3 Pages123>
Online uni
#1 Posted : 14 February 2016 11:58:08(UTC)
uni
Was thanked: 1381 time(s) in 806 post(s)
DISLIN 11.5
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources EULA
DISLIN is a high-level plotting library for displaying data as curves, polar plots, bar graphs, pie charts, 3D-color plots, surfaces, contours and maps.
Note: Paths to image and temp files must exist. Use double slashes ( '\\' ) for DISLIN functions.
Click to enlarge Click to enlarge Click to enlarge Click to enlarge Click to enlarge
Examples:
DISLIN. Example 1.sm (96kb) downloaded 129 time(s).
DISLIN. Example 1.pdf (288kb) downloaded 136 time(s).
DISLIN. Example 2.pdf (236kb) downloaded 174 time(s).
DISLIN. Example 2.sm (123kb) downloaded 128 time(s).
DISLIN. Example 3.pdf (955kb) downloaded 149 time(s).
DISLIN. Example 3.sm (309kb) downloaded 114 time(s).
DISLIN. Example 4.sm (87kb) downloaded 118 time(s).
DISLIN. Example 4.pdf (234kb) downloaded 140 time(s).
DISLIN. Example 5.sm (120kb) downloaded 108 time(s).
DISLIN. Example 5.pdf (431kb) downloaded 125 time(s).
DISLIN. Example 6.sm (203kb) downloaded 123 time(s).
DISLIN. Example 6.pdf (658kb) downloaded 185 time(s).
Links:
1. DISLIN Web site .
2. DISLIN HTML Manual. Contents .
3. Appendix D. Index .
4. A General-Purpose Scientific and Engineering Plotting Library that Includes Smith Charts (PDF file) by Dr. Scott Best from SiberSci, LLC.
Edited by user 01 June 2022 20:43:55(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 14/02/2016(UTC),  on 14/02/2016(UTC),  on 14/02/2016(UTC)
#2 Posted : 14 February 2016 19:32:20(UTC)
Was thanked: 1378 time(s) in 902 post(s)
A complete set of plots in a single plugin, this is wonderful Clap
I cannot evaluate the functions, seems something is missing Huh
Online uni
#3 Posted : 14 February 2016 19:46:46(UTC)
uni
Make sure to use the latest version. Restart SMath Studio if functions unavailable. Turn off autocalc mode.
Something wrong with the SMath Studio I think, there is no working example because I can't save the worksheet. But if you want to try I can get the list of functions which was used in my example (you must manually enter each function ([Ctrl+C] [Ctrl+V]) and press equal sign).
Test example:
Code:
dislin.metafl("svg")
dislin.setfil("d:\\file.svg")
dislin.errdev("FILE")
dislin.errfil("d:\\out.txt")
dislin.filmod("DELETE")
dislin.disini(0)
dislin.disfin(0)
Code:
N:50
for(n,range(1,N),line(el(x,n):{2*π}/N*(n-1),el(y1,n):sin({2*π}/N*(n-1)),el(y2,n):cos({2*π}/N*(n-1)),3,1))
dislin.units("INCH")
dislin.page(800,600)
dislin.disini(0)
dislin.reset("ALL")
dislin.pagera(0)
dislin.complx(0)
dislin.chacod("UTF8")
dislin.axspos(100,520)
dislin.axslen(650,400)
dislin.name("Ось X","X")
dislin.name("Ось Y","Y")
dislin.labdig(1,"X")
dislin.ticks(5,"XY")
dislin.titlin("Пример работы с графиками",1)
dislin.titlin("Функции: sin(x), cos(x)",3)
dislin.linmod("ON","SMOOTH")
dislin.graf(0,2*π,0,π/4,-1,1,-1,0.5)
dislin.color("blue")
dislin.curve(x,y1,N)
dislin.color("red")
dislin.curve(x,y2,N)
dislin.color("fore")
dislin.title(0)
dislin.dash(0)
dislin.grid(1,1)
dislin.solid(0)
dislin.xaxgit(0)
dislin.disfin(0)
EDIT: Tested only with Win x32. Don't forget to show log.txt (in the plugin directory: 23831ed7-5051-46d5-aaa8-b2fb40002ec1\x.x.x.x\) if something not working.
Edited by user 14 February 2016 20:30:42(UTC)  | Reason: Not specified
#4 Posted : 14 February 2016 20:49:05(UTC)
Thank you Viacheslav, disabling the recalculation I can save your example and I experienced some small improvements (still doesn't works):
Files (worksheet, log, output svg): DISLIN.zip (20kb) downloaded 45 time(s).
"Functions not defined":
Aside note, crash occours if the output directory doesn't exists;
Online uni
#5 Posted : 14 February 2016 21:01:02(UTC)
uni
I forgot to say that you should not save the file! Look at the contents. Function names lost prefix. Therefore it is necessary to follow exactly what I write.
1. Restart SMath Studio.
2. Turn off autocalc.
3. Do not save the worksheet!
4. Enter functions line by line, don't forget to add = (do not press F9!).
Code:
dislin.errdev("file")
dislin.filmod("delete")
dislin.disini(0)
dislin.disfin(0)
5. Now you can press F9.
EDIT: The library interface is ugly. You must read the user manual before continuing experiments. The order of calling functions is important.
Edited by user 14 February 2016 21:07:37(UTC)  | Reason: Not specified
on 14/02/2016(UTC),  on 15/02/2016(UTC)
Online uni
#6 Posted : 14 February 2016 22:50:06(UTC)
uni
There is a bug in SMath Studio I think, we must wait until Andrey say something about saving function names with points. As for file names, you can use any with some rules. One of them - double slash. I use Image Region plugin for visualization, you can use not only svg but other formats too: png, ... (see online help).
on 14/02/2016(UTC)
Offline Alex M.
#7 Posted : 14 February 2016 23:01:08(UTC)
Alex M.
Uni, great work! Looks like we just might get the right plotting tool in SMath.
Do you think you might have time to integrate DISLIN into a stand alone region?
If you do so, you might get around the function saving bug (since functions will not be exposed to SMath directly), and more importantly, to incorporate all the formatting options into a settings menu instead of typing them one-by-one.
Thank you for your hard work and time spent
Online uni
#8 Posted : 14 February 2016 23:38:23(UTC)
uni
Yes, like in assembler it is hard to write what you want. DISLIN is a graphical assembler which contain 777 functions now. It is possible to write some wrapper for it or make a stand alone region but in these directions will be lost some original functionality. I created this plugin only for 3D plotting but after several experiments I see what these functions have a strange behavior with hidden lines. The result image has artifacts.
Online uni
#9 Posted : 24 February 2016 19:32:12(UTC)
uni
Updated. Problem fixed. Thanks to Andrey for the explanation.
DISLIN. Example1.sm (124kb) downloaded 171 time(s).
DISLIN. Example1.pdf (156kb) downloaded 261 time(s).
on 25/02/2016(UTC)
Online uni
#10 Posted : 24 February 2016 19:58:44(UTC)
uni
DISLIN 0.1.5898.14938 ?
Online uni
#11 Posted : 24 February 2016 20:08:58(UTC)
uni
This is because of other program settings. I'll fix it now.
on 24/02/2016(UTC),  on 25/02/2016(UTC)
Online uni
#12 Posted : 24 February 2016 20:26:37(UTC)
uni
Updated. Try now.
Online uni
#13 Posted : 24 February 2016 20:50:42(UTC)
uni
Later I'll try to show some examples. DISLIN collection is not fully implemented and I will try to solve this.
Online Manual
Edited by user 24 February 2016 20:52:47(UTC)  | Reason: Not specified
Offline frapuano
#14 Posted : 24 February 2016 22:53:36(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Strange on my system Smath crashes and I am forced to close the program.
The release installed is
Working under Windows 7 Professional
Franco
Offline frapuano
#15 Posted : 25 February 2016 00:02:35(UTC)
frapuano
You mean to uninstall all Smath even if I am using actually an updated version of Smath portable.
Franco
Offline Alex M.
#16 Posted : 25 February 2016 06:47:59(UTC)
Alex M.
I confirm SMath crash trying to open DISLIN.Example1.sm
Online uni
#17 Posted : 25 February 2016 08:25:01(UTC)
uni
I have Windows 7 Ultimate x64 and it works fine for me. Show me log.txt (in plugin folder). Maybe environment variable TEMP points to a long path and DISLIN can't get access to the temporary folder. My TEMP=C:\Temp
This is just a guess.
Offline frapuano
#18 Posted : 25 February 2016 12:37:10(UTC)
frapuano
Uninstalled everything using Windows uninstall , then deleted Smath directory and other directories linked to Smath (I guess).
Reinstalled again downloading the last release from the site ...same result ( I haven't restarted the LT in between ) .
The example file loads and after a little bit comes up the screen with : Smath Studio Desktop has stopped working ..
Moreover I do not find any log.txt in the plugin folder and any dslin.something else anywhere on my computer ...make me wonder if the DSLIN plug in has been really downloaded and stored somewhere.
Franco
#19 Posted : 25 February 2016 13:39:44(UTC)
Confirmed, as stated previously the crash is due to directory management.
You have to disable the auto recalculation, open the worksheet, change the directories, and then you can run the example provided by Viacheslav.
Log file is available only if SMath is running, deleted after closing.
Edited by user 25 February 2016 13:41:48(UTC)  | Reason: Not specified
on 25/02/2016(UTC),  on 25/02/2016(UTC)
Offline frapuano
#20 Posted : 25 February 2016 14:53:16(UTC)
frapuano
Davide
Doing as you suggest and renaming the files to c:\file.svg and c:\out.txt ( on my computer and using a double \\ in the DSLIN command ) creates the output file and I am able to read the svg file in Inkscape ...I have still problem due to my ignorance of the new Image region to visualize it in Smath ..but hope soon or later to succeed.
Thanks a lot and best regards
Franco
3 Pages123>
