2 Pages<12
#21 Posted : 10 March 2016 20:34:59(UTC)
Was thanked: 1279 time(s) in 841 post(s)
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- Fixed content update in SMath Viewer;
- Added context menu item to access settings' form;
Please note: if you use symbolic data as content and the content changes, this may mess up the form layout (as for now a feature to refresh the whole layout of the viewer is not available).
Edited by user 11 March 2016 01:47:08(UTC)  | Reason: Not specified
on 10/03/2016(UTC)
Offline Jason McCool
#22 Posted : 08 June 2016 17:23:31(UTC)
Jason McCool
Was thanked: 9 time(s) in 7 post(s)
Thank you very much for this plugin. I have been using it for several of my engineering worksheets for several months now and find it very useful. I notice it does not show up under the plugins tab of the Extensions Manager like it did when I first installed it. Is this still being developed? If so, is there a way to be able to change the width of the ComboListBox? The Combobox function has resizing grips, but doesn't include a dropdown list that I really need, like your plugin does. Is that something could be added, either through grips, or through an additional width parameter in the Settings dialog? Thank you again for all your hard work!
Jason
Jason McCool
Robbins Engineering
Little Rock, AR, USA
#23 Posted : 08 June 2016 19:12:30(UTC)
You're very welcome Jason Good
I'm not sure on what you mean here, but if you mean that there aren't updates in the "Online gallery" is only because there weren't reports of bugs or new features added. But yes, the plugin is under development.
Maybe... the main problem is just about the minimum width, because I can't add ellipsis to truncate "properly" math objects; I'll see what I can do...
#24 Posted : 24 June 2020 14:08:53(UTC)
PLUGIN UPDATED SMath Studio 0.99.7251 and later
  • Enhanced alignments of embedded MathRegions;
on 24/06/2020(UTC)
Offline joaobr
#25 Posted : 22 November 2020 17:08:35(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Hi! The description of a ComboBoxList region can't be moved around or resized. Same problem in the Numeric UpDown region.
#26 Posted : 23 November 2020 12:19:01(UTC)
Hello joaobr Offline ,
confirmed. It is probably because these regions have fixed layout and the property is somehow inherited to the description tooltip, I have to check if this is intended.
Offline joaobr
#27 Posted : 23 November 2020 14:51:34(UTC)
joaobr
Brazil
Thank you for your reply!
#28 Posted : 07 February 2021 02:03:38(UTC)
Jason McCool
Hello, Davide. I was curious if there was any way to set the ComboBoxList source programmatically rather than through the Settings dialog. What I'd like to do - if it's possible - is to be able to use an if statement to control the source and populate the dropdown options for this combobox based on which radio button was picked by a user earlier in the worksheet. I don't know if that's even possible now, but it might be a nice feature to add someday if it's not Biggrin
Something like
If option 1 then
Combobox1.source = matrix x
Else
Combobox1.source = matrix y
There's probably some issues there with needing to define the source first for the box to be usable, but the properties not being defined prior to the combobox's location in the worksheet, or something along those lines. But I thought I'd mention it. Also, sometimes, the dropdown list is transparent and equations/text below the combobox show through it and make it hard to read. It doesn't do that all the time, though, so I'm not sure on a possible cause, but I thought it'd be worth mentioning as well.
Thanks!
Jason
Jason McCool
Robbins Engineering
Offline overlord
#29 Posted : 07 February 2021 17:03:41(UTC)
Turkey
Was thanked: 409 time(s) in 275 post(s)
Thanks!
Jason
It is possible already, maybe not the way you mentioned but it gets the job done.
combolist.sm (5kb) downloaded 44 time(s).
thanks 2 users thanked overlord for this useful post.
on 08/02/2021(UTC),  on 08/02/2021(UTC)
#30 Posted : 08 February 2021 21:23:45(UTC)
Jason McCool
Very nice! That worked just fine. Thank you!
Jason
Jason McCool
Robbins Engineering
Offline joaobr
#31 Posted : 20 June 2022 17:37:54(UTC)
joaobr
Brazil
Hi! I can't move the description of the Combo Box List region to the left. It is stucked above the region. Could this functionality be implemented? It would improve the look of many of my scripts. Thanks in advance!
Offline joaobr
#32 Posted : 20 June 2022 17:41:06(UTC)
joaobr
Brazil
In addition, the width of this region could adjust to the content and/or fixed based on the longest input data. Just an idea!
#33 Posted : 20 June 2022 21:16:38(UTC)
Hello, I'll check it, probably a wrong initialization by me.
I'll see what I can do, it is something that involves several things.
on 20/06/2022(UTC)
Offline Prmtv
#34 Posted : 31 July 2022 20:59:55(UTC)
Prmtv
Rank: Member
Hello. I found out an interesting feature. If i want "Show Description" at the object this plugin then if the text is too long, there are problems in SMathViewer. Text is either not included completely or is cut in half.
Maybe this is the problem called "joaobr" a few posts up.
#35 Posted : 02 August 2022 08:50:54(UTC)
no, they are unrelated. I'll check this too.
#36 Posted : 04 August 2022 21:19:01(UTC)
I've enabled multiline labels in Viewer, update and try again, it should work as expected now.
2 Pages<12
