It is possible to see arithmetic, in example on summation?? Not only a result ? And another question: If I want sum 2 diffrent Matrix, in example 2 column/3 verse and 4 column/2 verse is it possible to do this ?? irol:
Bardock wrote:It is possible to see arithmetic, in example on summation?? Not only a result ? Not sure that I understand your question... If you mean that you want to see every step of the calculation, then no. Program could only show you a result. Bardock wrote:If I want sum 2 diffrent Matrix, in example 2 column/3 verse and 4 column/2 verse is it possible to do this ?? irol: There is no rules in math to do this. Matrices could be summed up only if the number of rows and columns of both matrices are equal.
