Offline gregben
#1 Posted : 09 September 2010 08:34:40(UTC)
gregben
Was thanked: 2 time(s) in 1 post(s)
I want to do the following:
length := 16 in
diameter := trunc(((length + 2 in)/pi)in)
diameter = 7.0000 in
I need to be able to set the result of a parenthesis-enclosed
expression
to inch units, then apply the trunc() function to
it, retaining the units as inches. At the moment, it
seems as though it is only possible to apply the trunc()
function to the results of computation in parenthesis
using SI units, so the result becomes 0 because the
value of (length + 2 in)/pi is 0.1779 m.
The workaround seems to be to not use units at all,
but that is not nearly as nice.
Offline omorr
#2 Posted : 09 September 2010 09:32:46(UTC)
omorr
Serbia
What about this
The argument inside "trunc" divide by the desired unit (in - in this case).
Then, the entire expression multiply by the desired unit (in - in this case)
In general, when you do not want SI units - divide the expression by the desired unit.
Then you will get the dimensionless number with the value in the desired unit.
Edited by user 09 September 2010 11:43:59(UTC)  | Reason: Not specified
Offline gregben
#3 Posted : 09 September 2010 18:33:26(UTC)
gregben
This worked well. Thank you!
