3 Pages<123
#41 Posted : 22 April 2016 03:43:26(UTC)
Was thanked: 751 time(s) in 592 post(s)
Originally Posted by: Alex.M Go to Quoted Post
It is useful when you use one slider to fine tune several independent values (by switching between them)
Alex,
I don't understand "completely" your tune several independent values.
I suppose you mean adjusting "parameters" wrt model/modeling.
That was my comment reply to Sergio/Davide. Keep reading "Samples"
that's where you will find model functions already done. The last
two typical: Alcotest, Water viscosity. Modeling is a life time
addiction, no cure for that except the day I will suck the roots,
no urgency for that day ! can't even backward the clocking slider/timer.
Cheers, Jean
Offline Alex M.
#42 Posted : 25 April 2016 07:06:08(UTC)
Alex M.
Was thanked: 119 time(s) in 92 post(s)
Originally Posted by: Davide Carpi Go to Quoted Post
I can do it, but this means that the slider will be used just as visual feedback, since any user change triggers the evaluation that restore the input value.
Alex,
Davide and Jean,
This is how a predefined initial slider value would have been used for me before and can be used by someone in future:
<block of calcs outputs slider value>
-> fine tune the value using the slider
-> the value to a global variable which is passed back to the block of calcs
What I did before:
Have two sliders that define XY coordinates of the point. Use only those two sliders to modify coordinates of about 15 points. This would have been possible if the slider value could be preset from the workbook:
-> select a point
-> slider is positioned at the current point's coordinate
-> adjust the slider
-> point coordinate is stored in a global variable and becomes the new default position of the slider
-> select different point
-> repeat
To be fair I have abandoned the XY coordinate definition method in favor of using modeler region for that purpose. However the example demonstrates that presetting the initial slider position can be useful in certain cases.
#43 Posted : 25 April 2016 16:07:12(UTC)
Thanks Alex,
I understand why the slider is useful for you: set the coordinates of a drawing shape.
Not like me: tuning parameters of a model function [conjointly OriginLab, Smath Genfit]
Cheers, Jean.
Eastern Canada, still very fresh temperature.
#44 Posted : 26 April 2016 05:59:01(UTC)
... forgot one of the most pertinant use of the slider:
slide the convolving function [sliding integration].
One of so many RemToDo.
#45 Posted : 07 May 2016 20:20:50(UTC)
Was thanked: 1123 time(s) in 733 post(s)
PLUGIN UPDATED SMath Studio 0.98.5952 Nightly Build only Beta
  • SMath Viewer: the same slider of the canvas will be used, instead of the standard .NET Trackbar; this makes the project more consistent and solves several bugs even in the worksheet; moreover allows to remove the scale factor;
  • Scale factor removed; decimal values are now a valid input.
    ** if you don't have settings from canvas, transition is fully driven by the region;
    ** if you have settings from canvas and scale factor != 1, you have to update the input values from the canvas and change the name of the variable that contains the input settings or save and reopen the worksheet (an error message will be shown inside the region, output value will be undefined until you fix the settings);
  • Added new key for settings from canvas: "value" (if you want to disable input from users, region will be used just as a visual feedback);
  • Added new key for settings from canvas: "initial value" (the value of the region will be set as this value if it changes);
Slider Region.sm (29kb) downloaded 44 time(s).
P.S. If everything works fine, I'll relase a stable version for SS from 0.97.5346 to latest
Edited by user 07 May 2016 20:43:52(UTC)  | Reason: Not specified
on 22/08/2016(UTC)
Offline alyles
#46 Posted : 22 August 2016 16:55:57(UTC)
alyles
Was thanked: 70 time(s) in 45 post(s)
When I show the description of the slider, I receive an exception when trying to open the settings.
Picture and Exception text attached. I'm using SMath 0.98 (build: 6077) and plugin version (0.4.6078.4892).
exception.txt (26kb) downloaded 25 time(s).
#47 Posted : 22 August 2016 17:47:07(UTC)
Fixed & updated, thank you!
on 22/08/2016(UTC),  on 22/08/2016(UTC)
3 Pages<123
