried to understand but it seems more explanation is needed for low level users like me Good
It would be really perfect having Python scripts running within Smath.
Is there any ongoing effort?
++Ahmet
thanks 1 user thanked ahmetanildindar for this useful post.
on 02/03/2017(UTC)
Offline uni
#12 Posted : 02 March 2017 07:04:24(UTC)
uni
Updated. Variable terms added. Some namespaces declared implicit.
Script:
Edited by user 09 March 2017 09:56:44(UTC)  | Reason: Not specified
on 02/03/2017(UTC)
Offline uni
#13 Posted : 02 March 2017 21:51:49(UTC)
uni
Updated. Fixed some issues related to vb compiler.
on 03/03/2017(UTC)
Offline uni
#14 Posted : 04 March 2017 11:58:07(UTC)
uni
Updated. Examples added.
Edited by user 24 September 2018 19:33:40(UTC)  | Reason: Not specified
on 04/03/2017(UTC)
Offline uni
#15 Posted : 04 March 2017 18:44:52(UTC)
uni
Updated. Now more magic available.
Script:
Edited by user 09 March 2017 10:16:46(UTC)  | Reason: Not specified
on 04/03/2017(UTC)
Offline uni
#16 Posted : 06 March 2017 13:12:14(UTC)
uni
Updated. Another attempt to fix the problem related with the portable version. Martin, please try again. Now the tmp directory appears in the plugins directory and you need to remove it content manually periodically. Fix this later.
Edited by user 06 March 2017 13:14:43(UTC)  | Reason: Not specified
on 06/03/2017(UTC)
Offline mkraska
#17 Posted : 06 March 2017 17:09:45(UTC)
mkraska
Now working with the portable version, thanks. With maxima, we had quite some issues with temp dirs (interference between multiple smath instances or documents...
Offline uni
#18 Posted : 08 March 2017 10:12:54(UTC)
uni
Add definitions from list of strings. To get a textual representation we use [Ctrl+C], [Ctrl+V].
Script:
Edited by user 09 March 2017 09:55:54(UTC)  | Reason: Not specified
on 08/03/2017(UTC)
Offline uni
#19 Posted : 08 March 2017 19:32:48(UTC)
uni
String to matrix (c#).
Script:
Edited by user 09 March 2017 09:55:17(UTC)  | Reason: Not specified
on 09/03/2017(UTC)
Offline uni
#20 Posted : 22 March 2017 19:30:36(UTC)
uni
How to add unit.
Script:
Edited by user 24 September 2018 19:51:17(UTC)  | Reason: Not specified
Similar Topics
I can't install the SCRIPT REGION plugin (Questions)
by Orlando 25/05/2024 12:51:59(UTC)
Paste text does't works on Script Region (Bugs & Problems)
by oscampo 03/07/2021 01:14:53(UTC)
Script Region video (Extensions)
by KhasanMamaev 14/11/2019 07:58:50(UTC)
3 Pages123>
