2 Pages12>
#1 Posted : 06 February 2014 21:29:04(UTC)
Was thanked: 1267 time(s) in 833 post(s)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Numeric Up-Down Control.
  • requirements: SS 0.96.5146 or later;
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: Numeric up-down Region.sm (29kb) downloaded 33 time(s).;
  • languages: English;
  • main features:
    - Allowed inputs: region up/down buttons, + and - keys, mouse wheel; hold the input to have more increments.
    - Settings: double-click over the region.
    - Output: place a variable in the region placeholder.
    - Size driven by the value (manual resize not allowed).
    - Adds the same control in SMath Viewer.
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabelNumericUpDown | PathPicker | RadioButtonList | Slider
Edited by user 30 December 2021 01:52:25(UTC)  | Reason: documentation updated
thanks 5 users thanked Davide Carpi for this useful post.
on 07/02/2014(UTC),  on 07/02/2014(UTC),  on 07/02/2014(UTC),  on 07/02/2014(UTC),  on 09/03/2014(UTC)
#2 Posted : 18 March 2014 02:02:55(UTC)
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
- hidden the outer frame (still remains as transparent to avoid interferences with resize markers).
Edited by user 18 March 2014 02:05:05(UTC)  | Reason: Not specified
Offline mkraska
#3 Posted : 19 March 2014 02:18:44(UTC)
mkraska
Was thanked: 968 time(s) in 616 post(s)
Davide, it seems that description strings of the region are ignored in the viewer. Can that be changed or do I need to use sort of "nice" variable names?
File Attachment(s):
Notenschlüssel.sm (12kb) downloaded 102 time(s).
#4 Posted : 19 March 2014 02:48:19(UTC)
I'll do it Martin... previously I've noticed a bug, now seems that the description text it works Good
Edited by user 19 March 2014 22:13:38(UTC)  | Reason: Not specified
#5 Posted : 22 March 2014 20:44:41(UTC)
UPDATED
- SMath Viewer: uses the region description (if exist and is shown).
on 22/03/2014(UTC)
Offline PompelmoTell
#6 Posted : 22 July 2014 11:56:30(UTC)
PompelmoTell
Was thanked: 106 time(s) in 90 post(s)
Hello Davide,
It seems that the numeric up-down region remains active even when control is not checked
After using the mouse wheel
win7
smath 0.97 build 5301
on 22/07/2014(UTC)
#7 Posted : 22 July 2014 12:48:40(UTC)
Grazie Sergio Wink
Fixed, PLUGIN UPDATED
on 22/07/2014(UTC)
#8 Posted : 08 October 2015 16:36:19(UTC)
I think it is possible...
Something like in the attachment? The entry point for the variable would be the form (like in table region) or in the context menu (like in the modeller region); this should grant customizable settings for every region, when you have multiple regions.
on 08/10/2015(UTC)
#9 Posted : 28 October 2015 17:55:55(UTC)
PLUGIN UPDATED SMath Studio 0.97.5737
- Introduced settings from canvas (see attachment);
- History Undo/Redo now is supported;
canvas settings.sm (18kb) downloaded 118 time(s).
Edited by user 28 October 2015 17:57:48(UTC)  | Reason: Not specified
thanks 4 users thanked Davide Carpi for this useful post.
on 28/10/2015(UTC),  on 28/10/2015(UTC),  on 28/10/2015(UTC),  on 28/10/2015(UTC)
Online overlord
#10 Posted : 22 September 2021 16:44:14(UTC)
Turkey
Was thanked: 325 time(s) in 224 post(s)
Not a bug but a cosmetic issue.
In Linux, plugin shows two square on each side of the value.
They are not written to variable, fortunately.
on 22/09/2021(UTC)
#11 Posted : 22 September 2021 20:47:54(UTC)
Thank you, it appears because the thin space character is not available in that font (the irony... was added for cosmetic reasons too...Grabli )
I'll get rid of it for a more robust alternative.
#12 Posted : 04 October 2021 13:48:47(UTC)
PLUGIN UPDATED SMath Studio 0.99.7822 and later
  • buttons are now made by vector drawing;
  • removed thin spaces because issues in mono fonts;
on 04/10/2021(UTC)
Offline Renzorex
#13 Posted : 25 October 2021 20:12:35(UTC)
Renzorex
Rank: Member
Peru
Was thanked: 4 time(s) in 2 post(s)
Hi, it seems that the "canvas setting" field does not recognize the "whatever" variable. I'm using smath in windows 10.Slider.png
Online overlord
#14 Posted : 26 October 2021 03:18:43(UTC)
Turkey
I think this can be a bug.
When a setting has a string value, it can not be read by canvas settings.
Delete the "TickPosition" = "both" and whatever will be readable again.
I have tried this with "orientation" = "vertical", whatever can't be read by canvas settings.
Deleted the "orientation" = "vertical" element, and it can be available again.
This behavior made me to think there is something wrong while reading strings.
#15 Posted : 26 October 2021 11:58:20(UTC)
Thank you, confirmed. I'll fix it ASAP.
You are right, it is related to strings encoding. If you remove the space character from "maximum value" it works as expected.
#16 Posted : 01 November 2021 12:44:42(UTC)
Issue fixed in both NumericUpDown and Slider regions for latest SS stable and later.
Online overlord
#17 Posted : 01 November 2021 19:56:08(UTC)
Turkey
String issue not fixed, at least for linux.
slider_options.sm (5kb) downloaded 18 time(s).
#18 Posted : 02 November 2021 11:58:47(UTC)
Thank you, I can reproduce with your file even in windows... this issue it's something more subtle, though Wallbash
#19 Posted : 02 November 2021 17:56:10(UTC)
Found it. You forgot to set the optimization to "none" on definitions, as indicated in the documentation. If you hover over the definition you can see that in both numeric and symbolic optimization the boolean equal between strings is preprocessed and stored as 0.
Online overlord
#20 Posted : 02 November 2021 20:28:13(UTC)
Turkey
Thanks, now it works.
To be honest I didn't read the documentation in first post.
I only looked in Reference Book and couldn't see that information in it.
2 Pages12>
